Just wondering if anyone has any megasquirt fuel ve tables to compare? I have a 95 probe with a klze cold air intake and headers with 2 1/2 inch full exhaust . When I am running the klze base map it is showing on my wideband lean , in order for me to get it in the area it should read my ve tables are showing numbers as high as 170 and this is NA ..... is this normal ? hope someone can help me out here my car wont run for shit after half throttle !!
megasquirt VE tables ?
170 is way too high.
Some other settings might be off. what do you have as your required fuel value, and what are you other basic settings
A lot of us have posted our tables here:
https://forums.probetalk.com/showthr...p?t=1701288659
Here is my table, that is dialed in with a wideband sensor. After 70kpa, Air/Fuel ratio gets ramped up to 13.0:1 at WOT, but below 70kpa, it's generally near stoich.
https://farm5.staticflickr.com/4498/...c47bdccf_b.jpg1996 Boysenberry Probe GT MTXtreme
2014 Fusion SE MTXtreme
2005 Mountaineer Premier
well I checked and for some reason my required fuel the engine size was only set at 1845cc so I will update that and see where I'm at today .. thanks for your response ... your table looks different than mine I guess its because maybe my tunerstudio is newer?
