Old October 11th, 2017, 10:34 PM   #1
mejum
Juiced Member
KLZE Distributor Rotor and Cap
Does anyone have part numbers for a replacement distributor rotor and cap for a KLZE? Preferably at O'Reilly's or AutoZone.
Thru trial and error, I've picked up 94 and 97 GT replacement rotors and caps and they don't fit the KLZE. The 94 rotor is too small to fit on the distributor--the 97 slides right on. However with the 97 rotor on the distributor, the stock KLZE cap doesn't sit flush on the distributor. The 97 cap doesn't have the female end under the cap for the shaft that comes off the distributor.
I found this old thread that says to reference the Mazda Millenia, however when comparing part numbers, they are the same as the KLDE.
Be daring, be different, be impractical, be anything that will assert integrity of purpose and imaginative vision against the play-it-safers, the creatures of the commonplace, the slaves of the ordinary.
mejum is offline   Reply With Quote
Old October 12th, 2017, 04:49 AM   #2
Usually you would swap your stock klde disty on during the klze swap.
Brizzy is offline   Reply With Quote
Old October 12th, 2017, 02:35 PM   #3
SuperSquid
It's all J-dogg's fault
SuperSquid's Avatar
overnight parts from japan.
'94 teal w/black int. some sort of sts, 65mm DE TB full KL31 ZE, CAI, Phenolyc spacers, mx3 flywheel, pacesetter headers, 2.5" exhaust, stainless brake lines, MS and LC-1. Charter member Club 15.2 - Mustang Dyno - 187/169 @the wheels
'90 White GT "Pearl"....uh ohzzzz...I gotz turboz. Now with T3....
'96 SE & '93 "Red-Eye" smashed and trashed.
SuperSquid is offline   Reply With Quote
Old October 14th, 2017, 06:06 AM   #4
spada
ProbeTalk MC
spada's Avatar
You could try contacting an engine importer and see if he will just sell and ship you the distributor from a KLZE. I don't know if anyone ever found a supplier in America with the cap in stock.
1996 Boysenberry Probe GT MTXtreme
2014 Fusion SE MTXtreme
2005 Mountaineer Premier
spada is offline   Reply With Quote
Old October 15th, 2017, 11:11 PM   #5
mejum
Juiced Member
it shouldn't matter what year KLDE distributor i pick up? all wiring harness connectors are the same?
Old October 16th, 2017, 05:03 AM   #6
What year is the car ?
Old October 16th, 2017, 04:58 PM   #7
NickR
It matters. There are 2 types: 93 and 94 are different from the 95 to 97, if I remember correctly. (Though you can rearrange the wires in the 3 pin connector to make the other type work.)
NickR is offline   Reply With Quote
Old October 17th, 2017, 03:57 AM   #8
IIRC the 93'-94' has 2 hall effect sensors and the 95' has only one so you would want one to match your ECU otherwise it will spend longer cranking to find DTC of Cyl#1
Nitrous oxide. - 79' Yamaha QT50 'Yamahopper' 70cc, MLM pipe, VM18 carb, dual stage reeds etc.
stoker100 is online now   Reply With Quote
Old October 17th, 2017, 08:22 AM   #9
mejum
Juiced Member
Car is a '94
I'm on the hunt for a junkyard '94 distributor.
Old October 17th, 2017, 07:57 PM   #10
Or you could find a 95, take the ecu, distributor, 3-pin crank sensor pigtail, a 3 pin front turn signal pigtail, and make an adapter for the 3 pin distributor plug, so you can plug and play swap in a 95 distributor which "should" last longer.
More complicated and expensive, but, it leaves your stock wiring intact, and keeps the car OBDI. I was using a 95 disty in my 94, for the last 10k miles til yesterday. I finally went with an aftermarket ignitor, and it's still missing so I need a coil now as well.
Old October 21st, 2017, 01:36 PM   #11
ivinklze
overnight like every part
ivinklze is offline   Reply With Quote
WANTED: KLZE Distributor cap AND rotor (ORIGINALS!!) Franky Wanted 9 August 8th, 2002 07:26 PM
Distributor Cap and Rotor LowGT 2nd Gen (93-97) V6 2.5L 2 June 7th, 2002 06:33 AM
what is a distributor cap and rotor? vasilli 2nd Gen (93-97) I4 2.0L 1 April 24th, 2002 03:09 PM
New Distributor Cap and Rotor for 93-97 2.0L gilliman PT Member Sales 0 April 23rd, 2002 11:03 PM
New Distributor Cap and Rotor??? Csmicfool 1st Gen (89-92) Performance 1 December 29th, 2001 11:56 PM
