Old June 26th, 2012, 04:36 AM   #1
stoker100
stoker100's Avatar
My 94' probe after 15 years of ownership
In the last 15 years my car has gone through a engine conversion, interior conversion, headlight conversion, respray (including shaved door locks/antenna/badges), then a rebuild, some significant weight reduction and of course many, many other modifications along the way. here's just a few pics of its journey:
During interior conversion from grey to black (2004):
http://members.iinet.net.au/~steven.s/dash2.jpg
After the respray (2008):
After the rebuild (2010):
Big brake conversion, mazdaspeed 6 calipers, 320mm DBA slotted rotors (2011):
manual steering rack (2014):
Weight reduction (rear seats/interior/sound deadening/speakers):
Gauges to monitor everything:
Stock VS OD pulley (2017):
The engine bay (2016):
What it looks like now (2018):
now for the mod list...
ENGINE MODS:
- KLZE engine conversion (rebuilt)
- Ported Heads
- Interprep valve springs, DE retainers
- Manual timing belt tensioner
- modified front idler pulley to retard cam timing
INTAKE MODS:
- 65mm bored throttle body, blocked cold start path & coolant flow path
- K&N sealed intake system in front bumper
- Ported & Polished Intake Manifold
- Gutted VRIS
- NACA bumper duct intake
- Ceramic coated pipes
BOOST MODS:
- Eaton M62 clutched supercharger (mounted in AC location)
- Custom inlet/outlet flanges
- 2.25" outlet piping
- 2.5" inlet piping
- Bosch bypass valve recirculating to intake
- Crank overdrive pulley (160mm, stock boost was 3.5 PSI, OD boost is 6 PSI)
OILING MODS:
- Oil filter relocated (trandapt 1158)
- King 6 oil filter relocation plate
COOLING MODS:
- 14" 1700CFM single pusher fan
INTERCOOLING MODS:
- Aquamist 220PSI pump
- Methanol-water 280CC/min injector (40% methanol)
- Aquamist 1300CC Fast Acting Valve (controlled by MS)
- 1 Gallon methanol-water tank
TRANSMISSION MODS:
- Lightweight flywheel (MX3)
- RR-Racing Stainless Steel Clutch Line
- Heavy duty clutch
IGNITION MODS:
- MSD6A CDI ignition
- MSD HVC-2 coil
- KLZE distributor
- NKG Vpower plugs (BKR7E)
EXHAUST MODS:
- Stone racing headers
- Fiberglass wrapped headers
- 2.5" catback system
- X force varex dual tip muffler
- Resonated test pipe
FUEL MODS:
- Walbro 255lph Fuel Pump (extra large sock)
- Aeromotive AFPR (A1000-6 13109)
- Millenia S injectors
- Banjo bolt delete mod
WEIGHT REDUCTION:
- Aircon system & wiring
- Airbag system & wiring
- Cruise control & wiring
- Rear interior/seats
- Rear wiper, squirter & wiring
- Antenna & wiring
- Drivers and pass door locks & wiring
- Charcoal canister, PCV system
- Stereo system, Speakers and wiring
- Door holsters removed
- Modified power steering pump bracket
(weights in at 1220kg - 1/4 tank of fuel with Jack, space saver and tools to change tire)
SUSPENSION/STEERING:
- Rear strut brace
- Rear 17mm whiteline sway bar
- TEIN super street's front and rear
- 17x7.5" ET35 BBS Wheels
- Hankook RS4 tires
- Moog end links all round
- Polyurethane bushes front and rear (Whiteline & Nolathane)
- New rear rear lateral arms
- Megan racing forward rear lateral arms
- Manual steering rack from 323 (custom rack end to end-link adapters and steering column adapter)
BRAKE MODS:
- 06-07 Mazda 6 MPS calipers (front)
- 320mm slotted DBA rotors (front)
- Hawk pads all round
- Braided brake lines all round
- Motul 660 brake fluid
INTERIOR MODS:
- Battery relocation (boot)
- Gear knob
- Short shifter
- Custom interior manual door lock covers
- Blue LED HVAC/window/cluster
- Re-trimmed from gray to black
- Autometer ultralite A/f, oil pressure, oil temperature & coolant temperature
- MOMO steering wheel with 25mm spacer
EXTERIOR MODS:
- Clear side indicators
- Thruster spoiler
- Shaved door locks
- Shaved antenna
- Shaved front bumper badge
- Shaved rear bumper badges
- GT rear reflector
- Taillights outlined in black
- Door ding stripes removed
- Espec to Aspec headlights
- Tinted windows
- Dual globe brake light mod
- Sunroof delete
- Rolled guards
OTHER MODS:
- Megasquirt 2 V3.0
- 36-1 tooth crank wheel
- EFI analytics Bluetooth dongle
- MTX-L wideband
- RR-Racing poly Engine Mount Inserts
whats left?
- more weight reduction, needs to be under 1200kg
- alternator overdrive pulley (purchased, just need to fit it)
- surge tank & pump? (if i cant fix my fuel loss during cornering)
Old June 26th, 2012, 04:59 AM   #2
KnezicDex
Niiiice! Keep it up! Whats the 0-60 time?
KnezicDex is offline   Reply With Quote
Old June 26th, 2012, 08:12 AM   #3
JKpgt96
Drives Light Blurple Car
JKpgt96's Avatar
Nice! One of these days I will get to do one for the '95..but not until the motor is done..otherwise it is just another teaser, lol. I don't think I ever did one on my '96 before I sold it..I should.
Car looks great!
JKpgt96 is offline   Reply With Quote
Old June 27th, 2012, 07:07 AM   #4
RedGT
Looks great! I'm really digging those blue valve covers.
1994 PGT MTX-CAI/STS/Hotshot headers/Vibrant catalytic/Pacesetter-Magnaflow catback/Outlaw spacers/RR inserts/Mazda6 brake upgrade/Yonaka coilovers/AWR trailing arms/AWR rear sway bar/PRD rear STB/95-97 rear end conversion.
2006 Velocity Red Mica Mazdaspeed 6
RedGT is offline   Reply With Quote
Old June 27th, 2012, 04:05 PM   #5
no13regrets
damn bro get to work and start putting that supercharger to use.
also i really like your paint its super clean and shiny
1995 PGT BLACK: CF hood, stock KLDE, Clutchmasters FX400, MX3 Flywheel, MS1 Extra, KLG4 coilpack with PRD wires, T3T04e turbo, same side intercooler, tial WG, custom fuel rails with nissan 550cc injectors, Aeromotive FPR, AEM Eugo, Autometer gauges, 2.5" custom Borla catback, Tokico blues, Eibach springs, FD rims, J30 projector conversion......
no13regrets is offline   Reply With Quote
Old July 8th, 2012, 03:52 AM   #6
stoker100
stoker100's Avatar
sorry i forgot to answer this. I no idea to be honest, ive had issues with the alternator for ages and thenmore recently the VRIS. last dyno day i made about 100wkw (135whp) from 5000rpm to 7300rpm, im hoping the repair of VRIS#2 has made a substantial improvement (i know i can feel it) to the power numbers. so i would say somewhere in the high 6's 0-60mph. Ill be happy when i hit 130wkw N/A (175whp) and then it will be boosting time.
ive also updated some pics, big brake kit is now fitted and mod list updated accordingly.
Old July 8th, 2012, 08:14 AM   #7
93SEProbe
Really wish I could get my hands on a right hand drive one. Thats one clean engine. What rims are the last shown? Very nice car.
1997 PGTS......Turbo, 3 inch exhaust,Ms1v3, Nitto555,lip, slammed adjustable supsension,Wideband, upgraded fuel, Lots of mods
93SEProbe is offline   Reply With Quote
Old July 8th, 2012, 10:23 AM   #8
ZE Power MX6
Holy tile driveway!
1994 MX-6 RS -- RIP 1/30/2012
1996 MX-6 M-Edition
1993 RX-7 Grand Touring
2010 Mazda3 Hatch Grand Touring
ZE Power MX6 is offline   Reply With Quote
Old July 8th, 2012, 04:53 PM   #9
Manofthestreet
Holy cow bro the car looks awesome
If you live around Kansas check kcprobes.com Or MOPOC If you are in MO
Manofthestreet is offline   Reply With Quote
Old July 8th, 2012, 07:04 PM   #10
LoNaTiC
Car looks sick keep it up!
G35 Coupe
95PGT kinda stock
12 R6
14' Optima slow
LoNaTiC is offline   Reply With Quote
Old July 9th, 2012, 06:41 PM   #11
ScottD961
Where did you get that oil filler cap ?
ScottD961 is offline   Reply With Quote
Old July 13th, 2012, 05:59 PM   #12
stoker100
stoker100's Avatar
ebay, just search ford probe billet oil cap
Old August 28th, 2013, 05:58 AM   #13
stoker100
stoker100's Avatar
updated original post with pics of gauges/SC mounted in place. ive got a lot going on for the remainder of the year so there will be no more major progress. However I endeavour to administer my internal combustion engine with pressures exceeding that of the atmosphere within the next 6 lunar cycles.
Old August 28th, 2013, 07:08 AM   #14
Tokyojt
Clleeeeeaaaaannnn paint....looks great!!
93 PGT-ZE-Turbo project
94 PGT-all stock and sexy
95 PGT-ZE -Supercharged
2012 Honda Accord-daily driver
Tokyojt is offline   Reply With Quote
Old August 28th, 2013, 11:22 AM   #15
ScottD961
Thumbs up
It looks nice with the shaved emblems and antenna. I like the second set of wheels and the rear spoiler you chose as well. Right now I have SC envy
Old August 28th, 2013, 11:29 AM   #16
DeProbeGT
Love the car man. Just curious but to date how much $$$ would you say you have invested to get the car to this point? Mine is coming along very slowly...
DeProbeGT is offline   Reply With Quote
Old August 30th, 2013, 04:08 AM   #17
stoker100
stoker100's Avatar
dont ask, probably 2-3 times what i purchased/fixed it for originally (purchased damaged and repaired it to save $$$), bear in mind im in Australia so prices are at least 2x that of the same parts in the US. But its never been about the money, its a learning experience and i have no regrets. All builds take time just remember never to rush anything as thats where things start to go wrong. If you start off small and work your way up, my first mod was clear corners now i can rebuild an engine, boost it, megasquirt and tune it almost with my eyes closed and im still no professional that's for sure.
just waiting for the day to take it to the track boosted!
Old August 30th, 2013, 10:07 AM   #18
SpeedFreak94
Nice Ride!
94 Probe SE
91 Civic EF Hatchback
SpeedFreak94 is offline   Reply With Quote
Old March 29th, 2016, 07:17 AM   #19
dammitcam
It really stinks I can't see photobucket pics on my work computer -_-
1995 Probe GT. Colt 218* cams, Tein SS Coilovers with EDFC, K6F trailing arms, CZT traction bars, ZE Intake Manifold, Milly MAF/OBDII swap, GReddy SP1, Probe Addiction Strut braces, RX8 Seats, PRD STS, PRD door sills, ACT 6puck
, MFactory LSD,Built trans, Euro tails and corners, Walbro 255, and more to come
dammitcam is offline   Reply With Quote
Old March 29th, 2016, 11:34 AM   #20
BradsPGT
BradsPGT's Avatar
Old thread, but always loved this car. Was this the one that got sold semi-recently or do you still own is, Stoker? I like the clean setup of the breather filters on your intake pipe, and I definitely need to get me one of those oil caps.
PS. If you still own it, a Mach1 lip would look amazing on this car!
1996 Probe GT - Bought April 2010, Boosted August 2014
Fast FC04 18x9, Black Leather, King6, ADDCO, AWR, Yonaka, Quad J30s, AVC Pipes, Tial WG, Greddy BOV, Aeromotive AFPR, MS1v3
1993 Probe GT - 110k, auto, parts car
2011 Impreza Limited Hatchback - Daily, Lowered, WRX Wheels & Wing
BradsPGT is offline   Reply With Quote
Old March 29th, 2016, 04:16 PM   #21
stoker100
stoker100's Avatar
Thanks, this car hasnt been sold (ill probably never sell it). Currently working on dual feed fuel setup then going to fit the supercharger overdrive pulley and changing my sc inlet pipes. Been boosted for 1.5 years without any issues.
Old March 25th, 2017, 12:24 AM   #22
stoker100
stoker100's Avatar
since the site is so quite i thought id update some of my pics in the original post. Car has had very few issues since being boosted besides a leaky bypass valve. latest mod was a 36:1 tooth 160ish mm supercharger OD pulley, boost went up from 3.5PSI to 5PSI but i have not tested it since fixing the leaky valve, hoping for 6-7PSI.
Future plans include retarding the mechanical timing of the cams, purchasing wheels/tires to suit the occasional track day and modifying the SC intake to take the bypassed air back in.
Old March 25th, 2017, 11:43 AM   #23
proboner
PT Know it All
Very cool man. I had the M62 with overdrive crank a while back... was super fun to cruise at like 3krpm turn on the supercharger and feel the sudden SURGE of power!
Beautiful Beast-
Elo-
Project RWD- RWD PGT For Sale... pm me if interested
proboner is offline   Reply With Quote
Old March 26th, 2017, 08:44 PM   #24
Brizzy
More pics of the thruster !
1994 Project PGT
M62 In Progress...
Old March 27th, 2017, 04:44 AM   #25
stoker100
stoker100's Avatar
or just look in here:
http://s299.photobucket.com/user/sto...?sort=3&page=1
Thanks guys, looks like 5.1PSI is all im going to get with the OD pulley, no leaks. did the measurements/math and its only revving up to 11,400rpm when the engine is at 7,000rpm so there is a little more it can go but it will do for now.
[IMG] code is On
