Go Back   ProbeTalk.com Forums > Tech Section > 2nd Gen (93-97) I4 2.0L
2nd Gen (93-97) I4 2.0L Discussion of Maint Issues for I4
Old August 28th, 2014, 12:03 PM   #1
blackpgt1994
North North American Mod
blackpgt1994's Avatar
CEL 55, (Pulse Shift Generator)
Fired up my 93 for a drive, looks like I've lost overdrive.
- O/D light flashes on and off as soon as go into second gear.
- All shifts are harder than normal.
- No 4th gear, O/D
- Pulled the codes the from the MECS: code 55 (Pulse Shift Generator)
- Replaced the PSG with a OEM ford unit. Still have the same problem.
Did a search on probetalk and google, and couldn't really find a good answer for else could cause a code 55.
Anyone else run into this before or find a solution?
-Kyle
93 Black probe (K-sporting)
blackpgt1994 is offline   Reply With Quote
Old August 28th, 2014, 04:27 PM   #2
jasons96pgtze
Colt Cams BB Master
Ive never seen that code on an auto trans for one of our cars before.. How did it drive the last time you drove it and how long ago was that?
jasons96pgtze is offline   Reply With Quote
Old August 29th, 2014, 12:29 PM   #3
blackpgt1994
Probably around 2 weeks between the last time I drove it without issue, and the time I fired it up again and it didn't have O/D / started throwing this code.
-Kyle
Old August 30th, 2014, 07:54 AM   #4
unionrdr
unionrdr's Avatar
That's a sign you need a nee VSS-Vehicle Speed Sensor. It also contains a Magnetic Pulse Generator that feeds engine speed info to the computer, other sensors & the like. It's on the back side of the ATX near the bell housing.
'94 PROBE SE Middle-aged croozr
unionrdr is offline   Reply With Quote
Old September 2nd, 2014, 06:40 AM   #5
blackpgt1994
I was looking into it being a VSS failure as well, but wouldn't my speedometer be non-functioning as well if it had failed?
-Kyle
Old November 13th, 2017, 08:33 PM   #6
blackpgt1994
Does anyone happen to know the part# or have a photo of the VSS for the 93 2.0L?
-Kyle
Pulse generator code 55...... 74eldo 2nd Gen (93-97) V6 2.5L 5 January 8th, 2010 02:17 PM
Speed Pulse generator or TSS and TCM jyi21004 2nd Gen (93-97) V6 2.5L 3 September 29th, 2006 12:22 PM
WTB: VSS and pulse generator Griffon783 Wanted 0 November 18th, 2002 10:12 PM
pulse signal generator crook 2nd Gen (93-97) I4 2.0L 2 July 30th, 2002 02:05 PM
pulse generator 91REDLX 1st Gen (89-92) All 2 April 10th, 2001 08:17 PM
