Go Back   ProbeTalk.com Forums > Tech Section > 2nd Gen (93-97) I4 2.0L
2nd Gen (93-97) I4 2.0L Discussion of Maint Issues for I4
Old October 23rd, 2017, 07:40 PM   #1
RyanT
2.0L crank no start
Hello all,
I used to run a KLZE. I had 5 or 6 Mazdas in total. That was years ago.
I'm trying to help a friend with his 93 2.0L MX-6.
I spent some time with it tonight and I have some information, but no solution:
-Cranks, no start
-No codes. Pulling MAF plug yeilds a code.
-All fuses are good. jumped the engine ignition relay, no change.
-Disty rotor turns with cranking.
-No fuel or spark - although there is a weak spark when you stop cranking.
-Removing disty and spinning rotor by hand does run pump and injectors - forgot to check for spark.
- 12V on IG- in DIAG box - seems strange to me.
-Really weird voltage readings across injector (unplugged). No consistent GND or 12V on either pin. Voltage is really all over the place, positive and negative.
-No continuity to ground at IG-. Jumping IG- to ground yeilds a small spark at the jumper, but no change.
Since the voltages are weird on the injector and the IG-, I am thinking it must be a sensor ground issue, or an ECM.
Thoughts?
'93 1.8L BP MX3 - black - RIP
'93 2.5L ZE MX3 GS - black - RIP
'92 2.5L DE MX3 - Red - RIP
'99 M3 - Stock
'03 EJ20K swap Forester (Xti)
RyanT is offline   Reply With Quote
Old October 24th, 2017, 09:20 AM   #2
BoostedMan
cps, or ground
BoostedMan is offline   Reply With Quote
Old October 24th, 2017, 09:41 AM   #3
RyanT
I am confused why you can hear the injectors firing in turn when spinning the disty manually, if it requires the CPS?
'99 M3 - Stock
Old November 7th, 2017, 08:31 AM   #4
RyanT
Turns out it was the distributor - surprise.
'99 M3 - Stock
What started crank/no start is now no crank/no start.. stencer 2nd Gen (93-97) V6 2.5L 19 February 11th, 2009 06:12 AM
Loud noise during start up, goes away if I crank long or kill the car and start again Fantomas 2nd Gen (93-97) V6 2.5L 4 November 25th, 2005 05:02 AM
Crank Crank Crank *whiirrrrrrrrrrrrr* FAST_91 Indy Probes 7 April 19th, 2003 04:22 PM
crank crank crank thud crank crank iamdung 2nd Gen (93-97) V6 2.5L 29 May 1st, 2002 08:46 PM
