Old November 12th, 2017, 07:25 PM   #1
Horror Angel
Hatch lift (trunk support) brands that last?
I hardly use my car but my OEM hatch lifts (trunk support) died a couple years back and i replaced em. I wanna say the advance auto/auto zone ones didnt even last a year or two.
Do brands matter? I see rock auto has some Monroe and thats a pretty big name. Then again rock auto has sold me a bunch of duds and the fact its the most expensive one they sell doesnt mean much usually. What works for you?
Do they all fail pretty quickly ? Currently i just keep a small vice locks in the trunk, if they all fail in like 6-24 months i dunno if its worth replacing them. My vice grips probably work better than any new pair does just they take longer to use
Automatic 97 Ford Probe GT 54,000 miles original engine n stuff.
Horror Angel is offline   Reply With Quote
Old November 12th, 2017, 08:38 PM   #2
I'll check the ones in my 94 for brand name. I got them from the JY 2 - 3 years ago now. I opened a hatch on rusty probe and it lifted itself. I was impressed but walked away. Next day I came back could see the hatch was still open across the yard. I pulled them and bought them. They've handled thousands of openings and closings now. Word of caution, keep your chin out of the way as you get used to the arc because it will lift out of your fingers once it gets going. "Experience"
Old November 13th, 2017, 02:42 PM   #3
DatVash
I pulled mine off of a 97 GTS I found in a Pick'n Pull about a year ago and they are still going strong. I'll also look at my brand today and repost later or tonight.
DatVash is offline   Reply With Quote
Old November 16th, 2017, 09:36 AM   #4
DatVash
Mine don't have and branding on them, just some numbers; 010516, P-3381-GF.
Could be part numbers, hopefully this might help. But I wouldn't know what brands would be good either, best of luck.
Old November 19th, 2017, 06:00 PM   #5
MSDKLZE
Turbo Junkie
MSDKLZE's Avatar
I have rear lift gate struts from some Ford Escape or something like that. I got them in used condition many years ago when I worked at the KW Cook's Auto Salvage.
It took a little tweak here and there (some struts use a two-bolt plate and some use a single ball-stub) to make it fit, but now the hatch opens even higher than before and has never sagged or fell. These particular struts are like 3 times stronger than oem Probe ones.
If you are interested in this conversion, I MIGHT have done a writeup or previous mention of it years ago .. (cant remember) I could probably go check them closely for some part number too.
I feel like they are so strong, they will last me a lifetime!
DRIVE IT LIKE YOU BUILT IT!!
Hatch lift support removal iraklic 2nd Gen (93-97) V6 2.5L 3 March 27th, 2016 11:38 AM
hatch lift support problem jpk2379 2nd Gen (93-97) V6 2.5L 9 May 12th, 2007 11:17 PM
replacing lift support on 90 gt hatchback jays90gt 1st Gen (89-92) All 3 November 28th, 2005 06:43 PM
support.... support.....support 90probelxbrandon Greater Pittsburgh Probe Owners Club 1 October 14th, 2001 01:51 AM
Trunk Lift question mystic626hb 2nd Gen (93-97) I4 2.0L 6 August 30th, 2001 09:28 PM
