Hi guys, so I was workin on the car today and my cell phone battery was dying. OK no big deal, plug in the car charger- but I have to put the key in and turn it to ACC. I know that's the norm for new cars today- but I like the older models where the cigar lighter (and whatever was plugged in) always had +12v, whether or not the key was in or not. (I'd rather drain my battery then lock my keys in my car! plus I *hate* leaving the keys in the ignition when I'm working on the engine...)
So I started thinking... then went inside and got my Ford EVTM manual- and it looks like the Audio fuse, for the factory amp, isn't doing anything in my car right now. I removed & bypassed my factory amp when I got the car; my speakers run off my budget aftermarket radio. And my car didn't come with a factory subwoofer amp. From what I see- that underhood Audio fuse was only supposed to run the underhood light (no bulb in mine) and the factory amps. So I think it's a "free fuse"! And it's not controlled by the ignition switch either!
My plan is to re-route my lighter socket so it connects to that audio fuse under the hood... the EVTM shows C217 by the kick panel should have the gn/w wire- OR I can go digging under the center console to find the wires to C310 (which plugs into the amp).
Sound good to re-use that fuse for the lighter socket? Am I right that it's not being used right now (with my old factory amp taken out)?
Thanks!
Thanks!
