hey guys you have always been able to help me before so here we go again. When im driving at about 50 and step on the brakes my steering wheel shakes and shutter's pretty bad.. any idea's?
my guess would be that you need a brake job like new pads and get your rotors turned or if they are to bad to be turn replace them what is giving you that shutter is a warp rotor
Check around and buy new rotors and pads for the front. A good rule of thumb is to only turn a rotor once, if you can verify by YOUR records that it hasn't been turned before. i saw front rotors in a summit racing sport compact catalog for under 40 bucks apiece. New/turned rotors and brakepads will fix it!! That's my two cents worth.
I had the same problem braking from 120 mph. Very scary. Bought Powerslot slotted rotors and Axxis Metal master brake pads and was in awe how hard and smooth the stop was from over 100 mph.
