PSE driver--
ATX to MTX parts list for a 2.0L as follows:
-5-speed transmisson from 2.0. (2.5 will not work)
-Shifter
-Linkage
-Shifter boot
-Pedals, Clutch and Brake
-Clutch master cylinder
-Clutch slave cylindder
-Clutch lines, 2 metal, one rubber
-Brake fluid resevoir specific to MTX
-Flywheel
-Clutch/Pressure Plate
-Left and Right Half shafts(axles) Specific to MTX
Joint/jack/middle shaft Specific to MTX
-ECU, Not always needed but will get rid of CEL and Blinking O/D light after swap. I recommend it.
-New Pilot and Clutch Bearings
-All three Tranny mounts and brackets.
-Lower tranny insulator mount.
-Clutch pedal harness, If you have cruise you jump this over to your bake pedal harness.
It's been over a year since I did this swap and i think this is everything. LJspeed, Reppin626, Joel94SE, or anyone else who has done this swap, let me know if i missed something.
I put this up because my archived list i had made at the time of doing it is no longer available.
-Shifter
-Linkage
-Shifter boot
-Flywheel
