Bump for XRP's question
Saved another and gained a black one finally!
1995 Probe GT. Colt 218* cams, Tein SS Coilovers with EDFC, K6F trailing arms, CZT traction bars, ZE Intake Manifold, Milly MAF/OBDII swap, GReddy SP1, Probe Addiction Strut braces, RX8 Seats, PRD STS, PRD door sills, ACT 6puck, MFactory LSD,Built trans, Euro tails and corners, Walbro 255, and more to come
If memory serves me correctly it is .032" thick aluminum sheet. I don't remember the exact thickness. But with the framework put together the way I did -it doesn't need to be extremely thick. The framework provides lots of supportive strength. I am 230 lbs and I was all in there and on top of it when I was mashing down the sound mat material. It was easiest to get the stuff to stick well by just dancing around on top of it with no shoes on.
The sheet was an old sign that had been taken down long ago -and I was told to throw it out when we were cleaning up. But me knowing that it was made out of aluminum and that I would definitely be able to use it at some time down the road -I commandeered it.
Oh -and I must add that purchasing a pneumatic rivet puller is a most valuable move ever! I was pulling 3/16" stainless pop rivets with a hand puller when the handle snapped and nearly jammed a knife-sharp end into my arm to rip it open. I lucked out and it missed by a very small safety margin and I ended up with just a bad scrape.
I riveted the forward and aft aluminum angles and then made slots in them for the longitudinal "T" ribs (2 - 90 degree angles riveted back to back with silicone sealant sandwich between). Then I dropped the 3 longitudinal "T" ribs down into their respective slots and riveted them at the ends to the fore and aft angle supports. Then I just riveted all of the other short angle pieces between to the "T" ribs. To make everything sit flush before topping off with the top sheet -I used aluminum tape to hold some aluminum shim pieces (1/8" flat bar) in place.
All structure was 1/8" thick x 2" wide and purchased at Home Depot in the metal section (minus the donated sign). I finished it off by first sealing all the cracks and voids underneath with silicone sealant. Then after that was cured -I sprayed the entire underside with rubberized under-coating.
I keep forgetting that others may not have aircraft battle damage structural repair experience as I do -so I should add that to give the rivets more holding surface on the underside after shooting them -I smashed them with a hammer from underneath while my son backed them up top with a heavy steel round rod piece. This causes the protruding stub underneath to flatten out and hold far better. As seen in the photos -the rivet heads were very wide and really didn't need any improvement there.
I got the SS rivets at Ace Hardware -but you can also pick them up on e-bay. I recommend 3/16" x 1/2" long minimum for steel or SS. If you are going to use aluminum rivets -I would recommend 1/4" x 1/2" long.
P.S. One last note -don't expect this to be a quick 2 hour patch job. I probably have at least 20 hours into it. Someone else who has more SM experience than me might be able to knock it out quicker. It was extremely tedious with all the measuring, cutting, edge de-burring, slotting, shimming, riveting, smashing, sealing and finally soundproofing.Last edited by KLZE Porsche; October 23, 2016, 03:14 PM.Success is a measure of determination!
Mini-me & 500k "Old Gal" RIP
Restoration of a legend
dope! much easier the nwelding sheet metal in!94 PGT[96 PGT FuLL OBD2 WiRe HaRNeSS] ]KL31 SHoRT BLoCK & CaMS] [KL1C MaF SWap] [CuRVe NeCK MaNiFoLD] [KL68 TB] [Hei & MSD BLaSTeR 2] [Cai] [SS HeaDeRS] [STS] [R&R PoLY F&R MouNT & SHiFTeR iNSeRTS] [STaGe 2 CLuTCH] [FiDaNZa FLYWHeeL] [eGR DeLeTe] [FuLL a/C DeLeTe] [CoiLoVeRS] [RX8 WHeeLS oN 225/45/18]
Originally posted by xrp861 View Postdope! much easier then welding sheet metal in!Success is a measure of determination!
Originally posted by Venchman View PostAmazing find! OutstandingSuccess is a measure of determination!
Curious as to the reasoning behind it...
It cant weigh much if any less than stock (especially after adding sound deadening) and seems like a lot of work. I mean I can understand the desire to remove the spare tire well and have done so on my other car, but that was to fit a g35 muffler.Beautiful Beast- 1997 PGT in process of becoming an SC/NA Beast...
Elo- 1990 BMW 325i weekend car
Brunhilde- 2003 BMW Z4 3.0 6-speed daily driver
Originally posted by proboner View PostCurious as to the reasoning behind it...
It cant weigh much if any less than stock (especially after adding sound deadening) and seems like a lot of work. I mean I can understand the desire to remove the spare tire well and have done so on my other car, but that was to fit a g35 muffler.Last edited by KLZE Porsche; May 13, 2016, 03:23 PM.Success is a measure of determination!
Well that makes sense then!Beautiful Beast- 1997 PGT in process of becoming an SC/NA Beast...
Originally posted by j-dogg View PostI too, know of the black Probe struggle, I used to have one and I'm looking for anotherSuccess is a measure of determination!
After 3 weeks of hell and back from a very nasty flu -I am finally back in action to some extent. Other life episodes have also held me back. But it feels so good to finally feel good and have a little bit of time to work on my hobbies. So here is what I got done today.
First -I patched some holes and sprayed a little paint:
And then I decided to try out some sound mat as a replacement for the typically water damaged and dilapidated firewall fiber sound mat. I don't know how it will hold up against engine bay temps -but I am hoping for the best results. It certainly cannot be worse than OEM is when you try to spray wash your engine! After I get this one back on the road again and run it for a while -I will post the results. But it sure looks clean at the moment. I hope it stays that way!
I got all of the firewall pieces installed (brake booster, clutch master, etc.) -and the nice thing about doing it this way -is that you do not have to use the booster to firewall gasket -or other gaskets. The sound mat serves as a very good sealing gasket!
Last edited by KLZE Porsche; October 24, 2016, 04:25 PM.Success is a measure of determination!
What brand of sound deadening material did you use?I think it's an obsession!
http://www.supermotors.net/registry/media/911982_1
Originally posted by B-Ball View PostWhat brand of sound deadening material did you use?Success is a measure of determination!
