DID YOU KNOW??? 93-95 to 96-97 Probe GT differences
My 95 does not have lit door locks, but the ignition does have a light that is burnt out lol.
I also do not have "theater" lightning.
every 93-97 Probe ever made had the ignition key light
your 95 doesn't have theater lighting or lit door locks because both of those were options (i believe they came together in the same convenience group package), that definitely didn't come standard.
93-94 no center GT, license plate takes it spot. 95-97 has GT center, license plate moved to bumper location, as well rear bumper slightly different design having smaller center valance
how about the lit key hole on the doors? I believe it was a 93-94 GT only thing...but not sure. and when you unlock the door with the key if you turned it farther it would power unlock the passenger door as well.
my 95 GT has lighted exterior door locks
---------- Post added at 11:14 PM ---------- Previous post was at 11:12 PM ----------
Really? Maybe I've got a burnt bulb then, but I've definitely never seen this light. I'll have to look into this one.
I know the Canadian probe block heater was mentioned, but was the heated power mirrors mentioned? I may have missed it. I cant remember what year it was off of though, I read it a while ago.
Way to resurrect my nearly year old thread, dude! lmao
---------- Post added at 02:36 AM ---------- Previous post was at 02:34 AM ----------
my 95 doesn't have the heated mirrors
both of those options were dropped after 1995. i have a fully loaded 96 GT with every single available option (it even has the super rare stock subwoofer) but it doesnt have the heated mirrors or lighted exterior door locks. cost cutting began in 1994 on Probes and it continued every year till alot of things were stripped, the 1997's were bare of many things.
i am new to owning a probe and have come upon some electrical mishaps, if anyone could help me with my questions it would be really appreciated.
(found a 60 amp fuse that is control of a slight battery drain the fuse controls 27 different items that i have been going through and inspecting).
if anyone has had similar complications please message me or contact me through this thread i am newer to the site so i can not yet send direct messages. thank you for any and all assistance
-Erica
FPGT24 - thanks for all the useful info. I am afraid I almost got what I needed from your post but would like to ask you something. I am looking to replace both damaged tail lights of my red 95 GT. I want black frames because I have decided to paint the whole vehicle black. What all would fit? If you give me a selection of all that would fit I would have options in my search (e.g. 94 GT, 96 SE, 96 GT, etc).
I have seen some on ebay with black frames, but the lenses on the end look orange - I suppose these are non-GT according to your knowledge posted below. I may ultimately settle with red frames and paint them too.
Yes the black outlines will fit without any problems.
The ones with orange lenses use a different bulb harness. They are from the eu spec Probes. They will also fit as long as you get the proper harness for them.
I used the stock US Spec harnesses on my Eu spec tails (amber turns) and they worked perfectly. What is supposed to be different about the harnesses?
I'd like to know my options for replacing my damaged tail lights. I am repainting my damaged red PGT from red to black and would like to get the versions with the black frames. Saw possibly all 2nd gen probes fit each other but need to know before buying. Some versions on ebay have orange lenses on the outside portion? Thanks a bunch for your list - just not sure it quite gives me what I need in this area.
---------- Post added at 10:56 PM ---------- Previous post was at 10:53 PM ----------
Sorry to post that question twice - I didnt see my post and thought it didnt go thru. Thanks for your timely replies. I got what I needed.
