I've got a few little issues I need help figuring out how to fix.
Cold Start:
When I start the car it starts fine, its just that it revs really high and then slowly comes down as it warms up.
Hunting Idle:
This is new, it only started happening the past 4 times I took the car out. Once the cars warms up, the idle goes up and down (like a bad TPS on a stock car). Literally, nothing has been touched recently to cause this, so I'm clueless on this one. Figured maybe its a setting that needs adjustment. but I'm not sure why it would start out of the blue. When this happened I attempted to adjust fuel table but it didn't change anything. Even tried Autotune and that didn't help.
RPM read differently (stock tach and TunerStudio)
This I noticed today. The Tunerstudio tach reads about 700rpm higher than the stock PGT tach.
Info about the car:
-94 PGT
-MS2 v3.0
-Colipacks
-Stock IAC (plugged in and coolant lines are hooked up like normal)
-GM IAT instead of VAF
I took a datalog, but I'm not sure how to post it for anyone to download it. I looked around but haven't been able to find any instructions on how or where to post/upload it.
Edit:
Nevermind, I found a file hosting site
Here's the Datalog - http://s000.tinyupload.com/?file_id=...41658436013394
Cold Start:
Hunting Idle:
Info about the car:
-94 PGT
-MS2 v3.0
-Colipacks
Edit:
