95 Probe GT 2.5L MTX
I'm trying to hook up a remote start safely so that it will only work in neutral. I've spent more than four hours searching and reading and there is no definitive answer for my question available, so here goes!
I've run the two green wires from the harness under the TB through the firewall near the clutch pedal. I'm showing +12v across those wires when the car is in gear (key "on"), 0v when in neutral. How would I wire up one of these 5-pin automotive relays...:
http://www.partsexpress.com/pe/showd...number=330-073
...to bypass the clutch position switch (SPST). I was thinking about wiring the CPS to pins 87a (switch open) and 30 to close the CPS when 0v are applied, but 12v (in gear) across pins 85 & 86 (green wires from tranny) should keep the relay energized (and the Clutch Position Switch open) when in gear. Will this work? Can this relay handle being energized most of the time while driving? FYI, I'm not worried about Cruise Control since it isn't working anyway.
Any other ideas? I've tried coming up with a 2-relay circuit, but my feeble little mind can't seem to put it all together. Please help me!
