Dyno Run Results Database
  • #61
    -Year- 1993
    -Make and Model -Mx6 LS
    -Transmission- MTX
    -Mileage on engine -? JDM used from TOKIO MOTORS
    -Type of engine -KLZE
    -Power mods only KLZE, Malpassi FPR at 50psi WOT,mx3 shaved FW 12lbs, UDP UO, PS headers, 2.5 exhaust, Port&polish heads with 3 angle job, 65mm TB, MSD6A with Blaster 2 coil,Walbro 255hp
    --Brand of Dynomometer -Mustang dyno
    174.3whp and 152.5TQ
    Will post the plots as soon as I get a place to host them!
    BIGGEST WHP MAZDA MX6 KL EVER-----KLZE with PAUTER Rods and Wiseco Pistons 8.5:1 ...........553whp and 495tq@28psi and still running....
    1997 Silver Frost PGT... like new...
    dude, your email address isn't working ~admin
    • #62
      Year 1994
      Make and Model Mazda MX-3 GS
      Transmission MTX
      Mileage on engine 140k
      Type of engine KL03
      Power mods only Stock grand national turbo, kit made by me, 2.5" crush bent exhaust with cheapie 2.5" thrush turbo chamber muffler, test pipe, tied VRIS, water injection spraying washer fluid, non intercooled, walbro 190lph fuel pump, 8:1 fmu, 3 cold start injectors
      Other misc parameters 91 octane pump gas
      Brand of Dynomometer Dynojet 4th gear
      Elevation of the city where you dyno'd Ft collins, CO - 5300 feet
      5 psi:
      whp=223.03 wtq=?? Spark plug wires missing too bad to get rpm value, so no tq
      8 psi:
      whp= 268.95 wtq=??
      94 MX3 V6 - 403 whp 412 ft lbs 15 psi pump gas. RIP
      04 Volvo S60R 6 spd
      • #63
        Year 1995
        Make and Model Probe GT
        Transmission MTX
        Mileage on engine <20,000km
        Type of engine KLZE
        mods KLZE, pod filter, custom KLZE EPROM.
        Other misc 91 oct gas, melted rear bank cat and final cat
        Brand of Dynomometer Dynojet 3rd gear
        whp=146 (108.8KW)
        http://home.iprimus.com.au/stoker100/dyno12th2nd05.jpg
        Supercharged - 94' PGT: ZE, MS2, W/M Injection, weight reduced, manual steering because weekend race car! mods and pics thread
        • #64
          FrankenProbe ('93 PGT, 94k miles)
          *210.1 whp @ 6100 rpm (dynojet)
          *184.7 wtq @ 5700 rpm (dynojet)
          http://www.supermotors.org/getfile/1...ken_dyno01.jpg
          Intake
          • home depot ram air
          • 64mm TB
          • KLZE IM with removed VRIS
          • port-matched phenos
          Cylinder Heads:
          • ported & polished KL03 heads
          • polished & cc'd combustion chambers
          • Ferrea SS valves, stock size
          • Interprep valve springs & shims
          • Custom grind .471" int/exh lift cams
          Block
          • stock KLZE everything
          Ignition
          • Stock plugs, stock wires, stock distributor, stock timing
          Exhaust
          • Hotshot flanged headers
          • full 2.5" catback, mandrel bent, cherry bomb + dynomax ultraflow muffler
          Drivetrain/Misc
          • ACT HDR6 6-puck race clutch
          • MX-3 flywheel
          • Stock '94 PGT transmission
          • 26x8.5x15 Mickey Thompson ET Drag slicks @ 9.5 psi mounted on 15x7 cheapo steelies
          • MBX underdrive pulley
          Weight reduction/misc
          • no a/c
          • no power steering
          • lexan windows (except windshield)
          • no EGR, no VRIS, no ABS, no airbags...etc - use your imagination or look at the pics
          Fuel
          • Stock fuel pump (that's right!)
          • 100 octane fuel
          • adjustable FPR @ 55psi idle, 60psi WOT
          • stock injectors, stock tank, stock filter...
          • stock KL03 ECU, '93 model year
          • #65
            Date: 3-27-2005
            Elevation: 1090 feet (as per www.city-data.com )
            -1995 MX-6 LS - COMPLETELY STOCK KL03 - 138,000 miles
            Dyno: DynoJet Dyno 4th gear pull
            Temp ~40*F low humidity
            Results:
            Run #1: whp=135.6 wtq=141.9
            Run #2: whp=136.9 wtq=142.7
            Run #3: whp=137.9 wtq=143.1
            Dyno printout:
            Jason
            Back in /X\IPOC Land!
            • #66
              -Year 1994
              -Make and Model Ford Probe GT
              -Transmission MTX
              -Mileage on engine ~50K
              -Type of engine KLZE, Noyan Engines USA
              -Power mods only KLZE, AFPR set to 43psi running 310cc/min Millenia S injectors, Hotshot CAI, stock manifolds, 2.25" Shaodome Bulkbuy exhaust w/magnaflow resonator, Megasquirt Electronic Fuel Injection computer controlling fuel and spark (with my own fuel and spark settings), VAF Delete, Greg94PGT 65mm throttle body
              -Other misc parameters Intake Temp: 90F, Coolant Temp: 192, Ignition Timing: 29degrees to 5500rpm, 31degrees from 5500rpm to 7000
              -Brand of Dynomometer Dynojet (at BigShot Dyno in Hudson Ohio)
              -Elevation of the city where you dyno'd 1090 feet above sea level
              Results:
              Two pulls using Megasquirt'n'spark
              179.4whp, 162.1wtrq http://www.msu.edu/~spadaben/probepics/179.jpg
              181.7whp, 163.7wtrq http://www.msu.edu/~spadaben/probepics/181.jpg
              More importantly, check out the area under the horsepower curve in the upper rpm's
              2014 Fusion SE MTXtreme
              2005 Mountaineer Premier
              • #67
                -Date March 26, 2005
                -Year 1993
                -Transmission MTX (formerly ATX)
                -Mileage on engine ~55K
                -Type of engine KLZE, Japan Direct - Raleigh, NC
                -Power mods only KLZE, Bosal Cat-back, Bosal Headers, Test Pipe, Unorthodox UDP, Outlaw Engineering Pheneloc Spacers, SBC TZ Clutch, Fidanza Flywheel, K&N on VAF, Stock Motorcraft Plug Wires
                -Other misc parameters Stock ECU w/ TCM, Removed EGR, Stock Fuel System, Stock Ignition System, 18x8 Moda R6 Wheels with 225/40/18 tires, Bad O2 Sensors
                Results:
                170.5whp, 157.1wtrq http://people.emich.edu/slettieri/ProbeDynoPlot1.jpg
                171.9whp, 161.1wtrq http://people.emich.edu/slettieri/ProbeDynoPlot2.jpg
                172.8whp, 160.7wtrq http://people.emich.edu/slettieri/ProbeDynoPlot3.jpg
                Sandon Lettieri
                1993 Probe GT - KLZE & Stuff - 172whp / 161wtq - 146k
                2013 Focus ST - Stock & Stuff - 251whp / 290wtq - 142k
                • #68
                  1996 PGT MTX
                  Engine: KLDE, base engine not modified (stock throttle, VRIS, cams, heads, etc)
                  Mods: Custom CAI, Pacesetter headers (the dual ball-joint design), 2 3/8 ID catback with Borla muffler, JJ Resonated TP, CM II-R clutch on stock flywheel.
                  Other: Stock silver swirlies with Toyo Proxes FZ4s worn to wear bars, car was running quite warm towards the end of the run. This was also done on a Clayton brand dynamometer. Its neither a Mustang or Dynojet, but it is still accurate with numbers similar to a Dynojet.
                  Results: 160whp at 6200rpm. No print out of the plot, sorry.
                  Kevin B - Former Probe-owner
                  06 Legacy GT
                  98 Legacy GT
                  • #69
                    My Probe GT KLZE
                    -Year: 1995
                    -Make and Model: Ford Probe GT
                    -Transmission: MTX
                    -Mileage on engine: 120.000km
                    -Type of engine: KLZE (’98)
                    -Power mods only: KLZE, Pacesetter exhaust mainfold, cat. removed, Sebring exhaust, RAM cold air intake with green filter.
                    -Other misc parameters: RAM air intake not fitted during dyno run, so air intake temp. +/- 60 degrees celcius ( +/- 140 degrees fahrenheit) (it was not possible to touch the air intake filter, caused by the heat under the hood).
                    -Brand of Dynomometer: New type DynoJet
                    -Elevation of the city where you dyno'd: The Netherlands
                    Dyno run results (unfortunately with bad air intake)
                    For more pictures of the car and the modifications, take a look here: Pictures of my Probe
                    whp = 159,40 hp (117,2kW)
                    wtq = 166,54 ft-lbs (226Nm)
                    • #70
                      -Year 1990
                      -Transmission MTX
                      -Mileage on engine rebuilt
                      -Type of engine f2t-Power mods only in my sig.
                      Brand of Dynomometer Mustang dyno-Elevation was I dont know.
                      197whp and 256 lbs torque.
                      1989 GT, heavily modded....
                      • #71
                        1997
                        Probe GT
                        Manual Transmission
                        154,000 KL03
                        Dyno-Jet
                        152.35whp and 149.68 torque @ 5700
                        Cupertino is in the house!
                        • #72
                          YEAR: 1996
                          MAKE/MODEL: FORD PROBE GT
                          TRANSMISSION: MTX
                          ENGINE MILEAGE: 85,000
                          TYPE OF ENGINE: KLDE
                          PERFORMANCE PRODUCTS:
                          HOTSHOT CAI, HOTSHOT HEADERS, JJ TESTPIPE, BORLA CAT-BACK, KLZE IM, CZT 67MM TB, FIDANZA, CLUTCHMASTERS STAGE III, MSD 8.5MM PLUG WIRES
                          ADDED SINCE LAST DYNO:
                          COLT SS CAMS, AEROMOTIVE AFPR, WALBRO 255
                          BRAND OF DYNO: DYNOJET (4th GEAR)
                          171.18 HP 152.68 TQ
                          DE/ZE Hybrid 189 WHP 165 WTQ <--- SPUN #6
                          • #73
                            1993 Mazda MX-6 MTX
                            270,000km's
                            KL-DE
                            Modifications: kl31 chip/je50vaf, klze im, 2.5" crushbent exhaust, MSD SS coil, hei, obx headers, phenos, kl31 camset Fr./kl01 camset Rr., wai
                            160hp@6200
                            153ft-lbs@4500
                            4th gear pull on DynoJet/ 90degrees F/ 30%hum.
                            12.5-12:1 a/f ratio (consistent yet too rich)
                            dyno
                            • #74
                              Year 1995
                              Ford Probe GT
                              MTX
                              120,000k miles
                              KLDE/03
                              Mods
                              CAI - 64mmTB - Test Pipe - Pacesetter Cat Back - Unorthodox Flywheel
                              17 inch Enkie RS2 with Wnali 235/45/17's
                              DynoJet Dynomometer
                              93.6 degrees
                              29.3 in-Hg
                              18% humidity
                              800 feet elevation
                              WHP: 155.27 @ ~5700rpm
                              WTQ: 151.80 @ ~5000rpm
                              MazdaSPEED6
                              • #75
                                Date: 9/24/2005
                                -1994 Ford Probe GT MTX 1700 miles fresh
                                Mods: 10:1 Compression Ross pistons, Eagle Rods, 66mm TB, Ported stock intake manifold(bottleneck), P&P heads with 5 angle valve job, Interprep Cams and valve springs, Pace$hitter headers, JJ RTP, Greddy exhaust, Aeromotive FPR, Fidanza FW, stock ECU
                                Misc: 38psi idle fuel pressure, 39.5psi WOT fuel pressure, clutchmasters stage 3 clutch, Kosei K1 16 X 7" (15.5lbs)
                                Dyno-Dynojet 4th gear pull SAE corrected
                                Result-
                                177whp
                                159 ft/lbs
                                Actual was 181whp 162 ft/lbs
                                Dyno Printout
                                Dyno Video
                                This is the highest # I have seen on a KLDE manifold, ZE manifold and retune to come soon, looking for high 180's whp maybe 190 running slightly leaner a/f's as I see the big NA numbers are coming around 14:1 a/f.....
                                New motor has 1700 miles on it running good so far...
                                Ross Pistons 10:1/Eagle Rods/66.5mm TB/Ported manifold/P&P heads w/5 angle valve job/Interprep "street" cams and springs/Pace$hitter headers/JJ RTP/Greddy Exhaust/Aeromotive FPR/Walbro 190/Fidanza FW/Clutchmasters Stg 3/Tokico Illuminas/Eibach Springs/Kosei K1 15lb wheels/gutted from front seats back-177whp 159ft/lbs SAE corrected stock ecu, N20 to come
