Go Back   ProbeTalk.com Forums > Photography, Video, Photoshop > The Photo and Video Gallery
The Photo and Video Gallery Have a TASTEFUL funny pic or non-probe video, or just want to show off your good looks? Put it here!
Old February 1st, 2016, 07:10 PM   #26
dillinr
Seems relevant...
Ryan
'94 Mazda MX6 V-6
SMF Prep:
Old February 2nd, 2016, 07:19 PM   #27
artsvetkov
Got civic header
It became good source of 304SS bends for my intake manifold
-sold,
12" brakes, ZE, T3/T4 turbo, 2.5" exhaust , ACT 6-puck, MSD6AL+2step, Coilovers, 245/45/17x9 cobra r, 67mm TB, MS II, traction bars, meth inj. and more.
artsvetkov is offline   Reply With Quote
Old February 4th, 2016, 09:59 PM   #28
josh95mx
Fits in there pretty nicely. Progress is looking good.
95' AWD Mazda MX3
AWD conversion, fully built 1.6 Turbo motor, workign on BP turbo motor.
josh95mx is offline   Reply With Quote
Old February 5th, 2016, 08:22 PM   #29
artsvetkov
So I ended up chopping of the flange and getting another one cut, I picked up a $400 Harbor Fright TIG for this project. It's been a while since I TIG welded, so nothing to write home about. I used a separate Nitrogen tank to purge the manifold on the inside(China skipped this step and that's why they are prone to crack).
I also angled down the manifold 10* to offset the engine tilt. This gave me better clearance to fuel lines(see green clips).
-sold,
Old February 11th, 2016, 10:58 AM   #30
artsvetkov
Word of caution, tilting manifold down 10* brought my compressor housing too close to the engine block and water pump coolant intake. I won't be rewelding the manifold, I will just move the turbo forward by fabing up an up pipe.
-sold,
Old February 12th, 2016, 07:23 PM   #31
bob k. mando
Seems relevant...
holy shit. aren't most rally cars 4WD? and the RX-8 spanked them? day-um.
bob k. mando is offline   Reply With Quote
Old February 12th, 2016, 07:24 PM   #32
yellow2point0
yellow2point0's Avatar
Art, this project is simply beautiful!
1995 Ford Probe GT, black - Garrett GT3076-R @ 11.2psi. ~321ish whp/303ish wtq @ 19-20○ ignition, DIYPNP MS2/extra, etc. -parted & junked
1995 Ford Probe GT, black - MS3-Pro Ultimate, bone stock-ish, daily driver)
yellow2point0 is offline   Reply With Quote
Old February 20th, 2016, 03:18 PM   #33
artsvetkov
New snail location.
-sold,
Old February 28th, 2016, 04:28 PM   #34
artsvetkov
Slow progress is better than no progress, up and down pipes are done.
-sold,
Old March 3rd, 2016, 07:50 PM   #35
artsvetkov
Working on pre weld fitment.
-sold,
Old March 4th, 2016, 07:28 AM   #36
plx92
Making it look easy! Nice work.
1992 Probe LX_Rust in Peace
1989 Probe GT_Weekend Warrior
2014 Fiesta ST_Lemon
2017 BRZ Premium_Daily
plx92 is offline   Reply With Quote
Old March 4th, 2016, 09:36 AM   #37
artsvetkov
For some reason I had hell of a time making pilot holes in stainless tube, ended up going through about 4 drill bits. Last one was cobalt bit, it dulled before making the first hole, I re sharpened it on a bench grinder(the best I could on 1/8" size), I must of put some special angle on it because it cut my 4 pilot holes like it was a mild steel.
-sold,
Old March 6th, 2016, 11:44 PM   #38
Dima_MX6
Nice progress.
The only thing I'm thinking... It'll be tough to replace that valve cover gasket once it's all done
Dima_MX6 is offline   Reply With Quote
Old March 7th, 2016, 10:14 PM   #39
artsvetkov
The whole engine will be rebuilt once I finish fabricating everything. With this layout, it won't take much to pull the engine forward for major maintenance.
-sold,
Old March 11th, 2016, 10:34 PM   #40
artsvetkov
Got intake tacked up and ran out of purging gas, it's almost done just gotta fit the injector bosses.
-sold,
Old April 6th, 2016, 04:24 PM   #41
usiel123
Omg. I have a heart-on!!
96 pgt 15000mls on rebuilt, kl31cams, ebay sts, 9lb flywheel,16mm 626 sway bar, stage 2 clutch, chrome 5 stars, Ground Control coilovers on Illuminas, OEM mudflaps, window sealer mtr mnts. 17" XXR 962's.
usiel123 is offline   Reply With Quote
Old April 9th, 2016, 12:42 AM   #42
artsvetkov
Got a boat, it's 1988 Bayliner with ford 2.3( looks like I will be adding turbo set up from 80's turbo coupe this upcoming winter). Weather been really nice past few days, so looks like there won't be much weekend progress on RX-8.
-sold,
Old April 30th, 2016, 11:29 PM   #43
artsvetkov
Made steering rack relocation brackets
Also welded in injector bungs.
-sold,
Old May 2nd, 2016, 07:09 PM   #44
njintau_fsd
Damn that is excellent work?
Judging by your welding and fab work, I'm guessing you're an engineer? Or a certified tech at least?
Either way, I'm liking your designs for the exhaust and intake manifolds!
njintau_fsd is offline   Reply With Quote
Old May 2nd, 2016, 10:01 PM   #45
artsvetkov
Yeah I'm an engineer, grinder and paint makes me welder I ain't. welding stainless is more like welding Titanium, If I knew that I will be getting TIG for this project(I was planning to get by with my MIG) I would of went with Aluminum on the intake manifold.
-sold,
Old May 22nd, 2016, 08:22 AM   #46
artsvetkov
Looks like the server went down last night and lost my update. Long story short, I extended steering shaft 1-3/4" to compensate for the rack relocation. I used 7/8" .120 wall DOM tubing.
V groves increase the surface area for the weld.
-sold,
Old May 24th, 2016, 08:23 PM   #47
artsvetkov
I got the sway bar mounted, I used coupling nuts to extend the studs.
This is a crappy picture, but you can see the coupling nut on it. Later I will size a spacer for the stud that way my square tube won't buckle when I tighten the nuts.
-sold,
Old June 7th, 2016, 12:53 PM   #48
Probesport
20 years of Probin'
Probesport's Avatar
You have my interest.
| 2005 VW Touareg V8
Probesport is offline   Reply With Quote
Old June 7th, 2016, 03:18 PM   #49
M0rphine117
wow...just gorgeous...
M0rphine117 is offline   Reply With Quote
Old June 10th, 2016, 09:08 PM   #50
artsvetkov
Got FMIC mounted today.
I also test fitted the radiator
Lower outlet is too close to the steering rack, so I will have to extend lower rad brackets about 5/8".
-sold,
[IMG] code is On
New build B-Ball Probe Lounge 2 August 19th, 2011 07:20 PM
PC's? I can build those too. j-dogg The Photo and Video Gallery 13 January 4th, 2010 06:12 PM
my possible build s3xrapt0r 2nd Gen (93-97) I4 2.0L Performance 17 September 30th, 2009 07:43 AM
To re-build...or not to re-build...hmmmm harrison987 2nd Gen (93-97) V6 2.5L 2 June 16th, 2004 02:56 PM
