Better not be Crusty you're cutting up, or we're through >:o
oh, we're most definitely still on
I cut the rear quarter panels off of the probe since I had always wondered what the paint cracking on the passenger side was from... I had ideas but was told that it was just clearcoat cracking (which I knew wasn't true once I wetsanded through it)...
Here you can see what I discovered when I cut through the paint... yep... BONDO! Its over a large area of the panel and not put on correctly. The bondo was cracking and it went all the way through the paint!.
