deposit sent
Stainless Door Sills Bulk Buy!!!
This topic is closed.
Bulk Buy Item(s):
Brushed Stainless Door Sills for 1993-1997 Probes
Includes all mounting hardware
I'm interrested but can you tell me if you go to test it on your car for be sure it fit perfectly? Because I have a set of PRD and another of Mbx door sill I don't install because he don't fit perfectly, it was not the perfect angle the threshold. I can send you a pictures with the problem of them if do you want.1993 Ford Probe GT
1997 Ford Probe GT [SOLD]
Black PGT '93 MTX: [Hotshot CAI][CenterForce DF][Mx-3 Flyweel][MBX Dual Feed FPR][Red PRD Wires][P&P IM][F & R Polish Valve Cover][67mm TB][Insert Mounts RR-Racing][FD Strut Bar][Custom B-Pillar Bar][Custom Tranny Saver Red Powdercoated][Tokico HP Struts][DZ Springs][Chrome Wheels][Gauges AutoMeter C2 & Cobalt][Clear Corner][PRD Fan Shroud][Kenwood eXcelon & Rockford Fosgate Sound System w/ Kicker Components]
the mounting hardware will be "spread clips" used in the factory peice's circle alignment holes, and will use SS allen head bolts to fasten into them. There will also be foam tape or something similar on the bottom to "cushion" them and prevent rattling
there will be 2 holes in the pieces, but not in the location of the ones in the pic95 mx6 with a 4 lug swap
Built, Not Bought.
okay, deposit sent!1993 Ford Probe GT
i can only speak on mx6s really, but stainless sills vs plastic ones really stand out and make it seem more high dollar. awesome its being done!!Turbo'd 94 Mx6 12.87 @ 115 on 5 psi.
Built by Me, eBay and zip ties.
96 White M-Edition mx6 Being built with above's parts, just less tip ties and sketchyness.
