I had the joy of taking my transmission out today to change the clutch, flywheel, pressure plate and rear main seal today. I used Travis' guide to do it. Everything is going smoothly so far, but...
When I pulled the drain plug out of the transmission no fluid came out , I knew that it had fluid in it because I had just checked it last week. So I looked into the hole where the plug came out of and there is piece of metal sitting there, I pushed it over with my finger and the oil drained out just fine, no metal shavings or anything in it. But the piece of metal is large enough that it won't come out the drain hole. I don't want to reassemble the engine/tranny without removing it. Before my clutch went out it never grinded when shifting into any of the gears. And when the clutch went out the other day, the pedal stuck to the floor... no breaking noises or anything, it was just the throwout bearing.
So, if anyone has any advice on dissassembling the transmission so I can get access to right above the drain plug, please let me know...
Oh and btw i'm replacing the stock parts with a Stage 1 Exedy clutch and pressure plate, and a flywheel out of the 1.8L v6 MX-3. vroom vroom
*Edit* Sorry forgot to mention 1994 V6 LX model... I usually am on mazda626.net and i have that in my sig over there
Come on, I know someone out there has taken there transmission apart before... There is a whole thread in the performance section about changing out the gears in th tranny for one from the 323GTX or using performance kits to improve tranny reliability...
