Go Back   ProbeTalk.com Forums > Performance Section > 2nd Gen (93-97) V6 2.5L Performance
2nd Gen (93-97) V6 2.5L Performance Discussion of Performance topics for V6 2.5L
Old April 18th, 2017, 01:51 PM   #1
Jayblack94gt
WHERE ARE THE J-SPEC AND CHIPPED ECUs???
Hey Guys,
I just got a straight neck KLZE but I didn't realize how hard it would be to find a KL31 or KL36 ECU. I'm also having a hard time finding a chipped ECU (Probinator, Xtremethings ect). I was told to try the MAF swap, but I would prefer not to. I have an OBD1 car and don't want the CEL light.
Are any of these ECUs still available for purchase??? If not, what other options do I have in terms of making my KLZE perform correctly??
Jayblack94gt is offline   Reply With Quote
Old April 18th, 2017, 08:21 PM   #2
They are everywhere..... 10 years ago.
Brizzy is offline   Reply With Quote
Old April 18th, 2017, 08:24 PM   #3
ZE-Infused
yeah good luck finding them much anymore. Like you mentioned most go maf swap to get more out of the engine. Which is why I pick up the maf swap
95 PGT
07 MS6
ZE-Infused is offline   Reply With Quote
Old April 19th, 2017, 03:54 AM   #4
i used to make them but gave away all my prom burning equipment, ill see if i can find one for you.
Nitrous Oxide - 79' Yamaha QT50 'Yamahopper' 70cc, MLM pipe, VM18 carb, dual stage reeds etc.
Old April 19th, 2017, 08:27 AM   #5
poissonn
I think I still have a probinator chip laying around. You can have it if you want, but you'll have to remove and replace the one in your current ECU yourself or with the help of someone!
MX-6 DE-T // Parting out...
poissonn is offline   Reply With Quote
Old April 19th, 2017, 07:45 PM   #6
The ATX ecu whichever that one is (KL36?) will give you a CEL anyway. The MAF swap is the way to go. Make it plug and play and you can swap back and forth in minutes if you have to. It's nice to be able to check OBDII codes with a bluetooth scanner, monitor things, adjust others.
Old April 19th, 2017, 07:51 PM   #7
reuben_johnston
reuben_johnston's Avatar
If someone can send me the binary and the flash part number, I have prom burning equipment at work. But, you'll be on your own with the soldering, which will be a good learning experience for you.
REub
1996 mazda mx6 m edition
reuben_johnston is offline   Reply With Quote
Old April 22nd, 2017, 02:18 PM   #8
mazda-head
I have a KL31 chipped KL01 ecu hanging around. Works perfect on 93-94 with the two coolant sensors.
95' 323C 'Neo' V6 BA23
stock KLZE/retuned VRIS0/deleted VRIS1/retuned VRIS2/MX3 rear suspension/0.680 5th gear/3deg retard cam timing/manual TBT
mazda-head is offline   Reply With Quote
Old April 23rd, 2017, 09:59 PM   #9
J_Unit
I can't vouch for these guys or anything but they advertise a lot of cool KL stuff. http://www.xtremethings.com/Products.htm Looks like they sell some ECU stuff. I see you mentioned them above, not sure if they are sold out or what.
J_Unit is offline   Reply With Quote
Old April 24th, 2017, 04:28 PM   #10
As has been said... MAF swap
proboner is offline   Reply With Quote
Old April 25th, 2017, 10:06 AM   #11
Jayblack94gt
^^^ Yep, did a bunch of research and I'm convinced the MAF swap is the way to go. Talking to Pile Of Rd 1 now!
Old April 25th, 2017, 11:09 AM   #12
Probesport
20 years of Probin'
Probesport's Avatar
With PnP Megasquirts available, it's hard to recommend anything else. Have you looked into that at all?
Chrome wheeled, fuel injected, and steppin out over the line
PRD - The original Ford Probe Aftermarket, THANK YOU FOR THE GOOD RUN
1999-2013 : 14 Years of supporting the Probe community
| 2005 VW Touareg V8
Probesport is offline   Reply With Quote
WTB: Chipped ECU (or j-spec) for straight neck ZE Stugotz006 Wanted 5 May 17th, 2011 11:24 AM
GT 89 chipped ECU Man/ and 90/92 Auto GT CHIPPED ECU mx6t_ant PT Member Sales 3 June 26th, 2003 02:11 PM
Are 96 ECUs and 97 ECUs the same ?? 97pGT 2nd Gen (93-97) V6 2.5L 2 June 20th, 2002 09:19 AM
Selling 89 and 92 GT ECUs - great for upgrading with no downtime DAskren PT Member Sales 6 February 11th, 2002 06:58 AM
