PLEASE LIMIT THIS THREAD TO TRANSACTIONS TO BE COMPLETED AT MSD!!
ALL OTHER FOR SALE ITEMS NEED TO GO IN THE FOR SALE FORUM.
Thanks!
KevinD
I've got a bunch of stuff left over from the Probe that I'm wanting to get rid of... This is just a preliminary list; I'll add more stuff as I find it.
Prices are negotiable. I've listed these prices as an idea of what I'm looking for, also in accordance with PT selling policy.
If you see an item you are interested it, let me know. If I don't see any interest in some items, especially the larger ones, I won't bring them. With the price of gas as high as it is, I'm not going to pack along any extra stuff if I don't think I will sell it.
1 set (front and rear) of KLZE heads. They DO NOT come with KLZE cams, those were sold with the car. 1 head is fully assembled, the other is disassembled, but I will include the tools ($60 Craftsman Valve Spring Compressor) needed to reassemble (it isn't hard). I wouldn't personally recommend planning on just dropping these on the car w/no work done to them. I'd plan on replacing the valve seals, lapping the valves, having the deck machined flat and having them cleaned. I recommend this for any used heads before installing. - $220
1 brand new RR-Racing Short Throw Shifter. This is simply the best shifter you can get for these cars, period. This is the new design, so the area where the shift knob screws on is reinforced. Doesn't come with the stabilizer bushing. - $110
1 KLDE Intake Manifold. The casting marks have been smoothed down and the IM is painted black. The paint is a damaged near the rear of the main plenum. Most of the hard work to make this thing pretty is already done, just needs repainted. Includes VRIS actuators and the vac reservoirs, does NOT include fuel rails or TB - $40
1 KLDE Throttle Body. Stock. Comes with the IAC but w/o the TPS. $20
2 full sets of KLDE/KL01 cams (4 intake 4 exhaust). All are in good shape, no rust or damage. Good for a core if you are looking to get some reground cams. $40 per set
1 Stock air box w/K&N drop in air filter. $20
1 Front strut tower bar. Not sure what brand (was a gift) but it does the job. $25
2 Front Lower Control Arms. Used OE parts with about 90k miles on them. I replaced them because I thought they might be causing my wheel hop, but they weren't the problem. They are still in great shape. Bushings look good, ball joints are tight. Good replacement for old, busted LCAs without spending a ton for brand new ones. $20 for both
2 Stock Axle back exhaust systems. One is from a 96 PGT one is from a 94 PGT, but they are both interchangeable. Both are in excellent shape, no rust, no holes. $20 each
1 Stock 96 PGT Exhaust midpipe. This is the pipe that runs from the catalytic convertor to the axle-back exhaust. This is a 96-specific part. In good shape, no rust or holes. $20
1 Stock 94 PGT Exhaust Midpipe. This will fit 93-94 PGTs. $20
1 Set of 96 Stock Exhaust Manifolds w/Y-pipe. These have been sitting for a few years but still look OK. The pre-cats have been gutted out, but this never caused a CEL for me. This is good for you CA guys with 96 GT with headers who need stock parts to pass emissions. $20
1 Set of REAR KF01 cams. 1 intake and 1 exhaust cam from the rear bank. Not sure what to do with these, but if anyone wants them, you can have them FREE
I'm also feeling for the possibility of selling my wheels. They are Exel Ennios, 18" diameter 8" wide with a +45mm offset. I had them on my Probe, then swapped them over to the 3 when I sold the Probe. They looked awesome on the Probe, and they fit perfectly. They will come with a set of BFGoodrich g-force T/A KDW tires, sized 235-40-18. These tires are amazing, dry or wet. They don't have alot of tread left, but they should last through the end of the summer. The wheels are wide enough to comfortably fit up to a 255mm wide tire, but you would probably need a 10mm spacer to run those tires. 245-35-18s should fit w/o any trouble. Here are some pics of them on my Probe:
http://www.supermotors.net/vehicles/.../10255/31805-4
The combo was $1200 brand new, I'm selling for $650.
Thanks for reading!
Thanks!
KevinD
Thanks for reading!
