Old February 28th, 2016, 10:48 PM   #1
Mike 99
Mike 99's Avatar
B20 Pistons for Low Compression Setup
I'm looking to upgrade with higher strength Millenia rods and lower compression pistons to allow more boost. Wiseco forged pistons are a good option, lots of great info already posted on Vitera pistons as a low cost option with somewhere around 8:1 comp. This little exercise is looking at readily available B20 pistons.
Others have pointed out that the B20 piston has the correct pin diameter for the Millenia rods, and I think there are members who have done this swap for NA. I have a question on the use of B20 pistons turbo pistons with Millenia Rods for a low compression setup. Pricier than the Vitera pistons, but perhaps less than custom pistons and may be available off-the-shelf.
The B20 pistons for this example - although there are several suppliers - are the Manley Platinum Series, forged 2618 alloy, with floating pins, a 11.9 cc dish, and 84.5 mm. The B20 pistons have a compression height of 30 mm (1.181") vs. stock KLDE pistons with a compression height of 29 mm (1.142") (or 28.75mm in some references, verification here would be great!!).
The Millenia rod specs I have pulled from old threads is 5.4' length, 21mm small ends, full-floating, versus 5.427-inch and 20mm for stock.
The deck height with stock KLDE rods and pistons is 0.013" (I think, not verified from a shop manual reference). Add 0.027" for the Millenia rods (5.427 - 5.4), then subtract 0.039" for the difference between the compression height of the B20 and KLDE pistons (1.181"-1.142") and the remaining deck height above the piston top is 0.001", or diddly squat.
KL03 head chamber volume is 39cc, stroke is 2.921". Compressed head gasket is 0.026". Plugging the all info for the KLDE/Millenia Rod/Manley B20 turbo piston into the Summit Racing compression calculator tool,
http://www.summitracing.com/expertad...ion-calculator
comes up with a grand total of 8.6:1 compression ratio, or a nice happy number for a turbo while not killing it when not on boost. For comparison, STIs run 8.2, Evos 8.8.
Putting it out there to see what the issues may and see if anyone else has taken this to the next step.
I will get the ball rolling with some of the obvious stuff:
- may create interference engine, valve relief for a B20 may be all wrong for a KL
- the 0.001" piston clearance from the deck seems sketchy.
- The connecting rod/KLDE piston compression height/deck height numbers above may be off
- the piston wrist pin offsets may be wrong
Thanks!
Mike 99 is offline   Reply With Quote
Old March 13th, 2016, 10:24 PM   #2
Mike 99
Mike 99's Avatar
OK, problems above, the Millenia rod length is same as stock, so this would require using 5.4" 347 stroker rods, but cost for rods and additional shims and machining goes up. Bummer. Also dug deeper on the compression heights, looks like slightly less difference from the KL to the Honda that the first cut (29.6 mm Honda - 28.9 mm KLDE, 0.7 mm or 0.028").
Soooo, deck height: 0.013" stock plus 0.026" from rod length change minus 0.28" for difference in compression height between Honda and Stock piston =0.011". OK in theory, but for the cost may as well go Wiseco or something similar. Or 8:1-ish with the Vitaras.
Ah well.
Old April 6th, 2016, 01:26 PM   #3
dammitcam
Custom piston sets for milli s rods are like 130 a piece roughly too sucks we dont have better aftermarket support
1995 Probe GT. Colt 218* cams, Tein SS Coilovers with EDFC, K6F trailing arms, CZT traction bars, ZE Intake Manifold, Milly MAF/OBDII swap, GReddy SP1, Probe Addiction Strut braces, RX8 Seats, PRD STS, PRD door sills, ACT 6puck
, MFactory LSD,Built trans, Euro tails and corners, Walbro 255, and more to come
dammitcam is offline   Reply With Quote
Old April 6th, 2016, 09:42 PM   #4
Mike 99
Mike 99's Avatar
Agree. I have been looking at another Suzuki option, but very little information available. The 2007-2009 SX-4 also had the J20, which (hard to verify) had a compression ratio of 10.5:1, up from the earlier engine 9.5:1 ratio. What is really unclear is whether this was from different heads or from a smaller dish piston. The part numbers for these pistons is different than the 2003 and earlier pistons, so it is possible this is how the compression change happened - if it did. Did I mention good specification data is hard to find? The 2007-2009 pistons are 84 mm stock, so 0.020" oversize (84.5mm) should be the ticket. The wrist pins are floating like the earlier models, and 21mm, so should fit my Milli rods. If the piston dish is the source of the higher CR, this piston may - possibly - result in a CR of somewhere between 8.5 and 9:1 with milli heads and KLDE heads, if there are no fatal flaws like sticking up above the deck.
2010 and later SX4's went to a VVT design called the J20b, same bore/stroke dimensions but many other changes and flat top pistons, maybe different deck height? Unlikely to be a go.
I did call an aftermarket manufacturer who makes pistons for the SX to see if they had specs available on dish volume and compression height but keep getting routed to a dead-end voicemail. Try, try again.
So my connecting rod upgrade is on hold for now, in any case I will wait until I tear down the engine - or build a different one - to see if I need to go another 0.020" over on the pistons if the block needs a bore.
Until then, I would be immensely grateful if anyone on PT who may have access to the 2007-2009 SX4 piston specs would check it out and pass the info on!
Old April 22nd, 2016, 06:49 AM   #5
KaedenKy
Electrical Engineer
KaedenKy's Avatar
You can always pray for a bulk buy.
I want to buy some pistons soon. I will approach the admins about it.
¡Renewed Vigor!
KaedenKy is offline   Reply With Quote
Old April 23rd, 2016, 01:00 PM   #6
Mike 99
Mike 99's Avatar
I will light a candle under the bulk buy shrine.
I did get half the info on the SX4 pistons using a secret squirrel phone number given to me by a distributor. Same compression height as the earlier J20 pistons. Listed specifications differences are compression ring widths are narrower on the SX4 and the pistons appear to have a coating/heat treat. No specs available from the manufacturer on the dish volume, so I would need to pony up and buy a set to get an answer. Given the low cost, I may do this. The pistons may be cast from the same mold used for the older J20 with different ring grooves cut, or may be a different casting. This was the problem with the J18 swap as pointed out by others here, the factory dish volume would have been ideal for the probe but the aftermarket sells just the J20 piston dish to save making a different casting, and factory (non-oversize) pistons are 84mm. No way to tell on the 2007-2009 SX4 aftermarket piston without getting my hands on one.
Old April 23rd, 2016, 03:17 PM   #7
I don't know how well people have investigated into Nippon racing pistons for Honda -but these look like a very good piston for the money and supposedly good to 600 hp:
http://www.ebay.com/itm/161564228393
85mm is .020 over for a KL if I am correct? That is just about perfect for an overbore rebuild without going too far.
KLZE Porsche is online now   Reply With Quote
Old April 23rd, 2016, 05:46 PM   #8
KaedenKy
Electrical Engineer
KaedenKy's Avatar
Last I spoke with Ross, they wanted around 800 for 6. They have measurements already, but still recommended I send them a sample.
Diamond wanted about a grand.
These Nippon Racing ones are about half that price. I'm just not brave enough to be the guinea pig.
¡Renewed Vigor!
Old April 24th, 2016, 02:49 AM   #9
Whitefinish
It's a 21mm pin, but a pressfit. Would that make any difference for using the millenium rods ?
Also; I don't fully understand their compression ratio.
85mm B16A BLOCK AND HEAD 11:1
85mm B18A/B BLOCK W/ PR3 HEAD 12.9:1
85mm B18A/B BLOCK W /P72 HEAD 13.1:1
85mm B20B/Z BLOCK W/ PR3 HEAD 12.9:1
85mm B20B/Z BLOCK W /P72 HEAD 13.1:1
85mm B18C BLOCK W/ PR3 HEAD 11.9:1
85mm B18C BLOCK W P72 HEAD 12.1:1
Mazda Mx3- Panther black, Kosei 18", custom hood, cleaned, new pakfeifer front, customized pakfeifer rear
KLZE highcompression, Pippercros Viper intake, kl31cams, MS1 v3, Aasco fly, CM st3 clutch, cai, ss headers, ground wirekit, srd bushings, msd window switches, nitrous
Whitefinish is offline   Reply With Quote
Old April 24th, 2016, 04:16 AM   #10
That information would be irrelevant to us. Those combinations are using different block and head combinations (varying head chamber volumes and block deck heights).
For us -the only thing that would matter would be the piston compression height -which isn't given. I have sent the seller a message to see if he/she can provide this information. But -yes the pin size is the same as Milli "S" rods.
OK -I did a little bit of investigation and the results are not set in stone. But in using Rock Auto to find compression heights on pistons from a Ford Probe and from a Honda CRV (B20B engine) -EngineTech brand gives compression heights. They gave 1.150" for the Probe and 1.165" for the B20B. This is a difference of .015 (shorter for our Probe). This might be able to be compensated for in head gasket thickness (if you can find a head gasket that is .015" thicker than stock). This can also be compensated with 5.400" rods and a minimal shave on the heads. I think there is potential here.
Old May 2nd, 2016, 05:41 AM   #11
KaedenKy
Electrical Engineer
KaedenKy's Avatar
Considering the price of custom, I am very interested.
¡Renewed Vigor!
Old May 2nd, 2016, 06:57 AM   #12
dammitcam
My main concern is that these pistons are designed for an inline engine, don't V engine pistons have to be made a certain way? I'm sort of a novice at building engines lol
Old May 2nd, 2016, 06:59 AM   #13
KaedenKy
Electrical Engineer
KaedenKy's Avatar
Not having the proper off set would affect longevity. You side load the piston more.
¡Renewed Vigor!
Old May 2nd, 2016, 08:06 AM   #14
dammitcam
I know there were issues with one build on here I forget the member but he had 2 of the same bank made, there was a VR6 build on audizine as well where they placed the pistons backwards lol. It really got me contemplating doing my own engine work haha
Old May 2nd, 2016, 10:33 AM   #15
I found out not too long ago -that piston offsets are not always used. I will have to check with the seller to find out.
Old May 2nd, 2016, 12:46 PM   #16
KaedenKy
Electrical Engineer
KaedenKy's Avatar
When I spoke to both ross and diamond, they said they by default sold with no off set. You had to specifically request it.
Until my rental house sells, about a year from now, I won't be buying anything custom. Mainly just parts hording till then.
¡Renewed Vigor!
Old May 2nd, 2016, 02:17 PM   #17
Whitefinish
What does it mean, the piston offset ?
Should 3 be produced with a center hole slightly to left, and 3 to the right?
Old May 2nd, 2016, 03:42 PM   #18
That is how it would be normally. Yes -the piston offset is the pin center displacement from the piston centerline.
Old May 3rd, 2016, 04:44 PM   #19
I got word back from the seller today and he said there is no offset -as I suspected. These look like a very good alternative to uber expensive custom pistons.
Old May 4th, 2016, 06:32 AM   #20
dammitcam
So what does this mean lol
Old May 4th, 2016, 09:44 AM   #21
Cheap heavy duty pistons with factory coatings and better than OEM KL rings. -->8 pistons with ceramic coating for under $500 delivered -or 6 custom pistons from brand XXX for near $1000!
Old May 4th, 2016, 10:48 AM   #22
dammitcam
I need brands and part numbers, so I can get some prices for us
Old May 4th, 2016, 11:50 PM   #23
SBPGT
Five Star Member
SBPGT's Avatar
$699 for the right pistons made for the KL.
No longer in business but some pat numbers and prices...
http://www.importperformanceparts.ne...ons_mazda.html
I would guess Wesico and Ross still can make our pistons, but they don't list them anymore. Maybe they'll do some bulk buys for us?
Currently buying all my parts for my future part-out thread...
STEVE B
2002 Mazda 626 ES
SBPGT is offline   Reply With Quote
Old May 5th, 2016, 05:56 AM   #24
dammitcam
From what it appears is that those are only sets of 3 pistons not 6 and uncoated with no rings :/ I priced them out through Wiseco and they said roughly 150$ for a single piston and the wrist pin retainer and something else was discontinued
Old May 5th, 2016, 06:02 AM   #25
dammitcam
Yes. From what everyone has said (I know you are an old timer in these parts and are aware) but it's best not to bore these engines
Looking for high compression pistons Piers14 2nd Gen (93-97) V6 2.5L Performance 13 October 2nd, 2007 05:26 PM
Low Compression pistons pageusaf 2nd Gen (93-97) V6 2.5L Performance 1 May 10th, 2006 03:47 PM
low compression pistons? SEyouLater 2nd Gen (93-97) I4 2.0L 10 March 8th, 2004 09:00 PM
FS: 10:1 compression pistons FRCFD6 PT Member Sales 0 June 9th, 2003 11:31 AM
