Old March 17th, 2017, 10:01 AM   #1
Venchman
Unhappy HEI, External Coil, and No Start
So I was driving along the hwy and the car lost power and died randomly. I had the car towed back. I thought the hei module was bad so I replaced that, still no start. I thought the coil was bad and I replaced that, still no start. Is it possible that my timing jumped on the hwy and that caused the car to shut off? Seems plausible but not likely. You guys have any ideas why the car won't start otherwise. Thanks for the help!
-V
93 GT-ZE, Hotshot Headers, Greddy SP2, Eibach lowering springs, Magnecor's 8.5mm competition wires, AWR Mounts, Spec Stage 1...
Venchman is offline   Reply With Quote
Old March 17th, 2017, 10:12 AM   #2
-V
Hey Venchei!
So do you have spark or not? If you do not have spark -it can still be the crank/cam sensor within the Distributor. Have you tried swapping the entire distributor? It is possible to be jumped cam timing if your hydraulic tensioner is not in prime shape and if it jumped more than one tooth. You should be able to determine that if you have spark or not. You can still get spark with jumped timing.
If no spark -there is also the possibility of a bad ECU. Have you double checked all of your HEI wiring connections?
Old March 17th, 2017, 10:25 AM   #3
Venchman
Hey Mike,
Yeh I remember the last time I had a no start it was the distributor crank/cam sensor but the car wasn't on the hwy running when that happened. Connections look solid, I'll check those and the timing. Might be that crank/cam sensor again
Old March 17th, 2017, 10:54 AM   #4
Hey Mike,
Check for spark first before you do anything else. That helps to narrow it down!
Old March 17th, 2017, 12:20 PM   #5
Venchman
I pulled the first spark plug and it has spark. On the first turn it sounded like it was about to start but continued to turn over.
Time to check the timing.
Old March 17th, 2017, 02:28 PM   #6
LowClassCC
Fazda Tuning
LowClassCC's Avatar
I have had 2 different Probes, both shortly after buying them, just up and die on me when I was driving out of the blue. Ended up being the timing belt both times. Good luck and keep us updated.
LowClassCC is offline   Reply With Quote
Old March 18th, 2017, 12:31 PM   #7
Venchman
So I've found out that the timing is correct and I have spark... I'm thinking my fuel pump or ecu is bad. What do you guys think? Here are some links:
Spark Verification
Right Bank
Left Bank
Crank
Old March 18th, 2017, 04:17 PM   #8
KLZEEscortGT
Well when you turn the key on, you should hear the fuel pump prime. Do you?
With a bad ecu I think you'll get a code zero
1995 Escort GT lowered, KLZE, CAI, long tubes, 2.5 inch exhaust, Fidanza fw, mx3 trans, and on ZEX
1996 Escort LX bagged, mx3 leather buckets, gt bumpers and skirts, 2.0l zetec swapped, cai, borla muffler, 3 yellow tops, Hornblasters train horn kit and a MASSIVE sound system
KLZEEscortGT is online now   Reply With Quote
Old March 18th, 2017, 05:11 PM   #9
Spark Verification
Right Bank
Left Bank
Crank
Next thing to do is to crank the car. Shut if off and immediately go to the fuel rail and crack one of the 17mm banjo bolts to see if you get some spray.
P.S. Don't do this in your garage with a kerosene space heater going
Old March 18th, 2017, 06:02 PM   #10
Venchman
Hahaha yeh that was an interesting experience... It's parked under a car port outside a friends house lol. Battery is dead so whenever someone returns I'll get a jump, start the car and see what happens but when I cracked the fuel rail barely any gas leaked out.
Update: No fuel coming to the fuel rail after cranking the car multiple times; moreover, I heard nothing from the fuel pump upon turning the key to the start position. So we may have solved the mystery gang!
Old March 20th, 2017, 01:17 PM   #11
J_Unit
You should be able to jump your diagnostic box if its a 93-95 to force the fuel pump to run. not sure about 96-97
J_Unit is online now   Reply With Quote
Old March 20th, 2017, 08:05 PM   #12
Venchman
Replaced the pump, still no action. Actually just tried this and I hear the relay clicking but the fuel lines are dry, so the new pump is not running, maybe I have a wire short but the gauge on the instrument panel is reading. Going to drop the tank again and check the connections. Am I missing anything?
Should've tested it while it was down... Yay, opportunities to learn!
Old March 20th, 2017, 10:20 PM   #13
Venchman
After taking the tank down. I recorded this. Tested the 'faulty' pump and turns out it works too. So definitely a short but I have no idea how to trace it and fix this problem.
Furthermore, I removed the pigtail and ran the same current through it to the pump and found that the pigtail worked just fine; this is truly a mystery. Also found that the enertia switch wiring was modified with two fuse lines as placeholders (they weren't blown). I have to be missing something. Not sure what though.
Old March 20th, 2017, 10:46 PM   #14
Brizzy
Time to hardwire a manual switch. Lol
1994 Project PGT
M62 In Progress...
Old March 21st, 2017, 02:16 PM   #15
branscoset
Does the fuel cutoff light come on the dash when cranking? If so the inertia switch or whatever is left of it is bad.
I've Been Probed.
Old March 21st, 2017, 03:00 PM   #16
93lazerpgt
I would be looking more into the inertia switch as well. Could just bypass it to verify that is the issue
93lazerpgt is offline   Reply With Quote
Old March 21st, 2017, 03:00 PM   #17
J_Unit
Just because the relay clicks doesn't necessarily mean its good. Might want to try another relay if you have a spare or if your daring you can try jumping it at the relay to see if that kicks the pump on. If that is still a no go, well I guess I would start taking interior trim off and folding the carpet up and tracing all the wires and making sure they aren't damaged physically.
Have you used a multimeter to test voltage at the pump?
Could also take a multimeter, put it in continuity mode/diode mode/voltage drop mode whatever you want to call it. The mode that beeps when you touch the multimeter probes together . touch whatever you have open on the ground wire coming into the pump and touch the other multimeter probe to bare metal. if it doesn't beep your ground is broke somewhere.
Old March 21st, 2017, 06:00 PM   #18
Venchman
Fuel cutout doesn't come on.
When I pulled back the trim I saw that a prior owner bypassed the inertia switch. So that's not it.
I have some spare relays laying around. I'll test that. I ran a twelve volt wire and ground from the aftermarket amp in the trunk and the car started just fine. Never used a multimeter. So I'd have to buy one and try that.
Old March 22nd, 2017, 12:06 AM   #19
Wavoz
To me it seems that your crank position sensor is bad, i had similar issue, fuel pump worked fine when running it in diagonstics box. The thing is your ECU wont start the fuel pump if it gets no signal from crank position sensor.
Wavoz is offline   Reply With Quote
Old March 22nd, 2017, 09:21 AM   #20
Venchman
I wouldn't get spark with a bad crank sensor, correct? I am getting spark and the motor starts (after rigging the pump to work).
New Issues: now the sputters and backfire/misfire/popping at around 3000 rpm; it completely losses power at that point. Would that be the coil failing? Here is a video of it. Seems like everything is going wrong at a really bad time.
Old March 22nd, 2017, 09:48 AM   #21
When you dropped the tank and swapped the pump -how did the filter sock look? The 3000 RPM problem can be a bad ECU. Maybe you just have a bad ECU altogether. Got a spare to try?
Old March 22nd, 2017, 10:02 AM   #22
Venchman
The sock/strainer was brown. I changed the pump and the sock/strainer. So they are both new. I should have a spare somewhere, need to look through some things. Do you have a multimeter I could borrow?
Update: changed the ecu and same stumbling problem. I'm going to make another video of it.
Old March 22nd, 2017, 06:34 PM   #23
93lazerpgt
Have you verified that you are getting the proper fuel pressure to the rail? Logic says new pump should have correct pressure but just a possibility.
Old March 23rd, 2017, 05:16 PM   #24
Venchman
I don't have a compression testing tool <- If that's what it's called lol....
Old March 24th, 2017, 12:57 PM   #25
J_Unit
No, your not testing for compression right now, just fuel pressure. You need something like this. http://www.harborfreight.com/fuel-in...ter-62623.html
help!!! all confused... HEI external coil still wont start? johnmx3ze Engine Electronics 14 March 16th, 2009 12:33 PM
External Coil and HEI MOD trmoser Arizona Probe Owners Club 1 January 20th, 2007 10:41 PM
HEI and External Coil on OBDII car won't start PaSwayDoe 2nd Gen (93-97) V6 2.5L 0 February 4th, 2005 07:40 PM
HEI mod, External coil and Code 3. Related? supergoat 2nd Gen (93-97) V6 2.5L 2 September 12th, 2004 02:44 PM
