Old March 19th, 2017, 02:34 PM   #1
PGT96er
96 Probe Premium Sound System RESTORATION
Hello everyone. I decided to take out my after market radio, amp, and 2 10's out of my Probe in order to go original. Why you may ask? because after market speakers have the back panels sticking out of place, and i'd like more trunk space.
Current progress:
I bought a matching cd player, and i located the stock amp in the right back panel.
The stock subwoofer harnass has a connection I can't recognize and
I connected the stock cd player in, but it is obviously underpowering the aftermarket pioneer speakers. (i will buy oem speakers on ebay)
THE CAR DID NOT COME WITH A STOCK EQUALIZER FROM WHAT I CAN TELL. IS IT NEEDED FOR EVERYTHING TO WORK?
PICTURES COMING SOON
PGT96er is offline   Reply With Quote
Old March 19th, 2017, 03:07 PM   #2
Depends on the HU you have. If the HU has a 6 pronged connector open on the back (red circle in the picture,) then it was meant to work with an EQ. You will need to wire up a connector for the EQ 93-94 were the only years to have them. 12v radio on, 12v for memory, lights, dimmer and ground. There's also a chassis ground to connect the HU to the EQ. If no 6 wire connector is there it should work normal.
http://i882.photobucket.com/albums/a.../headunit2.jpg
Old March 19th, 2017, 03:18 PM   #3
PGT96er
http://i1380.photobucket.com/albums/...psioyrjxwt.jpg
http://i1380.photobucket.com/albums/...psi00wvchi.jpg
http://i1380.photobucket.com/albums/...psoif1dfec.jpg
http://i1380.photobucket.com/albums/...psc5flqgf3.jpg
http://i1380.photobucket.com/albums/...pslratg6y8.jpg
Another mystery connection...for an equalizer? my car did not come stock with one.
http://i1380.photobucket.com/albums/...pswxkwikri.jpg
Mystery connection I can't figure out?
http://i1380.photobucket.com/albums/...psrdpf3vcx.jpg
Previous owner cut these wires to connect a cheapy head unit
http://i1380.photobucket.com/albums/...psia9pobeh.jpg
one of the wires connect
---------- Post added at 03:18 PM ---------- Previous post was at 03:15 PM ----------
This is the one I bought on ebay.. hopefully I didnt buy the wrong one. http://s1380.photobucket.com/user/PG...1dfec.jpg.html
Old March 19th, 2017, 03:26 PM   #4
I think that's the keyless entry programmer wire you have in your hand in the trunk, there should be another one there, a skinnier one for the sub sound. Also looks like you need an EQ, unless there's some other accessory I'm not aware of that can plug in there. You might be able to figure out a jumper to work around the EQ, basically trick the head unit into thinking the EQ is in defeat mode. It returns full sound control to the HU.
Old March 19th, 2017, 03:32 PM   #5
PGT96er
the smaller connection is already connected to the sub. that is the only connection for the sub, but there is also those weird wires the previous owner cut. one of them leads somewhere but the others I need to figure out.. perhaps an aftermarket wire harness?
also, i dont believe I have a keyless entry, because I looked next to the rear speaker by the amp and there is no device for one... ill check again
Old March 19th, 2017, 03:33 PM   #6
Neither of those 2 connectors in the dash are for the EQ. The EQ power connector has a red cap on the back. The 6 wire audio cable to HU-EQ can be found in other cars. In Mustangs with Tape HU and CD slave, and I've heard others back can't remember, the wire connects the opposite direction in the Probe. HU end in a Mustang goes into the EQ in a Probe.
Old March 19th, 2017, 03:39 PM   #7
PGT96er
well if anyone can verify what those blank connections are, maybe I can utilize them and buy what they are used for. I know most probes have the same wire harness but owner options varied
---------- Post added at 03:39 PM ---------- Previous post was at 03:36 PM ----------
My car did not come with equalizer, but has all the other stuff for premium sound. Did I buy the wrong HU? I figured it was for all years with the style HU
Old March 19th, 2017, 03:41 PM   #8
95 and up they started weeding out wires and cutting back options. EQ power wires won't be there. I don't know what those white plugs (in the dash) go to, I think both of mine are just hanging there. Which cut wire are you concerned with? There's a lot in the pictures.
Old March 19th, 2017, 03:42 PM   #9
PGT96er
this one http://i1380.photobucket.com/albums/...psrdpf3vcx.jpg
Old March 19th, 2017, 03:49 PM   #10
PGT96er
Also, I do not have the keyless option, so no need to worry about that.
http://s1380.photobucket.com/user/PG...pobeh.jpg.html
Old March 19th, 2017, 03:52 PM   #11
That looks like old aftermarket subwoofer power, remote turn on, maybe an earlier a/m sub setup. Maybe audio wires to or from an LOC (line out convertor for audio to RCA signal,) too. Does that connect to any of the premium stuff anywhere? I did see a set of gray wires hooked up near the amp I think.
Old March 19th, 2017, 03:57 PM   #12
Well if the harness is there for the keyless box, (in the hole with the stock 4 channel amp somewhere) then you might as well get a box and remote off someone or ebay. The fat plug I was talking about earlier gets shorted to program remotes. The gray wires could be the sub signal, see which color wires are spliced at the 4ch amp and look for a matching set by the sub amp.
Old March 19th, 2017, 05:44 PM   #13
PGT96er
orange connects to this fuse
http://i1380.photobucket.com/albums/...pszwlssgnp.jpg
red connects to this one and there is a cut yellow wire..
http://i1380.photobucket.com/albums/...pszv9380uv.jpg
All factory by the looks of it, which means the last owner cut the wire and tossed the connection for it.
That is a road block if its true, because I rarely see any GT's with premium sound options in the junkyard.
Old March 19th, 2017, 06:29 PM   #14
Both of those look like aftermarket wiring to me, the solid color looks like part store stuff. The wire coming out of the front of the fuse box is not normal, probably just hooked in under that fuse. Then the relay... from Nissan. It looks like exactly what I said, power and 12v switched to turn on an aftermarket amp or some other accessory. How about those gray wires? They are probably tapped into the factory sub source off the 4ch amp
Old March 19th, 2017, 06:57 PM   #15
PGT96er
i stand corrected, they are aftermarket
but the red one is the wrong one, i have to follow it again. ill be working on it for the next couple of hours and try to take more pics. thanks for helping me by the way.
Old March 19th, 2017, 07:46 PM   #16
No problem. I've installed a factory HU, EQ, and 4ch amp in a Chevy before. Ripped the wires and everything out of my 93 when it was wrecked. Same system ended up in a computer shell. Might get put into my 95. I've also modified an EQ to work with an aftermarket, stereo it was not the best sound, better with oe power levels. Started off not knowing what any wire went to and no schematic.
Old March 19th, 2017, 08:00 PM   #17
PGT96er
lol yeah, wires are a pain in the ass..
well i tested the connection and the factory amp is not receiving any power.
the amp itself could be bad or its not receiving power from another location.
Old March 19th, 2017, 08:09 PM   #18
There are 3 fuses for the factory sound system. Radio, room fuse and one other all in the inside fuse panel. Check there first. There'd be no need to cut the power wires to the amps to disable the factory amp, so it probably wasn't.
Old March 19th, 2017, 09:39 PM   #19
One more thing. If you're going to do all this work to get it back to stock, you should probably get rid of all the butt crimps and wire nuts. Solder, soldering iron (butane is what I use, no extension cord,) heat shrink and electrical tape. It'd be a waste if speakers start cutting in and out after everything.
Old March 19th, 2017, 10:09 PM   #20
PGT96er
yeah, it will be a perma fix.
didnt have time to check too many other things, and I have drive back 300 miles south to work soon. I only come home once a month so I am going to put all my aftermarket stuff back in. i am stationed at a fire center and don't have the luxury of my own garage.
thank you for the help. I will keep you posted and call some places if they can do it for me.
Old March 20th, 2017, 08:37 PM   #21
PGT96er
i believe one of the two stock amps are out. thats probably why the previous owner took out the stock head and put a aftermarket one.
of course newer HU have built in amps i believe.
Old March 21st, 2017, 10:12 AM   #22
Yes regular head units have built in amps. There is a remote turn on wire for the factory amps I believe, turns on the amps when the radio gets turned on. But, without an EQ plugged in that cd player probably won't be making a sound. You might get some clicks or hissing to let you know if the factory 4 channel amp turned on or not.
Old March 21st, 2017, 01:20 PM   #23
sbeube02
If your subwoofer amplifier is dead I might be interested in buying it for mock-up purpose.
sbeube02 is offline   Reply With Quote
Old June 25th, 2017, 02:50 PM   #24
PGT96er
Its been months i know, but did 96-97 GT's come with EQ?
---------- Post added at 02:50 PM ---------- Previous post was at 02:49 PM ----------
I am going to test it soon. There are still some on ebay though.
Old June 25th, 2017, 03:06 PM   #25
PGT96er
Does anyone have this wire in their probes? I can't figure out where it goes because it was cut. aftermarket ?
http://i.imgur.com/QzW8ckP.jpg http://i.imgur.com/AG5s8dl.jpg
Non-premium radio for originally premium car? JTJGVLE Car Audio And Electronics 2 June 23rd, 2014 10:44 PM
Bosch ultra-premium 2.0L ignition wires NEW $20 / Premium rear brake pads NEW $20 danieldepetro PT Member Sales 0 November 13th, 2005 02:00 PM
Premium CD in 93GT with non premium wiring PA_Probe Car Audio And Electronics 2 February 3rd, 2004 03:52 PM
Stock Premium Sound System upgrade. Some questions. Vitaly Stepantsov Car Audio And Electronics 9 April 6th, 2001 09:27 PM
1st gen premium sound system power. Vitaly Stepantsov Car Audio And Electronics 1 April 1st, 2001 07:11 PM
