King6 manual timing belt tensioner reviews please????
  • King6 manual timing belt tensioner reviews please????
    Hey everyone,
    Went to the dyno today in my street car, over a 150 mile drive.. Wanted to test out the new tri flow turbo cams with the race gas on a good tune.. Made 3 good passes, best run was 418hp and 429tq at 13.5 psi with 23 degrees timing.. Then on the 4th pass on the dyno at about 6500rpm i heard a huge BOOM noise lol, checked timing and the damn belt slipped on the rear head.. Engine seems to be fine but im pissed because i couldnt finish tuning.. So im wondering about the king6 manual tensioner.. Has anyone ever had any problems with them? Who all is running one now??
    http://www.supermotors.net/registry/20602
    http://www.supermotors.net/registry/20602/73905
    Can't speak for the king6 one, but I made one out of my blown out stocker. I just followed Travis Williams how to thread and it works great.
    1994 PGT MTX-CAI/STS/Hotshot headers/Vibrant catalytic/Pacesetter-Magnaflow catback/Outlaw spacers/RR inserts/Mazda6 brake upgrade/Yonaka coilovers/AWR trailing arms/AWR rear sway bar/PRD rear STB/95-97 rear end conversion.
    2006 Velocity Red Mica Mazdaspeed 6
      Have you ever had to re-tighten it?
        your motor should be fine cause the motor is non interference.
        95 PGT Current project
        95 PSE swapped in 93 KL...Headers.... K&N cold Air.... Gutted Caged and ready for Dirt
        01 Seabring Convert 01 Neon Rims With Spacers..
        99 Olds Cutlas DD
          I would stick with hydraulic.. I do NOT like the manual tensioners. Our motors need that hydraulic adjustment.. Because there are different points of slack/tension in the powerband.. The best way I can describe it..
          My opinion.
          1992 Mazda MX-3 GS - KLG4 Turbo
          Scott
            yea i use the originals i really havent had a problem with them yet!
            99 Olds Cutlas DD
              I put a king6 one on mine and it worked good. I did have to tighten it a bit after a couple hundred miles. The craftsmanship of it isnt the greatest but it does the job. The stock hydraulic one gave me issues with too much belt slack, but i did have interprep springs.
              02 Lexus Is 300
              06 GSX-R 600
              99 Monte Carlo
                i am moving this thread to this forum: Product Reviews.
                this is where things like this should be posted. it would also be great if the person whose product is being reviewed were actually a vendor here.
                Let's get DANGEROUS!
                  I've had interprep springs for a long while now, the higher lift cams probrably also had something to do with it lol. Anyone else care to share?
                    i also built my own out of a stocker.... very simple and very effective.
                    Turbo'd 94 Mx6 12.87 @ 115 on 5 psi.
                    Built by Me, eBay and zip ties.
                    96 White M-Edition mx6 Being built with above's parts, just less tip ties and sketchyness.
                      Thumbs up! No problems. Beefier than the home conversion. I think the quality is very good. Keep timing belt where it needs to be.
                      Note: I did not have to retighten...the jam nut works well....however, i am only running stock cams/springs...but I were to guess, I would have to say it would it would workk well with high lift cam springs.
                      Originally Posted by jasons96pgtze View Post
                      there tends to be a lot of genius people here on PT.. Thats why we own probes lol
                        How long have you been using it and how many miles have you put on the engine since installing it? The only reason I'm considering the king6 is because it says no modification is necessary. If I make one out of a stocker I gotta knock some excess material off the oil pump which I really don't wanna do right now. Anyone else here running the king6 tensioner??
