My battery is in the trunk as well, I did not check the voltage but would a long crank that sets that code prematurely make the car run like crap or possibly maybe it was set then once it picked it up it fired. 3 was not in the original codes pulled yesterday when it was taking forever to fire.
I will double check the battery voltage but it should be good and I know the connections are good since I believe I have a voltage drain somewhere so I disconnect the battery every time I let it sit for awhile. Batteries remain on maintainers.
