Originally posted by cheater1034
View Post
Bulk Buy: 1g & 2g UHMWP Shifter Slop Reducing Bushings
This topic is closed.
Got mine and installed them today! Good fitment, had to use a c-clamp to gently caress the bolt back in!
Any chance you'll make a set for the horizontal cylinder on the shift linkage near the trans? we'd have to drill/cut the pin out and use a bolt instead, but mine are obviously shot...BC Probe Owners Club is VERY MUCH ALIVE - www.bcpoc.ca
93 PGT 2.5L SILVER - Stock DE, ZE Intake Manifold, T3/T4 .50/.63 AR Turbo, Valant Turbo Pipes, Tial 38mm Wastegate (~9PSI), Custom Water/Meth Injection, Megasquirt v3 (MSnS-Extra 029q2 Fuel/Spark), Millennia Injectors @ 70psi, 65mm TB, JJ Resonated TP, Centerforce DF Clutch, MX3 Flywheel, AWR Mounts, it begins all over again...
93 PGT 2.5L BLACK Dismantled
GARAGE - The hybrid with a piston hole... lots of various leftovers...
Originally posted by Stevoh View PostHow many 1g sets do you have still?
Originally posted by Xplode View PostGot mine and installed them today! Good fitment, had to use a c-clamp to gently caress the bolt back in!
Any chance you'll make a set for the horizontal cylinder on the shift linkage near the trans? we'd have to drill/cut the pin out and use a bolt instead, but mine are obviously shot...Turbo'd 94 Mx6 12.87 @ 115 on 5 psi.
Built by Me, eBay and zip ties.
96 White M-Edition mx6 Being built with above's parts, just less tip ties and sketchyness.
Originally posted by Stevoh View PostGot the bushings. Thanks man, left you feedback as well.
I may have to pick up a set for my 1g. Let me know when you get the stock in.
i would love to see more first genners in on this..Turbo'd 94 Mx6 12.87 @ 115 on 5 psi.
Paypal Sent for 2nd gen combo
Thanks
KeithSensei blue PGT Turbo'd http://members.cardomain.com/kes16
Originally posted by hawaiianPGT View Postsecond gen combo pleaseOriginally posted by KES16 View PostPaypal Sent for 2nd gen combo
Thanks
KeithOriginally posted by troyfromkamilla View Postpaypal sent. again.
as of right now i have 5 complete 2g sets that will be shipping out as soon a stock arrives .Turbo'd 94 Mx6 12.87 @ 115 on 5 psi.
Originally posted by cf_z View PostThat is a thought i've had. I have been informed that on the mx3 this joint is already servicable, and it uses the same bushings as the transmission side. I may look into drilling mine out and making it just like the trans side mount.
If that's the case, maybe i'll put my old trans bushings in, because they weren't really that worn - turns out its these horizontal ones giving me the slop. Can you pm me with any notes/tips if you do it?BC Probe Owners Club is VERY MUCH ALIVE - www.bcpoc.ca
Originally posted by Xplode View PostIf that's the case, maybe i'll put my old trans bushings in, because they weren't really that worn - turns out its these horizontal ones giving me the slop. Can you pm me with any notes/tips if you do it?
basically the only details would be drill it out and turn it into a bolt/nut type joint just like the transmission. if you had a bolt the EXACT same size as the trans one, and the bore of that hole at that joint is the same (.5"), they they will work.
only information i have on this joint is that on the MX3 it is the exact same as the transmission bushings, and they are all serviceable.
maybe i'll look further into it in the summer. too much going on right now.Turbo'd 94 Mx6 12.87 @ 115 on 5 psi.
PayPal e-check cleared the other day, just wanting to confirm you got payment. Also, it looks like my address is not complete on PayPal. I sent you my complete addy via PM...did you receive it?
Thanks!
Jason
jwink25@msn.comSomething new coming soon!!!
1994 Probe GT...
Badass Probe build... Soon to be turbocharged http://forums.probetalk.com/showthread.php?t=1701254359 http://www.cardomain.com/ride/3865502
