ZE IM: Thread stripped on VIRS #2 rod. In the process of replacing, if required.
Power steering pump: Came with my ZE.
Other new engine related components and gasket kits available by request: (I can get most parts from the wholesaler including J Spec parts). Parts for other makes available as well.
External igniter replacement mod kit (as used on Pauls Ozeborp's car) by request. I assume Paul has had no problems with it?
Originally posted by KCV6 ZE IM: Thread stripped on VIRS #2 rod. In the process of replacing, if required.
Absolutely faultless operation Mark. I would recommend that solution to ignitor module problem without hesitation.
Cheers
Paul
PS. When I saw you on the road the other day I heard you before I saw you.
94PGT, Electric Blue, Adelaide, South Australia
CD Stacker | K&N Air Filter | Whiteline Rear Sway Bar
Ok, been thinking about swapping in the Aus or UK tail lights for some time now, and I've decided to go for it. I'd be willing to trade my US lights for either type, or possibly straight up pay for a set. If anyone happens to have a set they would like to trade or sell, please let me know! Or if you happen to be junkyarding and see a set, find out a price, add some on for yourself, and lemme know how much it would be, and mebbe we can work something out. Thank ya'!
2003 Ford F-350 Crew Cab 4x4 7.3L Powerstroke Diesel Dually
2001 Ford Excursion Limited 4x4 7.3L Powerstroke Diesel
I was just thinking that there is no use having 2 sets of K-Mac springs that I'm never gonna use in my garage. So if anyone's interested in buying a set let me know.
Set 1: These were the set that I ran in my car. They are supposed to be a 40mm drop, but they turned out to be around 45mm. These were AWESOME for cornering; I got almost no body roll through corners. I felt these to be a little stiff, but was probably due to the following as well as the spring itself:
- I had shock absorbers at the end of their life in the car, so it was a little bumpy.
- I have 18's so slightly stiffer springs and elastic bands comprimise comfort.
- There are a lot of crap roads around me. The suspension felt great on the freeway.
Set 2: These were a second set that K-Mac sent down after I told them the first set was a little too stiff for my liking. They have never been installed, and are softer than the first set due to thinner coils.
I recommend that anyone interested should:
- have the stock rims
- have reasonable good/new shocks.
If anyone's interested, let us know. If not, they'll just stay where they are.
Would anyone mind finding me some hvac controls out of a junk yard probe with wiring? If You'll find out for me I'll throw in an extra $15 after shipping for your efforts.
I am looking for a set of aussie tails to swap with my 95 GT lights. if anyone has any that would rock. or perhaps a local junkyard would have a set for cheap?
thanks alot,
DAN
Originally posted by lowerdfool Would anyone mind finding me some hvac controls out of a junk yard probe with wiring? If You'll find out for me I'll throw in an extra $15 after shipping for your efforts.
junked probes are really hard to find.. I've never actually seen one before...
