Anyone have a good pair of front wheel bearings i can buy at a reasonble price? had an issue with mine and everyone said to just have a shop press it! they cant put back together because its scared way to bad with a huge grove if anyone can sell me a pair at a good price of point me to the right direction that be awesome does the lx V6 Share the same hub? i know the na does not! any help is greatly apperciated!
Front Wheel Hub 89 probe GT
Ive had same issues that they get scarred too much to re use, i think the 2nd gen gt spindle might fit u would have to check the part number. As for the 1st gen lx v6 u can use the spindle part but not the whole hub tie rod or i think it was doesnt sit the same something like thatowner of
89 Probe GL - ran, broke down, ran, junked
89 Probe GT - ran,broke, never got fixed junked
89 Probe GT - the 1st probe replacement
92 mazda 323 - current daily, klde swap coming soon
the 2g hub will bolt on but the caster will be off because the balljoint location is straight inline with the strut on the 1g, the 2g has the balljoint offset...
the lx hub would work fine, it shared the larger spline count on the hub sideLast edited by pile_of_rd1; June 2, 2015, 03:04 AM.1992 Mazda MX-3 GS - KLG4 Turbo
Scott
I don't need the whole knuckle just the hub. So I shouldn't have to worry about tie rod placement right? Would the 2nd gen press into a first gen knuckle? I take it the lx will fine correct I figured the lx would work I've heard plenty of people say they split the case of the lx trans and put the 2.2 bell housing and use that trans for the gt turbo.
Good children yes!! how much and do you have 2? they both are bad? any info or help is greatly appreciated. i have a TON of back up parts but zero spindles or hubs if i have something you need we can trade or ill buy straight across it doesnt have abs idk if that matters for just the hub but do know they offer different axles for them! thanks so much
you need only hub with stud or complete assy with bearing in it ? i thing bearing are bad in it because they sit in garage for two year now. they are from an abs car but only difference are sensor in spindle and gear on axleFord Focus RS 2018 red race
Ford Escape XLT V6 2008
Mazda Mx6 GT 1991
Ford Focus RS 2017 nitrous blue (Dead in Fire)
