43 and 51 psi respectively.
A/F gauge install instructions W/pics
I just got my A/F ratio guage installed. Should have done it myself...but i didnt feel like it. Anyway, now when im at idle it reads Stoich, but as soon as I get to *half* throttle it goes fully RICH...to the very last bar and sits there. For a while now i thought I've been running rich but haven't had it checked out. Do you guys think that the reading is too extreme....or does that sound right for running rich? I dont have a check engine light and the ECU isnt throwing any codes. Also..if I'm stopped in drive....I'm lean according to the guage and if I turn my lights on/off I get very slight changes in the readings. I told the shop owner to run it from the ECU and faxed him info from probetalk on which wires to tap. It seems to me like he tapped the wrong wire.......any ideas?
<----------- 96 GT ATX96 GT MTX. Fidanza Flywheel. ClutchMasters Stage III. RR-Racing STS. RR-Racing Motor Mounts. 20% tint all around. Matrix H4 Headlights. PIAA 1900x Driving Lights. HotShot CAI. JJ Resonated TestPipe. GReddy Cat-back. 18" Konig Maxxim Conflict Rims. Bridgestone Potenza S-02s. Bomz FSTB. Tokico Illuminas. Eibach Springs. NOS 5115 kit w/ heater, purge, and remote opener. 50 shot. ~SOLD~
~~ 04 Rally Red Evo VIII ~~
286 whp / 290 wtq
www.putfile.com/dero
How would i splice this into my 97 ECU .. i recall Skelly saying its the Green with white strip in the middle harness on the ecu , But theres 4 harnesses on my ECU ??N.E.P.O-"The Rebel"
-2005 SRT-4 *305lb tq*
-1998 Neon Stock:
-1997 PGT Stacked:**SOLD**
95 atx ecu
Just to add a little clarity (MAYBE) I will post what it is on my car so you know what colors to use. Every car is different depending on the plant it was made at. But I have a 95 ATX ECU and the left side(rear) o2 snesor input is the dark blue w/ a white stripe located one from the right on the bottom row. The right hand or front o2 is the one right above it and its black w/ yellow stripe. Hope this helps someone out in the future. Since Fozda just stick with the same color in all the obd1 cars! JEEESH
FWIW: I just did an install of one of these on a '96 PGT. I tapped off the black wire (of the four wires on the 96's O2 sensors) from one of the front O2's. Seems to be working fine so far.Greg Martin
2009 BMW 328i
2017 BMW X3
1990 Probe LX
those pics aern't working could you send them to me via email? azichek@hotmail.com. I would like to hook my a/f via my ecu.
this thread is now making its way into the archives.1996 Boysenberry Probe GT MTXtreme
2014 Fusion SE MTXtreme
2005 Mountaineer Premier
