Go Back   ProbeTalk.com Forums > Tech Section > 1st Gen (89-92) All
1st Gen (89-92) All Discussion of Maint Issues for 1st Gen (all models)
Old June 18th, 2001, 01:00 PM   #1
sifilis
Does anybody know if the turbo boost gage on first generation GT's is an actual pressure gage, or is just run by the ECU? I'm asking this because I suspect I might have a crack, but the PSI indicator shows normal pressure.
sifilis is offline   Reply With Quote
Old June 18th, 2001, 02:48 PM   #2
Josh89PGT
The guage is highly inaccurate from what I've been told. I think it shows an estimate of boost rather than an actual pressure reading. Hope this helps ya out.
Josh89PGT is offline   Reply With Quote
Old June 18th, 2001, 07:13 PM   #3
FLAPOC-Pres
FLAPOC-Pres's Avatar
it works off pressure from factory boost controller.
FLAPOC-Pres is offline   Reply With Quote
Old June 18th, 2001, 08:25 PM   #4
Trickie
yea what the second one said....
Trickie is offline   Reply With Quote
Old June 19th, 2001, 06:20 AM   #5
sifilis
Thanks for the info. So then I can assume that whatever the guage reads is the actual pressure in the turbo, right? That is, if the controller is not shot, which I don't think.
