I completely agree on adjacent values needing to be close this was the major reason my car didn't idle smooth before. Sim 2 fire seems to be working great for me, because you have such large injectors sim might not be the best way to go. Glad you got it worked out!
megasquirt - post your tables/msq here
Last edited by stoker100; January 10, 2014, 08:41 PM.Supercharged - 94' PGT: ZE, MS2, W/M Injection, weight reduced, manual steering because weekend race car! mods and pics thread
Was getting very light pinging on 95octane
Now with half tank filled with 35% 95octane and 65% 98octane with no pinging at all.
Even with +2 advance for low load and + 1 for high boost.
85% of it is AUTO tuned by VE ANALYZE LIVE with EGO correction off
This is my final beta map tuned for 14psi with good idling and cruise all the way to 130kpa is ok.
Sub 1400rpm 90-100kpa area tuned excessively rich by VE ANALYZE LIVE for some reason.
need to adjust it manually later.
Anything over 130kpa runs excessively rich 11.3:1 to well below 10:1 AFR @ 200kpa
Even though it has 50% max authority and max change of 50 it isn't auto tuning much at all.
When AEM wideband gauge reads 16.xx:1 AFR in TunerStudio it will read 19.xx:1 AFR
When AEM gauge shows AFR 11.xx:1 to 15.xx:1 TunerStudio will read leaner by about 0.6:1
12v+ from cig lighter(power by key on)
Grounded to MS PNP sensor ground screw terminal(tried chasis grounding too with no success)
Seems like a EGO AFR display bug in TunerStudio otherwise auto tune wouldn't be able to reach my AFR targets so well.
Anyone else have this problem?
Its giving me hell since the day I installed MS >.<! really need to sort this out.Last edited by sleepinglh; April 22, 2011, 01:39 AM.E85>KLZE MX-6 T3 Turbo, 1016cc/min injectors, Water to Air IC, 9lbs SPEC flywheel, Synapse 40mm wastegate, FuelLab AFPR, ACT 6puck sprung clutch, NGK AFX POWERDEX, Walbro 255 FP, Decat, No BOV, IAT MOD, King6 Poly Engine mountsMS 100% PNP from StratifiedAuto + J&S Safeguard Interceptor, rolling on 235-7x17" http://a7.sphotos.ak.fbcdn.net/hphot...0_811905_n.jpg
Check the voltage on the AEM's analog out and make sure it matches the official specs for what it should be. Sometimes they're off by a half point or more.Matt at DIYAutoTune.com
Thanks but no luck... measured 2.34v@ 14.7:1 with O2 unplugged.
With O2 outside the exhaust cleaned then dipped in water which should lean it out to the max maybe 20:1? returned 4.23v on the multimeter.
AEM afr gauge read 15:1 = 16.xx:1
15.5 or more = 19.xx+ on laptop and the AFR gauge glows red non stop.
I've tried a lot of different voltage points but to me this seems like a TunerStudio display bug or something.E85>KLZE MX-6 T3 Turbo, 1016cc/min injectors, Water to Air IC, 9lbs SPEC flywheel, Synapse 40mm wastegate, FuelLab AFPR, ACT 6puck sprung clutch, NGK AFX POWERDEX, Walbro 255 FP, Decat, No BOV, IAT MOD, King6 Poly Engine mountsMS 100% PNP from StratifiedAuto + J&S Safeguard Interceptor, rolling on 235-7x17" http://a7.sphotos.ak.fbcdn.net/hphot...0_811905_n.jpg
Originally posted by sleepinglh View PostThanks but no luck... measured 2.34v@ 14.7:1 with O2 unplugged.
I've tried a lot of different voltage points but to me this seems like a TunerStudio display bug or something.Matt at DIYAutoTune.com
Ye, I tried that too but doing that just throws off 14.xx readings too which is more important for me.
forget it I'll just have to live with it lol.E85>KLZE MX-6 T3 Turbo, 1016cc/min injectors, Water to Air IC, 9lbs SPEC flywheel, Synapse 40mm wastegate, FuelLab AFPR, ACT 6puck sprung clutch, NGK AFX POWERDEX, Walbro 255 FP, Decat, No BOV, IAT MOD, King6 Poly Engine mountsMS 100% PNP from StratifiedAuto + J&S Safeguard Interceptor, rolling on 235-7x17" http://a7.sphotos.ak.fbcdn.net/hphot...0_811905_n.jpg
Originally posted by sleepinglh View PostYe, I tried that too but doing that just throws off 14.xx readings too which is more important for me.
-JustinNEMESIS BUILT 2.7l KL, Precision T-66 Turbo, Eagle Rods, Ross Pistons 10:1 Ported G4 Solid Lifter Heads Colt Turbo Tri-Flow Race Cams, GM LS2 smart coils, MS3X RSX Leather... SOHC MY DOHC
for anyone who cares...here are my new spark and AFR tables. I managed to get 22mpg city driving mostly, with some boost pulls here and there. I think it's getting good mileage for its age, and considering it is getting pretty cold here so the warmup enrichment down low are not correctly tune for now so it's running pretty rich on startup:
That's on 91 octane fuel btw and the 13.8 in the low rpm/low load AFR is a typo..supposed to be 13.4 like the others aroundLast edited by poissonn; October 27, 2011, 04:39 PM.MX-6 DE-T // Parting out...
thanks for sharing, reminds me a lot has changed on my tune i should repost my maps too.Supercharged - 94' PGT: ZE, MS2, W/M Injection, weight reduced, manual steering because weekend race car! mods and pics thread
Progression of my tunes for the past 2 months
9.2c/r
mild port
550cc injectors
60mm turbo
Meth injection
Last edited by mac1; November 20, 2011, 02:23 PM.1993 Mercury tRacer :Vitara & mFactory: In progress 2020
2014 Factory Five 818s: sold
which engine is that for?
whats the compression ratio?
on my stock internal ze 5krpm-7krpm anything more than *35 @ 65kpa -100kpa will ping AFR @ 13.xx-12.xx
4krpm+ 3psi anything more than *23 will ping AFR@11.xx
4krpm+ 5psi anything more than *21 will ping AFR @ 10.xx
3krpm 3psi anything over *26 will ping slightly AFR@ 11.xx
J&S safeguard seems to pickup nicely after tuning the sensitivity with timing fixed on *10, the mic output is useless as all I hear is the valvetrain ticking away.E85>KLZE MX-6 T3 Turbo, 1016cc/min injectors, Water to Air IC, 9lbs SPEC flywheel, Synapse 40mm wastegate, FuelLab AFPR, ACT 6puck sprung clutch, NGK AFX POWERDEX, Walbro 255 FP, Decat, No BOV, IAT MOD, King6 Poly Engine mountsMS 100% PNP from StratifiedAuto + J&S Safeguard Interceptor, rolling on 235-7x17" http://a7.sphotos.ak.fbcdn.net/hphot...0_811905_n.jpg
my bad..............updating. YOu notice one person who's not in this thread? Westpalm, what aLast edited by mac1; November 20, 2011, 02:25 PM.1993 Mercury tRacer :Vitara & mFactory: In progress 2020
J&S safeguard seems to pickup nicely after tuning the sensitivity with timing fixed on *10, the mic output is useless as all I hear is the valvetrain ticking away.1993 Mercury tRacer :Vitara & mFactory: In progress 2020
I fix timing to 10* in MS ignition settings and do some runs @ 7krpm.
max out the J&S sensitivity and dial it down until only 1LED lights up then set MS to use your usual spark map instead of fixed timing @ 10*
After that I just assume aggressive LED light up are detonation.
Logically its working since the only difference is the timing to make the LEDs light up like a xmas tree.
And one other thing that I observed is that the LED will light up a little more when fully warmed up+ hotter IAT.
cold start+ full boost doesn't light up.
lucky you >.< kind of miss my big turbo. with my little t3 t just pulls progressively with no boost hit.Last edited by sleepinglh; November 20, 2011, 02:46 PM.E85>KLZE MX-6 T3 Turbo, 1016cc/min injectors, Water to Air IC, 9lbs SPEC flywheel, Synapse 40mm wastegate, FuelLab AFPR, ACT 6puck sprung clutch, NGK AFX POWERDEX, Walbro 255 FP, Decat, No BOV, IAT MOD, King6 Poly Engine mountsMS 100% PNP from StratifiedAuto + J&S Safeguard Interceptor, rolling on 235-7x17" http://a7.sphotos.ak.fbcdn.net/hphot...0_811905_n.jpg
Originally posted by mac1 View Postmy bad..............updating. YOu notice one person who's not in this thread? Westpalm, what a
I ask for advice and his old tune but told me Shaodome took care of everything.
But I was never able to get in touch with him PM or powersquirt EMAIL.E85>KLZE MX-6 T3 Turbo, 1016cc/min injectors, Water to Air IC, 9lbs SPEC flywheel, Synapse 40mm wastegate, FuelLab AFPR, ACT 6puck sprung clutch, NGK AFX POWERDEX, Walbro 255 FP, Decat, No BOV, IAT MOD, King6 Poly Engine mountsMS 100% PNP from StratifiedAuto + J&S Safeguard Interceptor, rolling on 235-7x17" http://a7.sphotos.ak.fbcdn.net/hphot...0_811905_n.jpg
