Go Back   ProbeTalk.com Forums > Performance Section > Forced Induction (Turbo/S.C.) > Forced Induction - Archive
Forced Induction - Archive Here you will find the BEST information!
Old February 12th, 2002, 01:40 AM   #1
krisw
Balls Across The Nose
Detonation and Preignition FYI
ok, so im wondering which of these 2 explanations is correct in describing what detonation is. is detonation when the air/fuel mixture gets so compressed and hot that it detonates BEFORE the spark plug goes off? or is detonation when a small pocket of air/fuel spontaneously combusts after the spark plug has been set off but has not completed its burn? the reason why im asking is because in Supercharged! by corky bell, he talks about how having an intercooler will cool the compressed air going into the cylendar and make it less likely to detonate. this would lead me to believe that detonation would be the first explanation. in which case if you ran nitrous while supercharging it would lower the cylendar temperature considerably, and thus reduce chance of detonation. i hope this makes sense.
krisw is offline   Reply With Quote
Old February 12th, 2002, 09:42 AM   #2
BryanPendleton
PT Know it All
BryanPendleton's Avatar
It is my understanding that they are both detonation. You also have pre-ignition. There is a very very fine line between the two. Detonation is described as the fuel combusting from the heat and pressure of the combustion chamber. This could could occur before or after the spark, it doesn't matter. Pre-ignition is describes as an alternate source igniting the fuel, such as a hot spot in the combustion chamber, or a sharp edge on a piston valve relief. Again this could occur before or after ignition. This is my understanding. I may be wrong.
The bottom line is you have uncontrolled combustion occuring in the combustion chamber. Whether before or after the spark you have flame fronts that will collide or a combustion that get highly compressed because it occurs so early, and the result is extreme stress on the engine components, that will quickly make alloy stew of your motor.
Bryan Pendleton |
BryanPendleton is offline   Reply With Quote
Old February 12th, 2002, 10:37 AM   #3
ASword
Yes, both types of problems will occur and are generally referred to as detonation. The two problems are quite different, however, and have different solutions. Corky has a bit of a discussion of both in his other book, IIRC.
Former PGT-turbo owner... now 2010 VW Golf TDI
ASword is offline   Reply With Quote
Old February 12th, 2002, 12:45 PM   #4
TXTalon
Corky Bell works for ME
Knock and detonation are one in the same. The actual sound of knock is the pressure waves beating the schnizz out of the inside of the cylinder, piston, and valves. Hence, if you hear knock, there are already bad things going on inside the cylinders. I have pictures somewhere of a 4G63 that literally shot 2 rods out of the bottom of the oil pan from it and bent the other two
Pre-ignition is caused by hotspots (which can also be a plug tip that stays too hot), as was said, and is basically the same as too much timing advance. It's basically still a smooth flame front that may or may not have waves in opposition to the regular spark ignition.
Detonation is actually ignition without any help from hotspots or spark plugs (auto-ignition..and that's the problem). It's an unsmooth, uncontrolled explosion (hence "detonate")....not a "burn"...and is pretty much guaranteed to have contradicting pressure waves .
Detonation is only "worse" because of the huge, rapid increase in cylinder temperatures and omni-directional pressure waves. You end up with pressure waves going it all kinds of directions and even against the plug-ignited flame front causing a collision and super-high cylinder pressures/temps.
As if that weren't bad enough, with both pre/auto ignition, you have combustion out of sync with the crank rotation. Imagine having that super high combustion when the piston is on its upward movement. The combustion will try force the piston down like it normally would on the power stroke, but that's not going to happen. So you end up with a piston that's moving into the pressure wave and neither one wants to budge. With a bunch of pressure and no where to go in any direction, your parts are either strong enough to take the beating or they're not. If you have a weak spot, the pressure is going to find it...that's how you end up with holed pistons, cracked lands, burned valves, blown head gaskets, bent rods, etc.
As for nitrous, you're thinking is there, but it's not quite the whole picture. You have to remember that it will not only be cold, which will keep cylinder temps down, but you are adding oxygen and a more dense mixture, which needs matching fuel or you'll be super lean and cylinder temps will be through the roof. You will need to add the proper amount of fuel to maintain the ratio for that new air, so at best it will be a wash...and that's exactly how it's supposed to work.
The only easy ways to control cylinder temperatures is via mixture characteristics or timing. You could pump 10x more air than the stock engine normally uses and if you maintain the proper ratio of fuel for that air like you're supposed to, cylinder temps should not budge, even though the combustion is much larger (more power). If you run too little fuel for the air (leaner), the cylinder temps would increase, if you run more fuel for the same air, you run richer and cooler cylinder temps.
The other way to play with cylinder temps is to adjust timing. Retarding the timing will ignite it later, give you less of a complete burn and a resultingly weaker combustion (less power) and lower cylinder temps.
As you can see, it's all a matter of playing with the mixture itself or how completely the mixture is burned. If you get more into it, you can inject things like alcohol, water, or simply go with a higher octane fuel, which again, all change the mixture properties.
TXTalon is offline   Reply With Quote
Old February 12th, 2002, 03:00 PM   #5
TXTalon
Found some of the pics of the detonation results. If you have weak stomach, don't look. Looking at these pics is like getting kicked in the nellies :o
http://www.dsm-performance.com/images/detonation.jpg
This is one of the rods that came through the pan. As you can see, it shot out sideways no less. The wrist pin literally blew a hole in the pan and the small end of the rod tore a huge gash in it.
http://www.dsm-performance.com/images/detonation2.jpg
That's the gash from the rod. Through it, you can see big end of the rod is still attached to the crank. The shiny mess in the middle is where the rod snapped off.
http://www.dsm-performance.com/images/detonation3.jpg
This is the rod as pulled from the pan (first pic). The piston was truly "free floating" around the crankcase somewhere
Old February 12th, 2002, 05:35 PM   #6
TXTalon
I see where I was misreading you. I was thinking of it in terms of heat from combustion and not just overall temps.
Adding nitrous generally isn't thought of as a way to cool cylinder temps because it's not a full-time solution, but yes, given the temperature of nitrous, with the proper fuel, it will cool the intake air temps and that would have an impact on overall cylinder temps. That benefit would be multiplied if you were boosted w/o an intercooler. So, I'd have to say yes, with the proper fuel to cover the extra air in the cylinders, nitrous would have some cooling effect on cylinder temps (I have no idea how much), but as I said it's not really a feasible full-time solution.
Given the cost of refills, the duration a bottle will last and the extra fueling requirements, it's definitely not the way to keep cylinder temps cool(er) on a street car. On a track-only car, it's another story entirely. Some of the fastest cars run huge boost, non-IC'd with alcohol and nitrous for cooling (Abel Ibarra comes to mind) or intercooled w/ nitrous on gasoline.
For the street, get a FMIC to get compressed air temps as close to ambient as possible and then use fuel/timing tuning to keep cylinder temps in check....the tried and true, 24/7 "right" way to do it....and it's a hell of a lot cheaper that daily bottle refills in the long run
Old February 12th, 2002, 06:09 PM   #7
krisw
well if i ever did add nitrous onto my non-existant supercharger i would only be using it to add a little extra hp when at the track or in a really good race. i just wanted to make sure that it would be safe to do so. but now that i think about it, it could kinda work as a detonation deterrent all the time couldnt it? i mean when youre just driving around between 1500-3500 rpm its not like youre getting that much boost anyways. so you could set the boost so that when you get to like 5000 rpm its running a little higher boost than the point you get detonation at, and just always have your nitrous switch in the "on" position. so you should be getting detonation, but the nitrous would cool down the charge. i doubt that made much sense, but in my head it would work... not saying i would do it, like my engine a little too much.
Old February 12th, 2002, 07:55 PM   #8
TXTalon
Well, there are limits and that won't only be left up to tuning, but fuel characteristics as well (octane). You'll need to add fuel for boost whether you have nitrous or not. If you add nitrous, you'll need to add fuel for that on top of the fuel for boost. That's a LOT of gas. You may not think you'll be on it much now, but when my PGT was boosted, the pedal was on the mat....often
I definitely wouldn't call nitrous a "detonation deterent", far from it. I know a lot more people who have screwed their engines on nitrous than with boost. Combining the two will make tuning, and the ability to supply enough fuel, that much more crucial.
Retarding the timing, richening the mixture, running lower boost, increasing the octane, cooling the intake charge or any combo thereof are detonation deterents. They all lower cylinder temps and decrease the chance of knock. You've taken ONE aspect of those (lower IATs) and are looking for the most costly and difficult way to achieve it
If done properly, what you're talking about IS feasible and will cool temps to a point (still seriously doubt the benefit out-weighs the cost), but that's definitely not the most practical way to achieve the goal. For the price of a nitrous kit, you could have a FMIC, have ambient intake temps and not have to pay for refills. That, and a good A/F mixture under full boost and you're cylinder temps should be in real good shape without adding to the fuel demand.
Running two power adders is not for the meek. If you do look at those track cars that run boost/nitrous, you'll see all of them run huge injectors, sometimes 2/cylinder, have fuel pumps that will empty a swimming pool in 15 min., and don't care about MPG or need to pass emission tests.
Intercooling, proper fuel supply and management is all it takes. You're making it much more difficult and expensive than it needs to be. You would be much better served with a water injection kit if anything. It will drop temps, water is the ultimate anti-knock solution, and it won't increase the fuel demands any more than the little extra needed for the denser intake charge. It's freely refillable and most kits activate immediately on positive manifold pressure or at a set boost level.
Running nitrous with boost on an engine that will only hold 7-12psi seems ludicrous to me, especially for the still apparent lack of fuel supply parts and tuning ability. I think you'll have enough trouble getting and tuning good fuel for either one separately, let alone both together.
K.I.S.S. is by far the best philosphy...
Old February 12th, 2002, 11:25 PM   #9
ranta18
Corky's book gives a lot of good info on calculating the heat created by a supercharger and the heat from compressing the air. There is and equation to get that plus the normal heat from the compression ratio and you get your final cylinder temp. I figured out what mine is (can't remember off the top of my head), but what is safe and what is not? On 93 octane and factory timming, what temps are ok if you have a good A/F ratio (about 13.5:1)? Thats what I want to know.
Mike
Supercharged Probe GT
http://www.geocities.com/ranta18
ranta18 is offline   Reply With Quote
Old February 13th, 2002, 08:55 AM   #10
ASword
First of all, a good A/F ratio is 12.5:1 ... 13.5:1 is actually fairly lean, at least for running under boost. Also, all the graphs I've seen for power vs A/F ratio put peak power at 12.5:1.
Second, the detonation temperature of 92-94 octane gas is approximately 500-860oF. Yes, this is a very wide range -- that is because it depends on a lot of factors including quality of gas, how well it is injected, A/F mixture, etc. I got the figure from Howard Chu's turbocalc spreadsheet, and I think his source was gas company publications or something like that. Your mileage may vary (so to speak).
Old February 13th, 2002, 09:04 AM   #11
TXTalon
Ranta18--
Yeah, those calculations are available everywhere. They're probably pretty close in most respects, but bench racing is no sustitute for real world feedback (dyno/logging/gauges).
Most people don't measure cylinder temps per se, exhaust gas temp (EGT) is probably one of the most commonly used methods (which measures "cylinder temps" outside the cylinder . Mount the probe within a few inches of the leanest cylinder's exhaust port and go from there. "Safe" for me will be about 1400-1500°F on pump gas. On race gas, I'd let it peak about 1550-1600F right before the shift.
13.5:1 isn't what I would call a good A/F. It takes fuel to make power. If you're are running stock timing and it's not being pulled from the knock sensor with that A/F, I would be VERY surprised. A "lean" part of the curve on my car would be 12.0:1 and "rich" would be less than 11.5:1. If you're looking at it from an A/F gauge point of view (which isn't really the best feedback for tuning), that's going to be pretty much pegged the hell out.
Like I was saying in another thread, if you tune fuel for good timing, EGTs will almost always have to fall in line. If the EGTs get too high, it's most likely going to knock first, which you'll see on a datalogger. Richening up the mixture will combat knock and drop EGTs. Tuning fuel just rich enough to hold the maximum timing the ECU will give (or as close to that as you can) without knock is what you want to shoot for. If you get there and EGTs aren't insane (shouldn't be at all), that's the best you can hope for without additional timing control.
Old February 13th, 2002, 01:18 PM   #12
ranta18
Yeah, I ment 12:0:1 - 12.5:1. Thats what Corky's book says. It was late when I typed that. So safe temps on 93 octane with a 12.5:1 A/F ratio would be anything less than 850 deg F and EGT of anything less than 1500 deg F. That comes out to 1350 deg R absolute cylinder temp, which is about what Corky said is the safe limit, but I would have to look.
Mike
Old February 16th, 2002, 04:06 AM   #13
AusMX6
i had also heard that playing with the individual cams timing on ur twin cam changes temps alot aswell - espically on the exhaust cam on boosted engines.....which in turn also effects EGT's...i had also heard that an EGT of around 800 degrees is ideal for most turbo's...??
this sound right 2 others out there?
WAS: 1989 MX6 2.2 Turbo 4ws
NOW: FE3 MX6 - 2 Cams is better then 1.....much better!
AusMX6 is offline   Reply With Quote
Old April 23rd, 2002, 03:42 PM   #14
GET_PROBED
For the Probe....
To combat detonation.....
I know:
We can increase FP to almost injector static limit.
We can run cooler plugs.
We can buy bigger injectors.
We can decrease boost.
We can intercool.
Does octane booster really work or only true race gas?
Is there a way to retard timing on the stock ECU without MSD?
It sucks that we can be rich on our AF meter but still get detonation do to hotspots.
I AM A BOOT CAMP NON-BOOSTER ....but willing to learn!
GET_PROBED is offline   Reply With Quote
Old May 14th, 2002, 12:36 AM   #15
PGT#1
racing gas will fry your o2 sensors, and make your engine run rich.........which initally sounds like a good thing, more fuel is better for boost. I just dont like the idea of having my ECU not knowing o2 levels in a boosted engine, would just make me nervous. I dont think octane booster would be very reliable either. Since you just add a can into your gas tank, theres no way to assure that it will mix well, leaving you with a range of octanes. Which again, on a boosted engine, i wouldnt want.
PGT#1 is offline   Reply With Quote
Old May 14th, 2002, 02:03 PM   #16
FRCFD6
F/I *********
FRCFD6's Avatar
how will racegas make it run more rich ?......racegas has a much higher octane rating, wich means its less prone to self detonate as in regular gas. and the O2s are only used during regular driving, not when you race.
Life isn't like a bowl of cherries or peaches, it's more like a jar of Jalapenos ....
What you do today, might burn your ass tomorrow.
Pearl '92 Audi //S4 GT3071R, running 27 psi
Lava gray '14 Audi //SQ5, Chipwerke, 034 Intake Pipe
For PSP Awareness click
FRCFD6 is offline   Reply With Quote
Old May 14th, 2002, 10:35 PM   #17
PGT#1
i was saying that when you run race gas, it will burn out your 02 sensors, and since their burnt out, you ECU doesnt have imput from those sensors. So to make sure its sending enough fuel, it adds more fuel. This happened to me, i bought like 5 gallons of 118 race fuel, and after about a 50 miles of driving my check engine light came on. I had my friend run the ecu for fault codes and what came back was 02 02 02 02 02 02 02. It was runnin a little flat too after the light came on. I ran through the rest of the tank, put 93 back in, replaced the 02 sensors, light went away . Ive heard other stories similar to mine, i couldnt tell ya exactly WHY the race gas recks the 02 sensors, but apparently it does.
Old May 14th, 2002, 11:14 PM   #18
ASword
Running boost without O2 sensors isn't a concern -- the O2 sensors are only used to run closed loop which doesn't happen when you are on boost. If it was trying to use the O2 sensors then the mixture would be bouncing around 14.7:1 and you'd be way to lean to boost safely.
I'm not exactly sure why race gas is hard on O2 sensors, but I too have heard this before. Leaded gas will kill them too, I believe.
Old May 14th, 2002, 11:25 PM   #19
PGT#1
so what, do you just remove the o2 sensors? cut the cord? doesnt this send error codes and make the check engine light come on? Cause i know you want to remove the VRIS when you boost, or tie the valves open, but i wouldnt want to have that code on all the time.
Old May 15th, 2002, 10:29 PM   #20
PGT#1
oh i misunderstood what you said. I thought you meant that when you boost you cant use o2 cause it would affect the air/fuel ratio, but then it clicked lol. When your boosted the ecu doesnt need to do all the open/closed loop with the vris and everything cause theres already positive pressure from the boost, gotcha.
Old June 10th, 2002, 12:58 AM   #21
kecamb
i wanted to let some people in on what causes the unique situation that detonation brings about.
from demolitions i know about some explosives and flame fronts and a few basic things about common fuels and oxidizers.
from physics i know about bulk modulus and sound waves.
when the mixture is so dense and compressed it can transmit sound waves faster than flame fronts and the sound wave can be powerful enough to create combustion in many places at once.
as one or two people described, the pressure waves go in all directions because the concussion, or sound wave travels ahead of the flame front. this is how a car can detonate but not autoignite or preignite. the original flame front can be the intial source of the concussion, but it doesnt need to be. pretty much, the more dense the mix, the more likely it will combust with a sort of fixed wave source. say the source is the spark plug being too hot and preigniting, then before the flame front can even move a fraction of the distance across the cylinder the pressure wave ignites every available fuel and oxy. if this occurs before the tdc point it can be as seen, a bit of it after tdc and after ignition can actually increase power, but is usually so drastically bad for an engine only diesels ever want to hear that ping.
hope i didnt waste anyones time..
kecamb is offline   Reply With Quote
Old June 13th, 2002, 06:04 PM   #22
hyc GTS
hyc GTS's Avatar
Yes, I looked up the Material Safety Data Sheets for unleaded gasoline from Chevron, Mobil, Arco, and a couple other brands. They all had very different ranges, and different data for summer blend vs winter blend, etc. There's a wide variety. If you're really concerned about the quality of gasoline that you're using, you can find this stuff on the companys' web sites and compare for yourself.
Meanwhile, I've also found some data on combustion flame temperature, but I don't think I'm going to be taking any new stabs at computing the energy release...
-- Howard Chu
17x8" BBS RC/Leda 24-way adj. coilovers/
Big Brakes: Wilwood 4-piston calipers+12.2x1.25" rotors/RRE FSTB/Top-End Racing FW/MazdaSpeed-Quaife LSD/65mm TB/Autophysics CAI/Groundz/Bi-Xenon HID headlamps/Euro Clear-corners+amber LEDs/Blazer amber fogs/JVC KDMX3000+CHX1200/Pioneer 6x9s/BCT7 Scanner/etc...
hyc GTS is offline   Reply With Quote
Old June 27th, 2002, 11:59 PM   #23
clavier
I'm not sure I understand this statement.
I am very often in boost without being at WOT. The ECU won't go into open-loop until the TPS sees WOT, so I am in closed loop with boost from time to time.
JEFF ABRAMS
Tierbeaux Beewst:
ROTARY POWER!! 1.3 liter 2004 Mazda RX-8 GT
TURBOCHARGED & INTERCOOLED 1.8 liter 1997 Mazda Miata
TURBOCHARGED & INTERCOOLED 2.5 liter 1993 Mazda MX-3 GS <== SOLD
clavier is offline   Reply With Quote
Old June 28th, 2002, 11:25 AM   #24
ASword
I'm pretty sure that the ECU will also drop out of closed loop above a certain airflow (i.e. load)... for safety reasons.
Old December 12th, 2002, 12:50 PM   #25
HaddixRacing
O2 sensors are killed by Race gas because it is leaded. Lead coats the sensors and renders them useless, you can sometimes clean them and they come back to life, but usually they will malfunction. If you want to run race gas just pull out the 02's at the track and plug the holes with cut off bolts. Or leave them out all the time and run 02 simulators, since your 02's are only there for emissions and fuel consumption reasons, and most of you prolly don't care about that if you are boosting.
HaddixRacing is offline   Reply With Quote
