7 bolt vs 5 bolt flange??
  • 7 bolt vs 5 bolt flange??
    I am becoming a little more curious as to the specifics of my t3 turbine on my t3/t4 compressor. The bolt pattern is a 7 bolt pattern. A shop stated that the 5 bolt pattern is the standard flange design for the t3 turbine. What bolt design does everyone else have on their turbo.
    For a little more clarification I have the drawing that I sent to the company that manufactured the flange I receieved.
    http://www.pages.drexel.edu/~bjc26/flange.jpg
    Thanks in advance,
    Brian
    My T3 turbo is a wierdo, it has 4 bolts . I didn't even know there was a difference so i bought a flange and it was the same thing that you got.
    So if anybod needs a 5 bolt exhaust flange i have one for sale dirt cheap. like $10
      mine must be a weirdo too because i have the 4 bolt pattern. I just made a custom flange.
      93 Turbo'ed Gt
      T3/T4 at 5PSI
        both of mine have been 5 bolts
        1994 PGT MS2 LC-1 370cc 190lph KLZE intake ported heads Turbonetics T4 2.5" Magnaflow STS MX3 flywheel ceramic clutch, 355fwhp ** sold
        1980 Fairmont 4-door, S472, Megasquirt, 351C, 678rwhp.
        2003 Mach 1, FR500 engine, 372rwhp w/out spray.
        2003 Escape, slow.
          Both of mine have the standard 5 bolt pattern as well. But looking at the differences, I think you could get away with the one you bought, unless the bolt holes are slightly off. Because you could just use a lot of sealer and be done with it
          Dan Brown - 1995 Turbo PGT ~ SOLD ~
          287whp & 307lb-ft. @ 10.5psi & 12* Timing
            I tried and the 5 bolt pattern is off by too much to make fit. Any idea where I could find one that would fit the given 7 bolt pattern. Worst case scenario I will make my own. I just found it wierd that my garrett turbo is so much different than other t3's.
              Anyone have any suggestions as to where I could find this flange.... I am thinking of having Toastier just fab one for me but wanted to see if anyone had anymore info on the flange first...
              Thanks
                Thanks
                i didn't see any on ebay... i would just get one made... can't be that hard... you could even do it yourself
                Lots of cars... none of which are a Probe...
                  http://atpturbo.bigstep.com/item.htm...2&PRID=1390391
                  Hey man, is this the one you're looking for? I was just browsing ATP and stumbled on it...I'm not sure what your turbine housing looks like tho...says it's for a GT25 but looks kinda like my T3 housing...check it out.
                  ~Chris
                  PS - That truck's got balls!!
                  Chris DiMarco
                  NNJ?! -> NCPOC
                    Thanks for the link chris but that still doesnt look right based on the sketches I have... I have sent the flange sketch out to a bunch of turbo companies and parts suppliers and I have yielded no matches. I am even thinking of swapping out the whole turbine housing or selling the turbo. Hopefully I will find something before I am forced to take that step.
                    Brian
                      Originally posted by pringlesaregood
                      [BPS - That truck's got balls!! [/B]
