Old May 5th, 2018, 06:31 PM   #1
yellowrob
Probing Nights
Cinco de Mayo....
Some people are living life and some people are just living.
yellowrob is offline   Reply With Quote
Old May 8th, 2018, 02:04 AM   #2
yellowrob
Old May 8th, 2018, 03:53 AM   #3
yellowrob
Has anyone come up with the minimal vacuum requirements for these cars yet? So many old threads about those dang vacuum chambers....
Old May 8th, 2018, 04:54 AM   #4
If you ditch the VRIS, all you need is 1 line to the fpr.
Brizzy is online now   Reply With Quote
Old May 8th, 2018, 06:36 AM   #5
Greg 94 PGT
Five Star Member
Greg 94 PGT's Avatar
Yeah that's what I did. No vacuum chambers, VRIS, or EGR.
'94 Red PGT Gone, but Project PGT has begun
'04 Black SRT-4 Um, no it's not stock. But "It's just a Neon, right?"
379whp @ 20lbs *Sold*
Greg 94 PGT is offline   Reply With Quote
Old May 8th, 2018, 11:22 AM   #6
J_Unit
Looking good. I like the color scheme. I thought if you ditched vris without megasquirt or some other tuneable ecu you would lose performance. Really I thought you'd lose performance even with a tunable ecu without vris.
J_Unit is offline   Reply With Quote
Old May 8th, 2018, 03:06 PM   #7
It IS more beneficial to have a properly set up VRIS. Mine was already leaking, and I was deleting the egr anyways.
Old May 8th, 2018, 03:49 PM   #8
yellowrob
Gonna have to look into that...
---------- Post added at 06:49 PM ---------- Previous post was at 06:48 PM ----------
Thanks, was wanting something other then black for this car.
Old May 8th, 2018, 06:38 PM   #9
yellowrob
No vris = CEL correct.?
---------- Post added at 09:38 PM ---------- Previous post was at 09:37 PM ----------
Old May 8th, 2018, 09:46 PM   #10
Yep , several.
Old May 9th, 2018, 01:47 AM   #11
yellowrob
Lol..
Old May 9th, 2018, 04:29 AM   #12
Greg 94 PGT
Five Star Member
To clarify my situation, I'm going boost and already have MS
Old May 9th, 2018, 05:31 AM   #13
ivinklze
Hey what up nice project man , I currently have a 93 with a klze, turbo,ms,250pump,550cc inj, my dilemma is my pgt is having starting problems or harness problems, anyone around CT area that could help figure this out?
ivinklze is offline   Reply With Quote
Old May 9th, 2018, 04:41 PM   #14
yellowrob
I would check the crankshaft position sensor and for spark from the distributor. And follow up with megasquirt with a file of your outputs.
Old May 9th, 2018, 07:42 PM   #15
edgar1989
nice I like what you doing to your probe.
edgar1989 is offline   Reply With Quote
Old May 15th, 2018, 06:00 AM   #16
KaedenKy
Electrical Engineer
KaedenKy's Avatar
Don't forget you HVAC line! Also for vacuum you can Tee off of the HVAC chamber on the passenger side. You just need to add a check valve.
If you are really going for a "cleaner look" drill out all the vacuum nipples you don't want and thread in plugs of some sort.
As for VRIS, depending on your use case for the car deleting it can be helpful. You lose mid range, but you can gain top if you gut the inside. Depending on level of ambition, you can cut the top of the intake off and remove the divider/port to your hearts content.
If you have an early probe, you can also block the extra PCV connection coming from the valve cover, they did this on the later cars. I'd personally keep PCV intact.
¬°Renewed Vigor!
KaedenKy is offline   Reply With Quote
Old May 15th, 2018, 05:25 PM   #17
yellowrob
Dang, got ya. You mean gut the inside of the Vris sensor?
How did you find out if it would need a check valve? I put mine back to its original spot, but was curious none the less.
I do like the idea of cutting off the extra ports.
Oddly enough you know that little hose on the front VC, I had two , one was " a hose" the other was a dummy, everything hooked up the same tube and all but the hold was plugged up.
---------- Post added at 08:25 PM ---------- Previous post was at 08:22 PM ----------
---------- Post added at 08:25 PM ---------- Previous post was at 08:25 PM ----------
In the vertical shot, you should be able to see the ground.
Old May 17th, 2018, 12:51 PM   #18
KaedenKy
Electrical Engineer
KaedenKy's Avatar
So on the earlier probes there was a PCV hose that wrapped from the front and went directly to the manifold. Depending on the year of your manifold the nipples are different. If you get a later valve cover the connection is not there.
As for vacuum, I am saying remove the nipples on your intake manifold if you are really looking to go for some fresh look. It looks cleaner than the rubber caps all over.
The reason you need a check valve, is at WOT you can drop vacuum low enough for the VRIS actuators to close. The check valve prevents the vacuum chamber from losing vacuum.
I can mark it up in paint. But that container behind the passenger strut tower is a chamber for your HVAC controls. You can T off of that and put a check valve in line with it to the VRIS Solenoids.
¬°Renewed Vigor!
Probing old people Caffeine Probe Lounge 7 June 9th, 2002 07:54 PM
New to Probing Waats North Carolina Probe Owners Club 14 April 11th, 2002 10:35 AM
Thoughts of De-Probing running through my head Probe 2C Probe Lounge 28 November 20th, 2001 09:34 PM
Thoughts of Probing and debt running through my mind.. supergoat Probe Lounge 11 November 20th, 2001 06:50 PM
Sandon Probing a Probe Pat_SOPOC Probe Pic & Video Post 15 April 10th, 2001 07:59 AM
