Hey guys, I have a 93 Base MTX that has recently begun intermittently idling very poorly, at times almost stalling. When I give it gas when its like this it will stutter badly and have extremely poor acceleration like its running on 3 cylinders and produce a smell that I can only describe that of a burnt match. When it first started usually revving it up to about 2000-2500 would cause the stuttering to go away, but now when it occurs it seems like the problem remains for the entirety of the powerband. It happens pretty much without warning but usually after ive been gassing it pretty hard, coming to a stoplight and then starting off from the light. Sometimes I notice it missing slightly even when the stuttering problem isnt occuring. A little backstory I had a check engine light come on about 2 weeks prior to this starting, however this code cleared itself. Recently I took it to a friends shop and they pulled the codes for me. There were indeed no current codes but the one in the history stated "Insufficient flow of EGR" The mechanic said that insufficient in the case of the EGR meant no flow. However at the time of the test (naturally) the car ran fine. The cap and rotor and plug wires as well as the fuel filter were changed probably 20-30k ago. Spark plugs were changed a few months ago, as well as the air filter. The car currently has 87k on it. If anyone could help I'd really appreciate it, thanks!
93 Base intermittently stuttering hesitating
Cleaned my MAF that wasnt the problem though the filliments were dirty. Took it by friends mechanic and he checked out the plugs, wires and cap and rotor and he said they all needed replacing (the plugs because they were champion and he said champions sucked in fords), but sine he put everything back together again the cars been ok, knock on wood.
Check out my thread and some of the things I've done. They haven't fixed the problem yet, but at least I've isolated it. Maybe you can find the fix.
http://www.probetalk.com/forums/show...did=170107252195 Black SE ATX. 3" HD CAI. Hella FF50 Driving lights, 10% tints, Euro clears.
If it seems to be worse if you sit at an idle for a minute or 2 then clean the idle air control valve.... Sounds like what mine's doing, I'll let you know if it works or not... If it was the MAF sensor wouldn't it kill right when the car starts? When I had to replace mine that's what it did at least...Nitrous is like a hot chic with a std, you know you wanna hit it, but you're afraid of the consequences.
'95 Probe GT~ Hotshot headers, Greddy Cat-back, UDP, Hotshot CAI, blah blah blah
'87 Mustang GT~ Work in progress
http://www.cardomain.com/id/etherealpsewi
Ok, cleaned the IAC to no avail, tomorrow it gets a FULL tune-up and I'm goin through the CELs, could just be the PCV or a dirty mass air, but at this point it's startin to get on my nerves!!!!!!!Nitrous is like a hot chic with a std, you know you wanna hit it, but you're afraid of the consequences.
Mine starting doing it right after I rebuilt the engine. Since that time I have replaced the plugs, wires, and IAC valve with all new ones. I replaced the disty and cap when I rebuild the engine. I just replaced the IAC 3 days ago. Does it need time to recalibrate the computer? It has gotten better, but I want to see what my plugs look like again too. I may eed to replace them again after all the time of crappy idle. Could it maybe be that when I had Ford time it, it sits at 8 degrees and that is the best I can get it without pulling the disty. I am lost. I am going to check my plugs again and reset the computer and see what happens.
Well after replacing the plugs that were black it runs smoother than ever. I hope this is the permanent solution and not a temporary one.
Originally posted by Wildstar
Well after replacing the plugs that were black it runs smoother than ever. I hope this is the permanent solution and not a temporary one.95 Black SE ATX. 3" HD CAI. Hella FF50 Driving lights, 10% tints, Euro clears.
Well after replacing the plugs that were black it runs smoother than ever. I hope this is the permanent solution and not a temporary one.91 Talon Tsi AWD - 16g turbo @ 15psi
94 Talon Tsi AWD - 2.3L stroker, Garret T70 turbo, Eagle H-beams, Ross racing pistons, knifed 4G64 crank, 3" GM MAF w/translator, South Florida header, Tial wastegate, SBR 24"x12'x3.5" FMIC, Walbro 255, RC 880 injectors...more coming
