Dyno Run Results Database
  • #16
    I've been summoned out of the darkness by Omaha95PGT's private message (which sent an e-mail to me inbox)...
    Power mods:
    KL-ZE
    2.5" cat
    2.5" custom mandrel bent exhaust
    Pacesetter Muffler
    Home Depot CAI with Arospeed shielded filter
    Non-power mods:
    Shaved flywheel <14 lbs.
    ClutchMasters STG 1
    CEL on, A-Spec ECU, operational VRIS, running lean (15:1)
    End result:
    170.04 whp
    I have to look for the dyno chart on my PC at home. Originally from thie thread:
    http://www.probetalk.com/forums/show...highlight=dyno
    Since that dyno was run other mods and engine tweaks were done and I gained some seat-of-the-pants power, but since there was no dyno to prove it, I just considered it 171+ HP.
    I'd be figuring close to 180whp before it was replaced by the Xterra.
    Black 94 PGT-ZE (RIP)
    | KLZE | PaceSetter Exhaust | Home Depot CAI |
    Blue 01 IS300
    | stuff | different stuff | some other stuff |
    • #17
      Date: 6/28/03
      1996 Probe GT, MTX, ~85k miles
      Engine: Bone stock long block, P&P 03 IM, stock TB, stock ignition
      Mods: T3/T4@ ~9psi, Starion IC, Fuel mods, 3" exhaust, testpipe, millions of other 'minor' things...
      Weather: 85-90F, dont recal the actual temp
      Wheel size: 18x8
      Dyno: Mobile Dynojet
      Results: 290.1whp & 271.3ft.lbs
      Ty
      • #18
        Date: 11/18/03
        Car: 1995 Mazda Mx6 LS MTX ~81k miles with stock KLDE.
        Mods: Custom cai
        Misc: FD wheels
        Results: whp=134.4 wtq=139.8
        Dyno printout:Cardomain 2
        Cardomain 1
        Dyno Type: DynoJet
        Discussion: 3rd gear, since 4th gear was my 3rd run and it was heated up.For the stock guys. Geez, I want a t3/t4 now...
        Evan
        1995 Mx6 LS
        • #19
          '93 PGT MTX
          Engine: KLDE/03 Completly stock internals, and IM/heads
          Mods:
          MSD 6A & Blaster 2 coil
          Custom CAI
          True Dual exhaust
          Misc:VAF relocated to the end of the throttlebody.
          .65 plug gap
          Splitfire plugs
          El cheapo plug wires
          89 octane
          Bored banjo bolt
          stock ignition timing
          Mileage: 149,500 miles at time of dyno
          Tire size and wheels/gear dyno run: stock size tires and wheels, 4th gear
          Dyno type: Dynojet
          #1: 58*F, 142.50whp/145.68wtq
          #2: 58*F, 146.12whp/147.86wtq
          #3: 58*F, 147.29whp/146.83wtq
          #4: 59*F, 148.50whp/148.80wtq
          Dyno plot #4 \/ \/ \/
          http://images.cardomain.com/member_i...71_99_full.jpg
          ~Aaron~
          1993 Silver PGT MTX ~~R.I.P~5/7/14
          • #20
            Date: 6/28/03
            199 Probe GT, MTX, ~65k miles
            Engine: Bone stock long block, stock IM, stock TB, stock ignition, stock injectors
            Mods: T3/T4@ ~9psi, Spearco IC, Only fuel mods: FMU/pump, GReddy exhaust, resonated testpipe
            Weather: 75-80F
            Results: 269.6whp & 263.3ft.lbs
            Lee
            Lee Hubanks
            As a political discussion grows longer, the probability of a comparison involving Hitler or the Nazis approaches 1.
            http://members.cardomain.com/ntruder95
            • #21
              Date: 4/12/03
              1995 PGT MTX, 95k miles
              Mods: T3/T4@ 7psi on Ludespeed Pipes, Spearco IC, Vortech FMU/ Walbro 255HP pump, Bosch Platinum Plugs (stupid, I know), GReddy exhaust
              Dyno'd On: Dynojet Dyno @ EIP tuning in Frederick, MD
              Results: 252.2whp/245.5tq
              Proof here
              Turbo Mark
              1993 Mazda RX-7 R1
              1995 Probe GT Turbo
              13.75@103.94
              • #22
                Date 7-26-2003
                Place Gateway International Raceway In St Louis @ Nopi F&F Racing Series
                Year 1993
                Engine type 2.5 kl-03
                Tranny Type MTX
                The only mod I had at the time was a pace setter 2.5 catback exhaust, also mind you my stock airbox when i took it out the day later to swap for my weapon r intake was completely clogged with a mouse nest. The next day I dynoed again with the weapon r WAI intake on.
                I also ran valvoline synpower 10w30 oil, and always 93 octane gas
                Stock 16" 5 stars with sumitomo rubber
                Temp in the city 96 degrees, on the track it red over 105!
                Type Mobile DynoJet
                My best pull was 149.5 whp doing a 4th gear run (stock intake)
                154.5 whp (weaponRIntake)
                I think that was dang good, i blew every other probe and mx6 out of the water!
                Since then wal mart spun a bearing in that wonderful motor thus damaging the piston rod and the front head. Now I am in the process of a ze swap, old motor for sale if anyone wants to rebuild a strong motor Private message me if interested!
                The Probe is gone forever yay!... Now just a 2004 Sonic Blue Mustang GT 40th anniversary . . . off road x pipe, and slp loudmouth catback, SLT True Cold Air Intake, 3.73 gears, Sct X3, MGW STS, Centerforce DF Clutch, Steeda adjustable clutch kit
                • #23
                  dyno pull 1996 PGT
                  Date: 5-3-2003
                  - 1996 KL-03 MTX PGT
                  - 68K miles
                  Engine: Stock 1996 KL03 engine, NGK V-power Plugs, NGK Wires, Stock Fuel, Stock ECU
                  Cams: Stock
                  Intake: Hotshot Cold Air Intake w/ Elbow
                  Exhaust: 1996 Stock Header with Pre-Cats, 2.5" test pipe, 2.5" Crush Bent Exhaust Piping, Arospeed DTM muffler
                  Misc: Fidanza 9lb FW, CM Stage III, 18" Konig Traffic 225 40 18
                  Temp: 68 degrees 89%Rel Humidity
                  Results:
                  DynoJet Dyno - 3rd Gear Pull
                  153TQ @4600RPM, 152 HP@ 5400RPM
                  • #24
                    Naturally aspirated mods
                    KLZE IM, VRIS Controller, UDP, pacesetter catback, test pipe, MX3 FW, MSD, PS headers, cm3 clutch, 255lph fuel pump, afpr, 65mm tb, cai, pheno spacers, suspebsion mods and lighter wheels.
                    173 hp 164 ft/lb
                    75 Shot of Nitrous
                    KLZE IM, VRIS Controller, UDP, pacesetter catback, testpipe, MX3 FW, MSD, PS headers, cm3 clutch, 255lph fuel pump, afpr, 65mm tb, cai, pheno spacers, suspebsion mods and lighter wheels. NOS 5122
                    240 hp 241 ft/lb
                    T3/T04E .48 hot side .60 cold side 54 trim compressor wheel at 6 psi un-tuned
                    KLZE IM, UDP, pacesetter catback, MX3 FW, MSD, stock exaust manifolds, Dangerous Dan turbo pipes, cm3 clutch, 255lph fuel pump, afpr, 65mm tb, cai, pheno spacers, suspebsion mods and lighter wheels.
                    224hp 212 ft/lb
                    I found a restriction in my intake some leaky couplers and some fuel issues. Here soon I will be tuning on the dyno with the turbo. When I do I will update my numbers. I plan on hitting the 250-260 hp mark
                    Also These dynos where pre ZE cams. I never did dyno with the cams installed N/A
                    My SRT-4
                    Sold, My Turbo 2g MX6
                    • #25
                      Re: Dyno Run Results Database
                      1/31/04
                      -Year 1993
                      -Make and Model Ford Probe GT
                      -Transmission ATX to MTX swap
                      -Mileage on engine Unknown (whore engine)
                      -Type of engine KL-DE N/A
                      -Power mods only Removed A/C, IM and TB Phenos, Knife edge/Ported IM, 64mm TB, Hot/Warm Air Intake, Bosal/Brospeed ceramic coated headers, testpipe, borla catback, fidanza 9lb flywheel, clutchmasters stage III clutch, NGK wires/plugs
                      -Other misc parameters 16" stock swirlies (Yokohama ES100), Ill update temp when I bring my sheets in the house.
                      -Brand of Dynomometer Dynojet
                      -Elevation of the city where you dyno'd Hudson, OH 1090 feet http://www.bigshotdyno.com
                      WHP= 158.0 / TQ= 159.9
                      (My other two pulls were @ 152hp and 155hp, dont remember the torque on those, Ill update when I bring my sheets in from the car)
                      MMIV, MMV, MMVI, MMVII, HH2k2, HH2k3, HH2k4, HH2k5, HH2k6, HH2k7, HH2k8
                      • #26
                        1/31/04
                        -Year 1993
                        -Mileage on engine 133,000
                        -Power mods only Phenos, 64mm TB, Hot/Warm Air Intake, testpipe, clutchmasters stage III clutch, lightened flywheel, NGK wires/plugs, 2.5" cat-back with Dynomax Ultraflow muffler, MSD 6-AL with Blaster 2 coil
                        Run 1 running full VRIS:
                        139.9 HP and 148.4 TQ
                        Run 2 running full VRIS:
                        147.8 HP and 152.2 TQ
                        Run 3 VRIS 1 held open
                        147.3 HP and 172.8 TQ
                        Pat
                        Dude. I'm old. Give me a break.
                        • #27
                          - 1994
                          - Probe GT
                          - MTX
                          - 140K miles
                          - KL03
                          - CAI, GReddy exhaust (no cat, no test pipe, just straight-thru piping w/ a resonator), ACT Stage II clutch, UR Underdrive Pulley, NGK plugs, 8.5mm NGK wires
                          - stock 5 stars, 1 front tire had minimal tread, other was brand new
                          - DynoJet
                          - Hudson, OH 1090 feet - http://www.bigshotdyno.com/
                          150 HP / 153 TQ on runs 2 & 3 .. run 3 at VRIS held open (didn't make a difference)
                          I ran fairly conservative .. revved to 3K in gears 1,2,3 and nailed it at 3K in 4th .. revved to 7K before letting go.
                          This was my first time dyno'ing anything!
                          07 Chevy Cobalt MTX LS - Bone Stock
                          94 MTX GT - Some Mods - SOLD!
                          94 ATX Base - GIVEN AWAY!
                          97 MTX Escort - Flat Tires
                          • #28
                            From the archives...it got left behind on the old server
                            95ProbeSS's dyno run
                            Year 1994
                            -Transmission MTX
                            -Mileage on engine 60Kish...145K on chasis
                            -Type of engine KL-ZE
                            -Power mods Home made CAI, 65mmTB, pheno spacers, Hotshot headers w/custum 2.5inch collector/ypipe, hiflo cat, 2.5 mandrel bent piping, Greddy SP muffler, Aeromotive AFPR, MsD ignition, Jay B chip, etc
                            On a DynoJet
                            First run was with the 94 ECU, fuel PSI at 50(wot) and managed 185whp & 159 tq. A decent gain from my last dyno 6 months ago (have added stuff since then).
                            Next run was with my ecu with Jay B's chip and same fuelpressure. 189whp & 164 tq.
                            Last run I lowered the fuel ressure to 45 (wot) and got 192whp &168tq.
                            Marc M.
                            2000 BMW M-Roadster
                            • #29
                              1/31/04
                              -Make: 1995 Ford Probe GT
                              -Transmission: ATX to MTX swap
                              -Mileage on engine: 102,000 miles (165 compression on average)
                              -KL03 stock internals: "TOTALLY UNTUNED" Garrett T3/T4 .63/.60 Turbo(7 psi), Non-Intercooled still, 2.5" Pacesetter catback, test pipe, IM phenos, 64mm TB, Southbend DxD clutch, 18 lb. Probe Flywheel, stock injectors, 255 regular pressure fuel pump, 12:1 FMU, stock FPR, P&P IM, NGK V-power 7 range plugs, NGK plug wires, and "running scary lean mod!"
                              -Brand of Dynomometer: Dynojet
                              -Elevation of the city where you dyno'd: Hudson, OH 1090 feet http://www.bigshotdyno.com/
                              238 WHP and 226 TQ
                              Dan Brown - 1995 Turbo PGT ~ SOLD ~
                              287whp & 307lb-ft. @ 10.5psi & 12* Timing
                              • #30
                                96 MTX PGT w/roughly 85k
                                Engine : KL-03 w/ZE cams
                                Power Mods : UR UDP, Magnecor wires, HS CAI, custom 2.5" catback w/TP, Outlaw pheno (port match runners on stock intake), 65mm TB, Walbro 255lph, Mallory FPR at 47psi idle (set for juice), Royal Purple 5w30, Redline MT-90, Redline water wetter, UR 9lb flywheel, SBC TZ clutch
                                Misc : 225/45/17 on SSR GT1, temp mid-high 70's, timing accidently off, plug gap shorter for juice,
                                Dyno : DynoJet @Speedworks, Lewisville, TX (elevation unknown), N/A pull, 3rd gear (at least, that's what I thought) @ 2:19:30pm on 6/21/03
                                whp=159.9 wtq=158.3
                                My car - another fully functioning OBD-II ZE.
                                What the hell is Lomo?
