Hello guys,
Visiting over from celicatech.com, looking for some more information about the Tein SS coilovers. We're in a bit of a debate about these, so im obviously very curious to what some of the very knowledgable probe talk team has to say about a few points Im about to buy some of these for my celica, but I want the absolute best, and I want to make sure this is it
Its been reported to me that the Tein system uses a subpar valving system that has its low points. Instead of using a digressive valve, I have been told that it uses a linear valve. This is going to greatly effect the performance of the strut, given different velocities factors of compression.
"1) Due to the design you won't feel a difference until the hole is almost completely closed up. (i.e. only the last few "clicks" make a real difference in how the suspension feels)
2) Linear valving. This means that the damping will increase equally by the increase in force applied. The alternative, which has been used in offroad racing for years, is what's called digressive valving. Effectively, this means that at high speed cycles (i.e. hitting a pothole or bumps in the road), the damping is minimal, but at low speeds (i.e. taking a sharp turn, hitting the brakes, etc.), the damping is much higher. This results in a better ride quality on the street but with better damping for taking the turns."
I am positive that Tein will use the same (i think they're monotube, correct?) damper throughout the SS line, so I'm positive this is applicable to you folks as well. The qoute above is from a BRILLIANT celica enthusiasts that I respect to a great deal, he's a mechanical engineer and has done some incredible stuff with his celica.
Any thoughts on this?
Come check out our thread please?
It actually starts gettin good at Post 14
http://www.celicatech.com/forums/showthread.php?t=12085
Thanks guys!
Thanks guys!
