How to Moon Roof Rust Repair
needs to be taken off and fixed properly. you can get that red in a can at color supply just take it off and do it the right way. hell you dont even need to remove it to bondo and paint it.94 PGT[96 PGT FuLL OBD2 WiRe HaRNeSS] ]KL31 SHoRT BLoCK & CaMS] [KL1C MaF SWap] [CuRVe NeCK MaNiFoLD] [KL68 TB] [Hei & MSD BLaSTeR 2] [Cai] [SS HeaDeRS] [STS] [R&R PoLY F&R MouNT & SHiFTeR iNSeRTS] [STaGe 2 CLuTCH] [FiDaNZa FLYWHeeL] [eGR DeLeTe] [FuLL a/C DeLeTe] [CoiLoVeRS] [RX8 WHeeLS oN 225/45/18]
Originally posted by xrp861 View Postneeds to be taken off and fixed properly. you can get that red in a can at color supply just take it off and do it the right way. hell you dont even need to remove it to bondo and paint it.
---------- Post added at 08:11 PM ---------- Previous post was at 08:11 PM ----------
P.s. Obviously this whole post/topic is sarcasm94 PGT -T, Used to be quick
94 Black PGT, KLZE, spun bearing, Likely parts car for life
