Go Back   ProbeTalk.com Forums > Performance Section > Engine Electronics
Engine Electronics Do you own a Jacobs, MSD, MegaSquirt or other ignition/fuel system? Get in here and ask your questions!
Old January 26th, 2016, 11:14 AM   #201
ChillinZX
The default map is set at 12 something and under a/f. Sounds normal, the extra fuel probably keeps the temp down. You can adjust it manually if you want, say 13 to 14 or so. I deleted my IAC, so I just adjust the screw on top if my idle is too high or low.
2000 ZX2 w/ '95 Millenia KL swap, MSPNP (VAF delete, IAT mod, AEM Wideband, Coilpack), MFactory LSD and 'Plate Mod' 626 trans, Aeromotive fuel system, custom DSS 500hp axles, AWR solid trans mounts, KLG4 IM, MX3 GS brake booster/master combo, ebay headers, ebay CAI system, Ford Racing ZX2 inverted coilovers, Cusco camber plates all around, custom made traction bars mounted to frame rails, body kit, 2 tone paint, etc...
ChillinZX is offline   Reply With Quote
Old February 3rd, 2016, 08:04 PM   #202
gavinegr
Great resource!
gavinegr is offline   Reply With Quote
Old March 29th, 2017, 03:14 PM   #203
Just wanted to update this thread with some tunes:
http://members.iinet.net.au/~steven.s/
stoker100 2017= my current tune as of right now
-MSD
-36-1 wheel
-No VRIS
-WMI control
-Mill S inj
NA 2015= my last tune before boosting (has some boosted VE/Timing but that's easy to change)
-MSD
-Stock crank wheel
-Stock injectors
-VRIS
^ for you proboner!
Nitrous oxide. - 79' Yamaha QT50 'Yamahopper' 70cc, MLM pipe, VM18 carb, dual stage reeds etc. Current
stoker100 is online now   Reply With Quote
Old April 10th, 2017, 09:11 AM   #204
BlackProbe
-MSD
-36-1 wheel
-No VRIS
-WMI control
-Mill S inj
-MSD
-Stock crank wheel
-Stock injectors
-VRIS
^ for you proboner!
Why did you switch the the 36-1 wheel??
93 Probe gt- ,15.37 1/4 mile at mph 85 ** 5/24/03 14.71 SOLD
1994 gt -klze,I/h/e/fly/ignition/kl31 ecu,colt210/210 cams Rip 2/13/08(blackice)
92 mx3gs,ze swap from my probe [email protected] :-( 175hp&155tq
BlackProbe is online now   Reply With Quote
Old April 10th, 2017, 04:32 PM   #205
It was on the crank SC OD pulley.
Old April 29th, 2017, 03:44 AM   #206
Probomax
Spark maps
Does anyone have some good spark maps for NA?
The Megasquirt baseup maps are for turbo and I' trying to figure out what a good map for NA would look like.
Probe GT 4WS!!! with KLZE heads & manifold, Megasquirt, OE spacers, ebay headers & RX8 steering wheel
Probomax is offline   Reply With Quote
Old May 2nd, 2017, 12:40 PM   #207
Matt Cramer
Authorized PT Vendor
Matt Cramer's Avatar
The MSPNP base map was tuned on a naturally aspirated KLZE.
http://www.megasquirtpnp.com/mspnp2_maps.php
Matt at
My PM box fills up fast - it's much better to email me at
Matt Cramer is offline   Reply With Quote
