the lighter doesnt seem to work even tho all fuses seem to be fine..anyone had this prob before? cant charge phone or anything...have tried moving the charger around and nothing....is there another fuse inline somewhere?
lighter socket not workin
Originally posted by bubbajay12 View Postthe lighter doesnt seem to work even tho all fuses seem to be fine..anyone had this prob before? cant charge phone or anything...have tried moving the charger around and nothing....is there another fuse inline somewhere?
have you popped the console apart? Theres a small clip-on connector that delivers the 12v to the lighter socket. it might have come off.BC Probe Owners Club is VERY MUCH ALIVE - www.bcpoc.ca
93 PGT 2.5L SILVER - Stock DE, ZE Intake Manifold, T3/T4 .50/.63 AR Turbo, Valant Turbo Pipes, Tial 38mm Wastegate (~9PSI), Custom Water/Meth Injection, Megasquirt v3 (MSnS-Extra 029q2 Fuel/Spark), Millennia Injectors @ 70psi, 65mm TB, JJ Resonated TP, Centerforce DF Clutch, MX3 Flywheel, AWR Mounts, it begins all over again...
93 PGT 2.5L BLACK Dismantled
GARAGE - The hybrid with a piston hole... lots of various leftovers...
i have this problem too... i can put any kind of charer in b/c its dead...
ill have to check the connector & fuses...
does the lighter outlet have a specific fuse ro is it teamed up with others?
