FrankenProbe work log, 2010
  • I like that the stock shift knob remains intact.
    2010 Ford Fusion
    I am a working stiff with no toy car at the moment
    I'm not a probe owner but im still a probe enthusiast
    • Dan do you by chance know what it weighs?
      Turbo'd 94 Mx6 12.87 @ 115 on 5 psi.
      Built by Me, eBay and zip ties.
      96 White M-Edition mx6 Being built with above's parts, just less tip ties and sketchyness.
      • Originally posted by 007 GTS View Post
        and pedals
        2003Subaru WRX E85stock td04,tgv deletes, full catless, custom 2in crosspipe, 3in TBE, walbro 255,850 modded injectors,grimmspeed crank pulleyTUNED by me on opensource 12.8 @105mph 1.7 60ft
        • I don't know its current weight, will check it when I have it aligned and corner balanced.
          Turbo kit (off the car to get coated) - I'm pretty content with how it looks, and very happy that it's done.
          http://i73.photobucket.com/albums/i2...e/58b97a62.jpg
          http://i73.photobucket.com/albums/i2...e/d949a988.jpg
          • Looking great, those pipes will flow!
            Need a chip or parts for your 1st gen GT go here----->Fordprobeparts.com
            Floridafordprobeowners.club
            • I see you are now cheating on Mountain Dew with Coke... Somehow things just aren't the same...
              2014 BMW 328d Luxury Line- Mineral White/Saddle Brown Leather, Premium Package, Driver Assistance Package, Cold Weather Package, Navigation, car seats inside
              2012 BMW X3 35i M Sport- Traded
              2003 BMW 330i ZHP- Alpine White/Natural Brown Montana Leather, Performance Package, Cold Weather Package, Navigation, Certified Dinan Stage III, car seats inside
              2004 BMW 330i ZHP- Totaled
              • Ricer grapefruit shooter.
                What color you coating them?
                2015 Audi Q3 - Stock |
                • I am content that you are content with the turbo setup....
                  • Originally posted by JKpgt96 View Post
                    I concur!
                    -J-Rod-
                    93 PGT-T
                    • Originally posted by Jarod7920 View Post
                      I concur!
                      from the movie "Catch me if you Can."
                      Why didn't I concur!?
                      Jesus is the remedy
                      Black '94 GT DE/ZE hyrbid, too many parts to list
                      Black '89 MX-6 GT AWS: T3/T4 turbo, 3" exhaust, big brakes, FD's, K-sports, FD's, plus much more...
                      Ebony Pearl '95 Subaru SVX LSi home of: BontragerWerks 22mm RSB #001
                      • im positive about being sure these will most definitively absolutely guaranteed to be the cat's ass of turbine pipes for this motor.
                        • Whoa, somebody has a V-band clamp fetish. Planning on switching from silicone rubber clamps to some aluminum Pegasus (or alike) ones on the cold pipes?
                          Impeccable work as always Dan
                          -Kyle
                          93 Black probe (K-sporting) My Cardomain
                          Mazdaspeed SVO 2.Slow turbo build teaser thread**
                          • Well let's see, it takes me about 3 minutes now to remove the hot pipes and downpipe...as opposed to about 15 times that much before, with poorly fitting flanges that *almost* lined up.
                            The cold pipe stays siliconed, v-band kits are expensive as hell (no, I don't shop on Ebay).
                            Edit - today I rebuilt the center console so I have my switch panel centered now, and a bit higher. It also fits the SDS ECU, control board, wideband computer and the fuel mixture knob so it's all in one place, which will allow me to trim the wiring a bit and make it more tidy.
                            Now that the Zeitronix software is upgraded, I can get full data logging now of AFR, boost, TPS, RPM, and so on. Next I have to build a little laptop nest so it won't be flying in the back of the car in one of them there sub 3-second 0-60 runs.
                            • Hey, you don't have to convince me of their pragmatism! Tho i have to do my thrifty shopping on ebay, cause there is no way i can afford all those goodies from ATP.
                              Still such a very sexy configuration...
                              -Kyle
                              • Originally posted by 'Dan [Sac
                                Pic!!!!!
