Go Back   ProbeTalk.com Forums > Tech Section > Racing/Suspension > Racing/Suspension Archive
Racing/Suspension Archive Quality Archived Posts and FAQs
Old April 23rd, 2010, 09:17 AM   #26
polarexpress17
bibliographically epic
polarexpress17's Avatar
Originally Posted by short4stuff View Post
My road tests will be this weekend. Now not sure if I will be able to trap on it yet, but probably will.. need to re-install msns... atleast the map should still be alright..
sweet! looking forward to the results
95 mx6 with a 4 lug swap
Built, Not Bought.
polarexpress17 is offline
Old April 23rd, 2010, 09:30 AM   #27
hppwdn
Golden Egg Purveyor
hppwdn's Avatar
If you don't happen to have your engine out when you do this Dansac's method of dropping the subframe is a very easy and simple alternative to removing the engine.
($100 junkyard KLG4)
, 14psi, DOT approved Hoosier drags, pump gas.
HIN/NOPI Supershow Class Winner - Miami 2010 - Street-Sport Compact-Mazda
Links:
As of July 2011 the MX3 has been retired and sold.
hppwdn is offline
Old April 28th, 2010, 07:56 PM   #28
short4stuff
On the Cutoff
short4stuff's Avatar
I never did get to drive it yet.. This weekend for sure.
Just the waterpump belt.
I measured it at being 29" on the smallest and 29.5" on the highest. Anyways I ordered a belt. 29.25" When you buy a belt their measurement is the outer diameter, mine would be the inner..
Long story short I'd go with a 29.5" outer. The 29.25" belt took some wrestling to get on.
94 PGT -T, Used to be quick
94 Black PGT, KLZE, spun bearing, Likely parts car for life
short4stuff is offline
Old April 28th, 2010, 08:08 PM   #29
polarexpress17
awesome, added the info to the 1st post
Thanks
Built, Not Bought.
Old May 1st, 2010, 07:37 PM   #30
short4stuff
On the Cutoff
Drove it today.
It will take some getting used to.. Less noticeable torque steer though.
Parking lots suck, and on ramps arent that fun either. but other than that its alright.
Best part is it gave room for the catch can. lol
Old May 2nd, 2010, 08:19 AM   #31
slinkyPgT
on a scale from 1 to 10 (10 being - very hard --- 1 being - working power steering.)
so auto-crossing with this conversion would be out of the question?
2003Subaru WRX E85stock td04,tgv deletes, full catless, custom 2in crosspipe, 3in TBE, walbro 255,850 modded injectors,grimmspeed crank pulleyTUNED by me on opensource 12.8 @105mph 1.7 60ft
slinkyPgT is offline
Old May 2nd, 2010, 08:31 AM   #32
short4stuff
On the Cutoff
Ya I wouldn't be auto crossing.. I am not a big guy... (150pds on a good day) I would rate parking lots a 8, and just crusing a 2 (its feels the same as the power pretty much)
Old May 2nd, 2010, 09:18 AM   #33
short4stuff
On the Cutoff
EDIT When parking I can turn the wheel with one hand (abit of struggle) until it straight and it needs to turn the oppisite way... then its a two handed battle.
Old May 2nd, 2010, 10:36 AM   #34
polarexpress17
probably due to the lower ratio. it should be fine for me, i can lift a KL by myself, just can't move with it LOL
Built, Not Bought.
Old May 4th, 2010, 07:56 AM   #35
slinkyPgT
yea im only 150 soaking wet! but drove a p/s deleted mx3. minded u its lighter
Old May 4th, 2010, 11:47 AM   #36
hppwdn
Golden Egg Purveyor
hppwdn's Avatar
This is the part number for the belt I used when I deleted mine a few years ago.
Dayco Part # 5040295, 4 rib 29.5" belt
Links:
hppwdn is offline
Old May 6th, 2010, 12:30 AM   #37
polarexpress17
Thanks andy! added it to the first post
Built, Not Bought.
Old August 29th, 2010, 05:23 PM   #38
pgtfreak
Born a poor black child
pgtfreak's Avatar
Why was this never stickied?
Good write up, and now copied and placed in the racing/suspension archive.
'14 Jeep Grand Cherokee Limited
'16 Chrysler 300S
pgtfreak is offline
