Originally posted by Elli
View Post
2.5L KL Colt cam bulk buy!
The process works like an assembly line... they want as many in the shop at one time.
They un box them, mark them so each cam goes back to the original owner
they get cleaned, checked for damage, journals polished, checked for warpage, and cam straightened as needed.
all cams getting the same grind are grouped together, then setup machine to do intake cams of grind X... He then does every intake cam. Then setup for exhaust cam grind X.. then he does all the exhaust cams.
Move on to Grind Y, Rinse and repeat...
If your cams aren't in on time then there is extra setup time...
I have a set of cams from my DE that I want to grind and put in my ZE. Will this be a direct swap? considering tolerances?The daily driver: http://www.cardomain.com/ride/389595...t-hatchback-2d
yes you send them your old cams and they regrind them to whatever grind you want95 PGT white dd klze / mtx fidanza,maf swapped obx headers 2 1/2" mandrel bent 14.3 sec 1/4mile time
94 PGT blue toy de/ze/g4 hybrid/ mtx turbo 5- 10 psi maf swapped aem piggy back, fidanza mandrel bent exaust
93 PGT red klde/mtx klg4 intake,wild orchid interior
97&94&93 PGT gone
DALE
Thats not really what I meant. I am talking about the journal tolerances between the cams. I know that with them being out of tolerance that is not good. Should I get the cam journals and caps checked? or is it safe for a direct swap after the regrind?The daily driver: http://www.cardomain.com/ride/389595...t-hatchback-2d
you can swap cams in to different heads. You can measure the cam journals to see if it is within manufacturer specs.
Never swap cam caps from different heads they are matched and machined on the head they came from. Heads that have no caps are basically worthless.
You can if you want, torque the caps down with no cams in and measure the bores with the proper tools and micrometers and compare the difference to the measured cam journal to find the clearance you have.
with all the HLA's removed the cams should spin freely.
Ok so what you are saying is to install the cams in with out the HLA's. They should spin freely, if not then there is a problem?
I really don't have the measuring tools to measure the cam journals on hand. I know that the cam caps cannot be swapped. I just didn't know how close the cam journals were machined originally to be matched.
Thanks for the info.The daily driver: http://www.cardomain.com/ride/389595...t-hatchback-2d
Originally posted by Zepticon View PostWell i dunno how the stuff is organized, but if i where him i would love to get a stable supply and not get everything at once in the end of feb So i would ask if he could do yours early
Originally posted by DDDyloD View PostOk so what you are saying is to install the cams in with out the HLA's. They should spin freely, if not then there is a problem?
i spoke to geoff and he made a point that he has to use specific machining tools and that these cams were very particular, so i'm sure like mr. jason said, he'd like to spend as little time setting up and breaking down for these grinds as possible. he's a nice guy thou so who knows.
Originally posted by Elli View Posti spoke to geoff and he made a point that he has to use specific machining tools and that these cams were very particular, so i'm sure like mr. jason said, he'd like to spend as little time setting up and breaking down for these grinds as possible. he's a nice guy thou so who knows.Mazda 626 GT - 2.5 V6 - KL31
Mazda RX-7 FD - EU spec
I'm seriously confused on the difference between the turbo and the tri flo cams. I tried to do a search between the two and the information was minimal. Does anyone mind explaining the difference or showing me a link that explains? I would love to get in on this BB.
1994 Ford Probe Gt Ze. Kitted. Lowered. Turbo'ed. MSv3. Czt Tranny. Lsd. Shiny
2008 BMW 335I 2JZ German style looks stock but not
1995 Nissan 300zx With a fan symbol instead of a oil symbol
Originally posted by knightrider07 View PostI'm seriously confused on the difference between the turbo and the tri flo cams. I tried to do a search between the two and the information was minimal. Does anyone mind explaining the difference or showing me a link that explains? I would love to get in on this BB.
The triflow cams have two different grinds on each pair of lobes, meaning that the valves for one cylinder doesn't open at the same time.
Not sure what the exact details are, but i think i read something that one of the lobes where a 210 grind, while the other was a 218 grind. All exhaust cams should be the same.Mazda 626 GT - 2.5 V6 - KL31
you can get tri flow turbo grinds, but i dont know if they are offering them in this BB the way it is worded.
check the archives for past BB where it says the following
NEW TRI-FLOW GRIND:
Prime Int: 218° @ .050 / 288° duration / .363 L
Sec Int: 210° @ .050 / 274° duration / .355 L
Exh: 218° @ .050 / 288° duration .363 L N.A.
Exh: 210° @ .050 / 274° duration .355 L Turbo
This grind gives a much broader power band with minimum low end loss
For more information on the tri-Flow please check our web page. www.coltcams.com (under tri-flow technology)
In fact this BB thread has far less info about the grinds than the previous BB threads. Not sure why that is.Last edited by Mr.Jason; January 15, 2012, 01:27 PM.
