Go Back   ProbeTalk.com Forums > Vendor Support and Contact > Former Vendors > Darkstar Motorsports
Darkstar Motorsports Offering Light weight Pulley Kits & Solid Motor Mounts
Old January 25th, 2009, 02:27 PM   #1
darkstarmotorsp
Lightbulb GI: Custom Made "Probetalk.com" Sequentially Numbered Badges
Custom made name badges for Probetalk.com
Each badge is sequentially labeled beginning with #0001 to #0100. Please note that these are limited edition badges. The number can be increase from 100 to 150 or 200 if theres enough interest.
Since badge numbers are unique, if you see a car on the road with a specific badge number, you can look up what member that was on the cumulative GB List!
Specifications:
3" x 1" 1100 Alloy Aluminum with Brushed/Satin Finish with a hard anodized clear coat.
3M VHB (Very high bond) mounting tape
Strength: 25 lb/in of 90 degree peel adhesion strength (440 N/100mm)
Anodized / Clear Coat Specs:
Mil-P-514
Mil-P-15024D Type H & G
Federal Spec GG-P-455B
Description:
Chemically anodized black and blue dyes followed by a mil spec anodized clear top coat. The result is an image that is chemical resistant, and highly durable for outdoor applications in direct sunlight and in salt water conditions. The plate of metal itself would have to be destroyed to affect the image due to the state of the art manufacturing. Traditional silk screen or printed badges has color that can scratch off with your fingernail, and the colors fade in UV light... These military spec bad boys do not have a raised ink surface and will last a lifetime.
Each badge has been anodized and CNC cut from a sheet of 0.050" aluminum alloy sheet which is very robust. In addition, each badge is backed with 3M 4949 VHB Black foam tape. This is a premium mounting acrylic/rubber-like pad that will allow your badge to mount to your exterior paint, or textured surface plastics. Designed as an exterior fastener to replace rivets, spot welds, and liquid adhesives, 3M VHB is made of a viscoelastic acrylic foam that is energy absorbing with outstanding durability. (UL746C)
The acrylic adhesive is 100% resistant to full submersion in water, salt water, hydraulic fluid, 10w30 motor oil, and glycol antifreeze. 90% resistant to kerosene, 50% resistant to jet fuel, 35% resistant to gasoline, and 5% resistant to MEK (Methyl Ethyl Ketone).
If applied at room temperature, 50% of ultimate bond strength will be achieved after 20 minutes, 90% after 24 hours and 100% after 72 hours. The higher the temperatures, the faster the curing time.
Installation:
PLEASE make sure the badge is exactly where you want it to go before applying it. This means first taping the badge to the location you want and checking that it's not crooked. Next, outline the badge with tape to mark the location. Finally, peel back the clear plastic liner and apply firmly to virtually any surface that is clean. The bond will be strong, however it can and will remove cleanly without leaving a residue. Just apply about 90 lbs peeling force and the "rubber like" adhesive removes cleanly.
The pirce for these would be around $23 USD shipped anywhere in the world.
I would just need the Admin approve to copy the forum's image to make these. I have attached a few pic of badges i have made for other forums
darkstarmotorsp is offline
Old March 1st, 2009, 05:13 PM   #2
riithunder916
I think this would be cool! So i would be in for one.
riithunder916 is offline
Old March 1st, 2009, 05:23 PM   #3
JazRedGT
Junior MODARATER
JazRedGT's Avatar
Yeah I would be in for one. I got dibs on #23. LoL
1993 PGT-DE-T Silver Surfer - 8psi
2004 Acura TSX - Wife Mobile
JazRedGT is offline
Old March 1st, 2009, 09:26 PM   #4
1990pgl
Balls Across The Nose
why do they say ford fusion on them
1990pgl is offline
Old March 1st, 2009, 09:41 PM   #5
95PGTTech
Push The Limits
95PGTTech's Avatar
read before posting
Originally Posted by darkstarmotorsp View Post
...I would just need the Admin approve to copy the forum's image to make these. I have attached a few pic of badges i have made for other forums...
95PGTTech is offline
Old March 2nd, 2009, 10:17 AM   #6
darkstarmotorsp
Thank you everyone for the interest, but before I can do any type of drawing of these, I would first need the admin approval.
Old March 3rd, 2009, 06:49 PM   #7
riithunder916
True, have you asked the admins yet?
Old March 3rd, 2009, 08:43 PM   #8
pro_am_rider
i would take a couple as well.
Praise the Lord and Pass the Ammunition!!
Kill 'em all and let God sort 'em out.
pro_am_rider is offline
Old March 3rd, 2009, 09:03 PM   #9
orange93gt
dibs on #13 (if they work out) lol
1993 Orange PGT - FOR SALE!!! buy me!
1995 VW Golf - my new toy
1994 VW Jetta - the wifes new toy
orange93gt is offline
Old March 4th, 2009, 01:13 AM   #10
darkstarmotorsp
I'll send them a PM tonight
Old March 4th, 2009, 01:18 AM   #11
archangel
Ill definitely take one.
ARRIVE....RAISE HELL....LEAVE!!
archangel is offline
Old March 4th, 2009, 11:33 AM   #12
guiltyspark117
id like #117
guiltyspark117 is offline
Old March 4th, 2009, 04:34 PM   #13
MakatoMotors
PT Master
since no one metnioned it
dibs on #1
are they guna look similar to the fusion ones?
2012 Ford Focus Hatch
Eibach Pro-Kit. AEM CAI, Magnaflow Exhaust. Steeda Rear Sway Bar. RS Spoiler. RS Hood. 18" MSW Wheels
16.28 @ 86.56
MakatoMotors is offline
Old March 4th, 2009, 04:36 PM   #14
riithunder916
Dibs on #114!!!!!!!!!!1
Old March 5th, 2009, 02:38 AM   #15
dmark101
Obfuscatory & Abstruse Nomenclature
dmark101's Avatar
dibs on #1
if anyone has dibs on #1, it would be me and no one else.
i've still got to talk this over with stacey, but i wish that the vendor would have approached us BEFORE posting a thread.
dmark101 is offline
Old March 5th, 2009, 07:55 PM   #16
MakatoMotors
PT Master
^^^ ok
but i hope u approve this seems cool
16.28 @ 86.56
Old March 6th, 2009, 12:51 AM   #17
darkstarmotorsp
#'s 1-5 will be reserved for the Admin and mods of the forum.
I wanted to see if there was any interest in these badges for this community. No badges would of been made WITHOUT the admin approval.
Sorry if i did jump the gun though.
Old March 6th, 2009, 03:06 AM   #18
akmer
i call dibs on number 31
akmer is offline
Old March 6th, 2009, 09:04 AM   #19
riithunder916
I"m glad to see this staring to come along!
Mike
Old March 6th, 2009, 10:35 AM   #20
LowClassCC
Fazda Tuning
LowClassCC's Avatar
dibs for 69
come on people we need at least 68 buyers other than me.
so far we have
1 dmark101
2 *open for admin/mod
3 *open for admin/mod
4 *open for admin/mod
5 *open for admin/mod
13 orange93gt
23 JazRedGT
31 akmer
69 LoeClassCC
114 riithunder916
117 guiltyspark117
dmark you should get 1 and 101
LowClassCC is offline
Old March 6th, 2009, 01:10 PM   #21
polarexpress17
bibliographically epic
polarexpress17's Avatar
I'll take 007.
95 mx6 with a 4 lug swap
Built, Not Bought.
polarexpress17 is offline
Old March 6th, 2009, 02:18 PM   #22
dmark101
dmark101's Avatar
no worries. we just want to make sure we're all on the same page with this.
32nd ANNUAL FABULOUS FORDS FOREVER - APRIL 30, 2017
Every Probe owner in CA is encouraged to attend! - Plan for it NOW!
dmark101 is offline
Old March 6th, 2009, 05:53 PM   #23
riithunder916
Originally Posted by polarexpress17 View Post
I'll take 007.
NICE!!!! now if these were for austin martins!
Old March 6th, 2009, 08:59 PM   #24
darkstarmotorsp
any news on the approval process?
Old March 6th, 2009, 09:04 PM   #25
Caffeine930
I'll take #95
95 GT Chameleon Beauty
"Without Risk There Is No Reward"
Caffeine930 is offline
[IMG] code is On
