Go Back   ProbeTalk.com Forums > General > Probe Lounge
Probe Lounge Discussion about most everything Non Probe related goes here.
Old March 16th, 2010, 11:47 AM   #1
MazdaMX6KLZE
1994 Ford Escort V6 2.5 BUILD
Ok so this had been in the talks now for a little while between me and Sean whether i should or not Build it and i decided to just go ahead and do it. Sean suggested before anything goes down that I have all my information on point so now this Escort is a BASE model and has a 1.9 SEFI Motor and it is a 5Speed. Im wanting to put either a KLZE or KLDE and I need to know if any of you have any information as to what I will need to know as far as any custom work or parts i may need to make this project possible. The Escort is gutted with nothing but a Dash and 2 seats (lol) so its light and should pull out some good numbers (hopefully). So any suggestions or help with this is greatly appreciated. This project is not only for just me but for those that said "Dude its only an Escort" "what could it possibly do?" lol so lets show them. Thanks for any help that you can provide.
MazdaMX6KLZE is offline   Reply With Quote
Old March 16th, 2010, 11:55 AM   #2
V3rtigo
V3rtigo's Avatar
you need a mx3 front subframe and then its pretty much a bolt on affair. There are multiple KL scorts running around WI
2006 WRX Limited SRR
2013 STi Limited PBP
V3rtigo is offline   Reply With Quote
Old March 16th, 2010, 11:59 AM   #3
MazdaMX6KLZE
Sick, thanks man.
Old March 16th, 2010, 12:01 PM   #4
riithunder916
I was about to say that myself, Get yourself an Mx3 parts car and your all set. What you don't you i'm sure you can sell it. Just make sure it's the v6 model.
mike
riithunder916 is offline   Reply With Quote
Old March 16th, 2010, 12:41 PM   #5
For all the money and effort why not go with the KLZE. I think it's only a difference in vacuum lines, EGR, and ECU between the 2.
Old March 16th, 2010, 12:47 PM   #6
riithunder916
the ze would be best, and if you just get the ze engine, it will have everything you need. A standard de computer will power the ze, but it won't have the right virus point, which can be solved one of two way, either with the right computer, or with window switches from msd, or you can tie them open....
Old March 16th, 2010, 03:08 PM   #7
MazdaMX6KLZE
Ok cool, wow lots of info coming through. Thanks every1.
Old March 16th, 2010, 04:37 PM   #8
riithunder916
PT is full of it! i'm sure more people while chime in too!
Old March 16th, 2010, 08:39 PM   #9
Badandy44
PT Know it All
KLDE Wagon did the swap. He pretty much knows everything you need to know. Might want to try and getting a hold of him.
93 PGT-ZE-T<---- Yes T as in turbo.
89 PGT
Badandy44 is offline   Reply With Quote
Old March 16th, 2010, 08:48 PM   #10
lost4good2009
id be pissed if i got beat by an escort in my pgt but id gladly rock one and piss other people off! im sure i would hear tons of excuses from people at the track as to why they got real familiar with the rear of an escort hah
lost4good2009 is offline   Reply With Quote
Old March 16th, 2010, 09:17 PM   #11
sooksvtdriver
ahhhhhh, I started my car love with my first car which was an escort, over at escortracing.com before it was shut down....Ive watched youtube videos of the purple scort with the v6,....awesome
sooksvtdriver is offline   Reply With Quote
Old March 16th, 2010, 09:40 PM   #12
riithunder916
the only thing better would be a pink turbo escort v6
ultimate insult right there
Old March 17th, 2010, 03:17 AM   #13
Turpro
Actually you don't need the mx3 subframe. You can do mx3 LCAs or a set of 88 rx7 balljoints(that's what I'm going to use with my kl swap in my protege). If you're that gutted grab the dash harness and engine harness from a mx3 v6. Also grab the cluster. Not sure how well it will work in the escort dash though. Besides that you'll need the following
Kl
Kl trans
Mx3 axles
Mx3 motor/trans mounts. Aslo need the chassis braket for the pass motor mount
Mx3 shift linkage
And then you'll need the heater hoses,ect. Not sure what radiator you are thinking about using but the probe rad is huge and you'll need to massage the rad support a lot. I'm personally going with a 3 row civic half rad. Some say it won't be enough to keep it cool but I think it will. You can also do like shawn and run a 95 neon rad or dan [sac] uses a scirroco rad. Both of those you can get in all aluninum dual core for 200-300. Hit up clubprotege. There's a lot of info there on the swap into the bg chassis. Also best bet is grab a millenia intake manifold because the straight neck will come close to hitting the brake fluid resivoir.
1993 Mazda protege-soon to be kl powered
Turpro is offline   Reply With Quote
Old March 17th, 2010, 10:48 AM   #14
hppwdn
Golden Egg Purveyor
hppwdn's Avatar
I considered doing a KL escort a few times. Cool swap.
($100 junkyard KLG4)
, 14psi, DOT approved Hoosier drags, pump gas.
HIN/NOPI Supershow Class Winner - Miami 2010 - Street-Sport Compact-Mazda
Links:
As of July 2011 the MX3 has been retired and sold.
hppwdn is offline   Reply With Quote
Old March 30th, 2010, 03:52 PM   #15
phantomplanet89
I just got a 95 4 door hatch escort . kinda thought about the KL switch.. its a auto. so like. GT auto tranny line up ok?
phantomplanet89 is offline   Reply With Quote
