Old January 3rd, 2017, 04:57 PM   #1
stoker100
stoker100's Avatar
Sunroof Delete ::HOWPROBABLYNOTTO::
Well each x-mas break i choose a project to keep me busy, this year is was deleting the sunroof from the probe. Certainly not a fun/interesting project but im sick of it leaking and for some reason i like to torture myself.
1) find a donor roof (from a non sunroof version)
2) remove old sunroof
3) mark out
4) nibble away
5) test fit
6) remove paint (note bog/rust removed in bottom left corner)
7) test fit
8) start the BS welding
points to note:
- i am not an auto-body repair person, i cannot weld well so don't expect a nice next picture!
- i could have sat it flush in the old sunroof hole, i chose to overlap it by approx 10mm.
- the roof curvature appears to be different (the back near the hatch curves off quickly to the sunroof) im not changing this.
- i will paint it myself, if it turns out crap then ill put a wrap over it
- more to come soon.
Old January 3rd, 2017, 06:05 PM   #2
For future similar projects -you could get yourself a pneumatic lip former. And there are adhesives known to man that will bond metal to metal nearly as good as a weld. Form a half inch lip all the way around. Glue in cut piece of metal and then you have yourself a flush fit patch with very little body work required. I have a lip former -and it is highly recommended.
If you don't trust bonding glues -you can always add a hole dimpler to your tool collection and use countersunk head rivets along with the bonding glue.\
P.S. Your welding looks pretty good to me so far.
Old January 3rd, 2017, 07:39 PM   #3
stoker100
stoker100's Avatar
I looked into the glue and would have gone that way except the roof panel isn't reinforced and it would raise up the panel even further (meaning more bog). I will however be using metal glue from the inside to help increase the overall strength. I also could have formed the lip but if i was going to do that i would have just found an original sunroof panel and welded that in. The metal is VERY thin, less than 0.8mm thick so i didn't want to warp it forming it either.
9) 1/1000th through spot welding, i decided from here to just fill the rest as it was killing me.
10) half way through grinding back the welds, looks like it took 5min but it was closer to half a day
11) where i am leaving it for today.... bog, prime/fill, sand and repeat x10 has worn me out today.
The good new is its getting close to flat from what my eye can see.
Old January 4th, 2017, 04:07 AM   #4
Looking good to me. I had thought about filling in the dreaded hole on one of mine before -and not because of leaks -but because of air rattling. Mine would make noise at highway speed. And since the top wasn't glass -there was not really any use for it for me. I had tried using it once or twice -but they are actually quite lame. A window down does a far better job of keeping me cool on hot summer days.
Although -I do not have the welding skills that you have (nor the patience). That is a lot of very fine spots that would have been burn-thru holes for me. If I ever do fill one of those on one of mine (hahaha) I will use my lapper and glue technique. But -unless the glass top in my black one leaks -it will remain untouched. I already have far too many projects.
Keep pressing away at it -it looks good and I am anxious to see the finished product. I am amazed that you could even find a spare parts car "down under" to cut a top from. Aren't Probes fairly rare down there?
Old January 4th, 2017, 05:32 AM   #5
Greg 94 PGT
Five Star Member
Greg 94 PGT's Avatar
The last pic isn't looking too bad.
When I was doing the body work on my pgt, I removed the door lock holes and antenna hole.
It obviously wasn't the amount of welding, grinding, sanding, and filler you are doing. But even the amount I did helped me realize I don't want to do body work ever again.
So I can sympathize with you.
379whp @ 20lbs *Sold*
Greg 94 PGT is offline   Reply With Quote
Old January 4th, 2017, 09:13 PM   #6
stoker100
stoker100's Avatar
2000 were imported here, up until about 3 years ago i still saw plenty on the roads. now im lucky to see one a month.
Years ago i got someone to weld in an Australian 20c coin into my door locks (they fit perfectly) i did the bog/prime work on that and the antenna and they came out perfect. This sunroof project is 10000000000000x more work.
http://i299.photobucket.com/albums/m...ting/day2b.jpg
12) hope nobody works in conditions like i am (39.3c = 103f), ignore the top temp that is the air temp inside my rainwater tank.
13) I hate those little holes that are too big for the primer/filler but too small for the bog! trying to fill those but ended up using bog then sanding back what felt like 100kg of bog with 1600 sandpaper
14) Full coat of filler on the new section of roof
15) sanded that back one last time.... yes there is a dent in the middle of the roof (white part, probably from removing the internal structural support)
Tonight its getting one more coat of filler and that's it. Ive had enough of this project now, im going to go lay down somewhere cool.
Old January 5th, 2017, 11:51 AM   #7
Wait a minute... this was the perspex sunroof?
Old January 5th, 2017, 12:22 PM   #8
stoker100
stoker100's Avatar
Yes it was.
Old January 5th, 2017, 01:01 PM   #9
Aww
Old January 16th, 2017, 03:04 PM   #10
supercharged3.0
I have not seen this to be done before.
supercharged3.0 is offline   Reply With Quote
Old January 16th, 2017, 09:28 PM   #11
stoker100
stoker100's Avatar
its pretty much done for now, its glossed and ive rubbed it back with 2000 wet and dry, just waiting for a polishing pad to finish it off. came out ok for a rattle can job. will post pics once i complete my next project.
Old January 23rd, 2017, 01:43 AM   #12
stoker100
stoker100's Avatar
base coat:
after gloss:
close up (prior to 2000 wet sand and polishing):
all done (and now water resistant!):
Old January 23rd, 2017, 04:09 AM   #13
Great job!
Old January 23rd, 2017, 05:00 AM   #14
Greg 94 PGT
Five Star Member
It came out great. Bet you're relieved now.
Old January 23rd, 2017, 05:09 AM   #15
plx92
Finished product looks great! Nice work.
1992 Probe LX_Rust in Peace
1989 Probe GT_Weekend Warrior
2014 Fiesta ST_Lemon
2017 BRZ Premium_Daily
plx92 is offline   Reply With Quote
Old January 23rd, 2017, 11:58 AM   #16
LowClassCC
Fazda Tuning
LowClassCC's Avatar
That came out a whole lot nicer than I expected. Great job man!
LowClassCC is offline   Reply With Quote
Old January 24th, 2017, 07:59 PM   #17
pgt4speed
pgt4speed's Avatar
Looks phenomenal!
Sandon Lettieri
1993 Probe GT - KLZE & Stuff - 172whp / 161wtq - 146k
2013 Focus ST - Stock & Stuff - 251whp / 290wtq - 142k
pgt4speed is offline   Reply With Quote
Old January 24th, 2017, 10:17 PM   #18
stoker100
stoker100's Avatar
Thanks everybody, yes came out pretty good and i am relieved its finally done. I rushed the last few days of leave to get it done so its not perfect but its certainly good enough for a 23 year old car.
Old February 9th, 2017, 07:41 PM   #19
KLZEEscortGT
^^^^ slow learner
1995 Escort GT lowered, KLZE, CAI, long tubes, 2.5 inch exhaust, Fidanza fw, mx3 trans, and on ZEX
1996 Escort LX bagged, mx3 leather buckets, gt bumpers and skirts, 2.0l zetec swapped, cai, borla muffler, 3 yellow tops, Hornblasters train horn kit and a MASSIVE sound system
KLZEEscortGT is offline   Reply With Quote
Old February 12th, 2017, 09:29 AM   #20
pw_cc_runner
pw_cc_runner's Avatar
It was a lot more work but back in the day when I installed the factory moonroof into my car I removed the whole roof. A lot less body work since the b and c pillars are covered by the glass.
pw_cc_runner is offline   Reply With Quote
[IMG] code is On
Sunroof Delete 95PGTTech Appearance Section 20 March 28th, 2005 09:15 AM
94 Sunroof vs 95 Sunroof = Compatible? patnugent 2nd Gen (93-97) V6 2.5L 1 January 9th, 2003 04:37 PM
1st Gen sunroof install on a sunroof-less LX otakunoanime Appearance Section 0 May 6th, 2002 07:24 PM
sunroof or no sunroof ??? jared r Appearance Section 6 May 27th, 2001 07:18 AM
