Go Back   ProbeTalk.com Forums > Performance Section > Engine Electronics
Engine Electronics Do you own a Jacobs, MSD, MegaSquirt or other ignition/fuel system? Get in here and ask your questions!
Old March 29th, 2018, 07:34 PM   #1
V3N0M951
confirming ignition/spark settings.
ok everyone I have a 92 mazda 323 dropped a klde in it with MS1V3.57. Did the 98+626 coilpack with 36-1 crank pulley. Im having some issues with spark not firing correctly in cylinders 2 and 5.Which falls into the same coil driver. I just want to confirm my settings are ok so I can rule out that part of the ignition system. I followed the guides from the DIY to set up 3 ignition outputs. So yes everything is set up in the MS how its supposed to be.
owner of
89 Probe GL - ran, broke down, ran, junked
89 Probe GT - ran,broke, never got fixed junked
89 Probe GT - the 1st probe replacement
92 mazda 323 - current daily, klde swap coming soon
V3N0M951 is offline   Reply With Quote
Old March 29th, 2018, 07:39 PM   #2
V3N0M951
im having trouble uploading a pic. anyways this link will direct you to a screenshot of my settings.
https://drive.google.com/file/d/1nTG...ew?usp=sharing
owner of
Old March 29th, 2018, 09:02 PM   #3
J_Unit
How new is your MS? Has it been in use for a while?
J_Unit is offline   Reply With Quote
Old April 4th, 2018, 01:00 AM   #4
V3N0M951
got it figured out. a solder joint actually did break off so it was barely making contact to the resistor on the board.
owner of
Old April 5th, 2018, 10:07 AM   #5
BlackProbe
am trying to do the samething on my mx3,with my diypnp ecu..i think i got everything right..i guess ill find out real soon..
93 Probe gt- ,15.37 1/4 mile at mph 85 ** 5/24/03 14.71 SOLD
1994 gt -klze,I/h/e/fly/ignition/kl31 ecu,colt210/210 cams Rip 2/13/08(blackice)
92 mx3gs,ze swap from my probe 15.0@96mph :-( 175hp&155tq
BlackProbe is offline   Reply With Quote
confirming nissan injectors will work proboner Forced Induction (Turbo/S.C.) 5 January 23rd, 2008 06:15 PM
Confirming some things!! breezn 2nd Gen (93-97) V6 2.5L Performance 3 June 18th, 2007 09:27 PM
Confirming what I suspect I already know. Domino81 2nd Gen (93-97) V6 2.5L Performance 6 June 7th, 2007 08:36 AM
Ignition, Ignition, Ignition Wowo76 2nd Gen (93-97) V6 2.5L Performance 1 January 2nd, 2003 10:54 PM
