i put in new cams, waterpump, timing belt, and a ze manifold....and ive got it 95% back together (misc vaccum lines, splash guards, dumb stuff) and itll crank about 4 times (you know when you crank it and it goes rrrrr rrrrrr rrrrrr ? it does that 4 times or so) and then thuds which slows down the cranking and then it keeps going and then thuds again
im a bit confused as to what this will be
it doesnt do it while the distributor is unplugged
what gives?
what gives?
