2010 Colt Cam Bulk Buy V6 2.5L
  • #46
    I am in on this I want just the 210 street cams.. but I was wondering will I be getting back the same cores that I send them??
    1992 Mazda MX-3 GS - KLG4 Turbo
    Scott
    • #47
      You receive your cams back.
      When they receive cams they color code paint them all
      clean/ inspect/ prep for grind
      grind all intakes
      grind all exhausts
      final processing
      engraving your order number on the cam
      repackaging/shipping
      I seen their setup last time and it is super organized. They know if they have mixed up a cam at the end, and haven't done it yet Geoff said.
      Geoff also does all grinding work himself.
      • #48
        is it possible to get these cut to spec for SLA's?
        Beautiful Beast- 1997 PGT in process of becoming an SC/NA Beast...
        Elo- 1990 BMW 325i weekend car
        Brunhilde- 2003 BMW Z4 3.0 6-speed daily driver
        • #49
          Look for Integral Cams...
          Originally posted by racerx43269 View Post
          maybe a group buy for the FSDE 2.0? lol i need cams so i would be down...
          • #50
            By 210 street cams you mean the "colt performance NA grind" correct????
            http://www.supermotors.net/registry/20602
            http://www.supermotors.net/registry/20602/73905
            • #51
              Which of these would be the best choice for an n/a bolt on KLZE? Will be running stock electronics w/ Interprep springs/retainers.
              1988 MX6 GT $2015 Challenge Car, 1990 MX6 GT DD/$2015 Challenge Car, 1993 Escort GT Broken Forever, 1993 Miata F2T Incoming, 1998 5spd Cherokee Sport Overland, 2000 Cherokee Sport Yum! Groceries!, 2000 Miata Track car
              • #52
                I would recommend the colt performance NA grind or if you want more aggressive you could also get the colt tri flow NA grind...
                • #53
                  welp im going thru delta... they said it was like 100 a cam for regrinds.. and im sending in a spare set i have
                  • #54
                    So both of those play nice with stock tunes? I have no interest in going standalone with this thing. Probably the most it would get would be a chip down the road.
                    • #55
                      The bulkbuy has begun aye!? I'm gonna pull my de cams out I am contemplating turbo triflows
                      -Nick
                      • #56
                        Jason, please change my grind to Colt Race N/A.
                        My cams will be shipped out Jan. 3, 2011.
                        • #57
                          both of those grinds should work fine with the stock ecu.. And although tuning would be limited with the stock ecu i would still recommend getting a wideband and tuning it a little.. That way you can get max performance..
                          ---------- Post added at 03:42 PM ---------- Previous post was at 03:40 PM ----------
                          -Nick
                          The turbo tri flows should be great for a street or strip car.. A few members on here have them and love them.. I will be installing my tri flow turbo cams this winter and retuning this spring.. Just let me know if you do decide you want in on the bb..
                          ---------- Post added at 03:43 PM ---------- Previous post was at 03:42 PM ----------
                          Changes have been made.. Thanks
                          • #58
                            I am very interested in a race grind set, this triflow thing is new to me I need too look it up first but one or the other I am ready to go.
                            I'll give the Triflow a shot, Race Grind.
                            I will package up a set and get everything ready but I am not shipping until after christmas with all the nightmares that happen over christmas. I can pay before then if need be.
                            Also any chance of getting a set of Miata 1.8L cams done too I have some spares and I am sure if we get one set on my MS car we would have quite a few locals ready to jump right away. PM me on that.
                            Denny Crane /\ Capsule E.R.
                            05 GTO 408 Stroker \ 13 FRS LSx Swap (IP) / 02 Camaro SS 6.0L Chey's \ 14 F-150 5.0L / 96 MX6 M-Edition
                            Give college students enough time and they can set anything on fire. --Cross & White Dart
                            • #59
                              What kind of setup will you be using the cams on? turbo, supercharge, nitrous or NA? If your unsure about anything you can always call geoff at colt so he can explain things to you in detail.. The tri flow cams have been around a year or two.. I bought a set of tri flow turbo cams last bb but wont be installing them for another month or so.. However, several members here who got the tri flow cams last bb are very pleased with them.. Just let me know when you have made your decision and ill get you on the list.. Anything else let me know..
                              Thanks
                              Jason
                              • #60
                                I'm weird goals jump all over since I have done so many different things.
                                Either way I updated my original post I will let you catch up to that one and I went with the Tri-Flow Race Grind.
