Old November 11th, 2017, 05:47 AM   #1
undertaker
Brake/Fuel/Evap lines
So I am looking to buy a few rolls of brake/fuel line since my rear brake, evap, and fuel lines are rusting pretty bad. I found a few options but wanted to get opinions on what would be good to use since I live in the rust belt. These are the 3 options I have found:
- steel line, zinc coated and copper lined
- Nicopp (copper/nickel) line
- pvf coated steel
Prices seem to be pretty reasonable for 1/4 and 3/16 diameter in any of the 3 options.
Has anyone done the fuel/evap lines? I didn
Undertaker
1993 Ford Probe GT
2013 Mazdaspeed3 Touring w/ Tech Package
undertaker is offline   Reply With Quote
Old December 1st, 2017, 01:04 PM   #2
ScottF
Seeing as how you live in Wisconsin, I would go for the one with best resistance to corrosion, LOL Not trying to be smart-assed or anything, but I know the winters up there can get messy
ScottF is offline   Reply With Quote
Old December 1st, 2017, 03:30 PM   #3
LowClassCC
Fazda Tuning
LowClassCC's Avatar
Nicopp. I just replaced all the brake lines on my wife's s10. I have used steel line in the past and hated everything about it. working with Nicopp was a wonderful experience and i am looking forward to redoing her fuel lines next.
LowClassCC is offline   Reply With Quote
Old December 4th, 2017, 12:26 PM   #4
undertaker
Awesome, thanks for the responses. I will go with the nicopp. Can anyone verify the size of the fuel lines? I have found a few posts where some specify 1/4 while others specify 5/16. I will probably measure them, just have to find time to get over to the storage area and jack up the car.
Undertaker
1993 Ford Probe GT
Code PO 443 (D) EVAP Control Purge Malfunction sumbuGT 2nd Gen (93-97) V6 2.5L 8 November 14th, 2006 05:01 AM
fuel vent and EVAP? rock2000 2nd Gen (93-97) V6 2.5L 5 August 8th, 2004 12:46 PM
HElp.. EVAP purge solenoid code.. obdII EvoPGT 2nd Gen (93-97) V6 2.5L 3 May 20th, 2004 08:30 AM
Taking out Fuel Evap Canister ? Trancerx84 2nd Gen (93-97) I4 2.0L 2 September 23rd, 2003 08:44 PM
